"Fake" reference RX 580?
6 (0.00/day)
System Name A M D
Processor Ryzen 5 3600
Motherboard Gigabyte B450M Gaming
Cooling ID Cooling 240mm AIO
Memory Team Elite 8GB 3200Mhz x2
Video Card(s) RX 480 Reference 4GB
Storage WD Blue SN550 512GB + 2TB HDD
Display(s) ASUS VZ249HE
Case Corsair Carbide Spec-01
Power Supply Corsair CS 550M
Keyboard Cooler Master CK550
This is my first time posting here, sorry if I did anything wrong. I saw a used reference RX 580 4GB (at least it is what the seller claims to be) for pretty cheap, so I decided to take the risk and grab it. After confirming that it does work, I proceeded to clean and repaste the card. I also did some visual inspection. Here are some pictures.
Oddly it only has a single 6-pin connector (I think it is supposed to be one 8-pin). I have heard of a Dell OEM 580 with red PCB that only has a single 6-pin connector. But I have never seen one like mine with black PCB. I asked the seller and he claims that it is a low power version of the 580. Here are the GPU-Z and 3DMark screenshots.
I should also mention that DDU recognize it as Polaris 10 instead of Polaris 20. The GPU die does not have any marking (I am not sure if RXs have such marking). I looked up the numbers on GPU die side and most results are related to RX 480 reference. I also Googled the P/N on the back of the PCB but nothing showed up. My guess is that it is a reference RX 480 flashed to 580. What do you guys think, should I attempt to flash back to 480 vBIOS?
EDIT: Under the "Advanced" tab I saw an interesting thing. The board power limit is 110W, and I never see it go past that even in intense situations. It could very well be a power limited version of RX 480/580.
EDIT 2: Here is the link I got from the "Lookup" button. Looks like it has a DVI output so it is unlikely to be my card.
13,617 (3.82/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
There's a number of RX580 with that device ID also @4GB.
1,905 (0.57/day)
Seattle, WA
This is exactly what it looks like. It's got a PCPartner sticker on it so its safe to assume it's an OEM card. Some RX 480s were resold as 580s with no physical changes with some brands, and the PCB number matches the reference 480.
1,470 (0.22/day)
Processor Ryzen 1600AF @4.2Ghz 1.35v
Motherboard MSI B450M PRO-A-MAX
Cooling Deepcool Gammaxx L120t
Memory 16GB Team Group Dark Pro Sammy-B-die 3400mhz 14.15.14.30-1.4v
Video Card(s) XFX RX 5600 XT THICC II PRO
Storage 240GB Brave eagle SSD/ 2TB Seagate Barracuda
Display(s) Dell SE2719HR
Case MSI Mag Vampiric 011C AMD Ryzen Edition
Power Supply EVGA 600W 80+
Can you use the upload bios button on gpuz and see if there is a copy in the database
6 (0.00/day)
System Name A M D
How do I do that, is it the "Lookup" button?
Edit: There is also a "Validation" tab.
That's a good find, my card has the exact same frequency as the last one with 1340 core and 1750Mhz memory.
I have also added some extra info to the original post (power limit).
13,617 (3.82/day)
Sunshine Coast
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Probably an ex-mining card flashed to something that worked, without being the stock Bios.
6 (0.00/day)
System Name A M D
I just uploaded the BIOS, here is the link:
It shows up as a Yeston card again. Now my main concern isn't whether it's a 480 or 580, but whether I should try to flash a reference 480/580 BIOS.
13,617 (3.82/day)
Sunshine Coast
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Post the number stamped onto the memory chips please, eg: Samsung K4G41325FE
6 (0.00/day)
System Name A M D
The photos I took doesn't show the memory chips very well. I am afraid I have to take my card apart to see the chips again. GPU-Z shows it's Samsung K4G41325FE though.
13,617 (3.82/day)
Sunshine Coast
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
My suggestion would be to try flashing 480 bioses to it as those memory chips were used from 460 through to 5 series.
If the chips have HC 25 after the memory chip number they are the faster 8.0Gbps, HC 28 are 7.0Gbps.
6 (0.00/day)
System Name A M D
I am not experienced in finding and flashing BIOS so I am going to need some advice.
After some looking I there are 3 BIOS in my selection:
These seems suitable but I am confused by the memory timings.
Almost every BIOS has different timings. How to determine if it is suitable?
Do I need to find a BIOS with the exact same device ID and subsystem ID?
6 (0.00/day)
System Name A M D
Just wanna update that I flashed a 480 BIOS and everything is working fine for now. It seems to run quieter too. Thanks a lot for everyone's help.
