Fake Nvidia GTX 1050ti
bebeto_maya
8 (0.01/day)
Hello everyone. It is already common that "manufacturers" are applying this scam. So I took this card identified on the GPU-z as GTX1050ti, but I believe it is a GTS450. After a lot of reading, I decided to buy a CH341A bios recorder. Replaces the Bios with about 10 versions of the GTS450 / 1gB and none worked (I used Programmer EPROM 1.29). The screen is blurred and nothing appears. So, the memories of this board are ELPIDAS 1032BABG-50-F. Photos are included. Has anyone had this experience and can help me?
8,088 (1.35/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
Did they remove the bottom number on the GPU chip its self? Looks like just a bit of "A1" is visable.
5,834 (0.81/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Razer Pro Type Ultra
Please take a picture of the core that doesn't have terrible glare, so that we can actually see the numbers. It's unlikely to help, since as @thebluebumblebee noted the seller has already removed the actual part number from the chip, but it certainly won't hurt.
Would also help if you would tell us how many memory chips are physically present. And what display outputs the card has. And what PCIe power connectors it does or doesn't have.
At this point you might as well try every BIOS listed at the bottom of https://www.techpowerup.com/gpu-specs/geforce-gts-450.c1778
dorsetknob
9,106 (1.27/day)
Simple Answer is NO
This Scam is generally perpertrated by individuals from **** via Ebay with no official connection to OEM Manafactures.
Sometimes Fooled Buyers try to recuperate their Purchace by offloading their fake purchace via other local resellers.
bebeto_maya
8 (0.01/day)
Yes.
Hello, The Exact Core number and text:
NVIDIA
12B7B613 1131A1
S TAIWAN
PAY329.M08
The inferior number, as @thebluebumblebee said, looks a like Ai or A1 (removed??)
Theres 8 chips of memory: ELPIDA W1032BABG-50-F 1028W90L700 (probally 1GB in total)
The output problem is the application crash after memory overflow (which should be 1GB and not 4GB, like writed in GPU-Z).
Thank you so much.
8,088 (1.35/day)
Hillsboro, OR
System Name Main/DC
Please post a picture of both the front and the back of the entire card.
bebeto_maya
8 (0.01/day)
Simple Answer is NO
Hi, Yes, i put the quotes. "manufactures". Bye ; -)
Ok...
By the way, if i used the original adultered BIOS, come back to the function (so-so, freeze the screen in applications 3d)....
14,064 (3.82/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
Try this Asus Bios, your card is a Fermi GF116 which is a GTS450 R2
8,088 (1.35/day)
Hillsboro, OR
System Name Main/DC
That has a power connector. OP's does not.
bebeto_maya
8 (0.01/day)
Whathever, someone knows the code wheres the memory reference in hexadecimal of BIOS? I will try rewrite the BIOS code for the memory and low to 1024MB.
