Fan Controller on a water pump.
DaMulta
My stars went supernova
16,168 (2.36/day)
Oklahoma T-Town
System Name Work in progress
Processor AMD 955---4Ghz
Motherboard MSi GD70
Cooling OcZ Phase/water
Memory Crucial2GB kit (1GBx2), Ballistix 240-pin DIMM, DDR3 PC3-16000
Video Card(s) CrossfireX 2 X HD 4890 1GB OCed to 1000Mhz
Storage SSD 64GB
Display(s) Envision 24'' 1920x1200
Case Using the desk ATM
Audio Device(s) Sucky onboard for now :(
Power Supply 1000W TruePower Quattro
Now there is 3 wires on the DD Fixed speed pump. 2 for power 1 for temps.
Could you use a fan controller to control the pumps flow?
http://www.zalman.co.kr/ENG/product/Product_Read.asp?idx=209
Has anyone here tried that? I don't have a fan controller to test my idea with.
calvary1980
1,801 (0.28/day)
Toronto, CA
Processor Intel Core 2 Quad Q6600 Kentsfield L724A629 @ 3.8Ghz 423x9 1.47v
Motherboard Abit IP-35 Pro Beta 16.B04 (vDroop)
Cooling 6x Scythe S-Flex SFF21F, EK Multi Option 2 Port, dB-1 Compact, Swiftech MCR80, Swiftech Apogee GT
Memory 2x1 OCZ Flex XLC PC-9200 @ 5-5-5-18 1220 2.3v
Video Card(s) Inno3D Geforce 8800GTS 320
Storage Western Digital Raptor X 150
Display(s) Samsung Syncmaster 226BW 22"
Case Cooler Master RC-690
Audio Device(s) Creative SoundBlaster X-Fi Xtreme Gamer 7.1
Power Supply Thermaltake ToughPower 1000
Rheobus handles 20 watts per channel, 12 volt control. I don't see why not I don't think it's wise though :p
- Christine
panchoman
Sold my stars!
9,595 (1.48/day)
Processor Amd Athlon X2 4600+ Windsor(90nm) EE(65W) @2.9-3.0 @1.45
Motherboard Biostar Tforce [Nvidia] 550
Cooling Thermaltake Blue Orb-- bunch of other fans here and there....
Memory 2 gigs (2x1gb) of patriot ddr2 800 @ 4-4-4-12-2t
Video Card(s) Sapphire X1950pro Pci-E x16 @stock@stock on stock
Storage Seagate 7200.11 250gb Drive, WD raptors (30/40) in Raid 0
Display(s) ANCIENT 15" sony lcd, bought it when it was like 500 bucks
Case Apevia X-plorer blue/black
Audio Device(s) Onboard- Why get an sound card when you can hum??
Power Supply Antec NeoHe 550-manufactured by seasonic -replacement to the discontinued smart power series
Software Windows XP pro SP2 -- vista is still crap
if the controler can handle the pump wattage, you shouldn't have a problem, as all the controller does is limit the voltage.
DaMulta
16,168 (2.36/day)
Oklahoma T-Town
Storage SSD 64GB
Well I control it now with a meanwell, but that is controlling it with voltage not watts. This would be a lot better in my eyes.
I wonder how many watts it eats.
3,527 (0.55/day)
UK
System Name Dream Weaver
Processor Ryzen 5600
Motherboard B450 MSI Gaming Pro Carbon AC
Cooling NH-D14
Memory 16GB Flare X @ 3200MHz CL14
Video Card(s) Sapphire Vega 64 Nitro+
Storage 500GB evo 970 m.2 + 4TB HDDs
Display(s) ASUS 27" 1440p 144hz FreeSync
Case Fractal Design Define R3
Power Supply Corsair 850W
calvary1980
1,801 (0.28/day)
Toronto, CA
why? the pump should be running 100% when the power supply is on. I get annoyed when people inquire about connecting there radiator fans to a controller some things should not be played with, liquid cooling is about efficiency if a pump or fan bothers you maybe you should go back to conventional.
- Christine
DaMulta
16,168 (2.36/day)
Oklahoma T-Town
Storage SSD 64GB
why? the pump should be running 100% when the power supply is on. I get annoyed when people inquire about connecting there radiator fans to a controller some things should not be played with :)
- Christine
I only run 100% fans and 100% pump when I am ocing:)
There is no point in doing that when I'm not overclocked.
calvary1980
1,801 (0.28/day)
Toronto, CA
what was the point of purchasing $200 worth of water cooling equipment if you were just going to run the entire loop at 50% liquid cooling is about efficiency it doesn't pay off until you reach extreme temperatures.
- Christine
intel igent
4,640 (0.64/day)
Toronto, Canada
System Name old school / new school
Processor 3.0e C0 @ 3.6 / e5200
Motherboard p4p800e-dlx / p5q-DLX
Cooling custom water see sig / air
Memory 2x1g oczPC4000EbPl / 2x2g ocz2rpr1066
Video Card(s) 3850AGP / 4890vaporX
Storage 36g raptor+120g wd / wd 1001fals 1tb
Display(s) BenQ / sharpAQUOS LC-37D64U
Case modded antec plusview / generic
Audio Device(s) audigy 2zs / ASUS Xonar HDAV1.3
Power Supply fan/cable modded powerstream 520 / OCZ 700mxsp
Software Xp pro SP2 / VISTA ultimate OEM
there is no point in OC'ing if you're going to put it back to stock DaMulta.
DaMulta
16,168 (2.36/day)
Oklahoma T-Town
Storage SSD 64GB
I ran death clocks and then I have oc clocks that don't require me to run everything 100% fan noise.
cdawall
where the hell are my stars
27,683 (4.04/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
i'm thinking that he doesn't go back to stock just not extreme anymore
DaMulta
16,168 (2.36/day)
Oklahoma T-Town
Storage SSD 64GB
- Christine
To run death clocks from time to time, but why do death clocks have to be 24/7?
calvary1980
1,801 (0.28/day)
Toronto, CA
simple answer because you can. I don't want to get in a discussion about philosophy of overclocking. all im saying is maybe you should of thought of this before you purchased.
- Christine
intel igent
4,640 (0.64/day)
Toronto, Canada
who said anything about death clock's?
i've been running my max stable OC 24/7 since day 1 which wouldn't be possible without my w/c, damn presshotts :mad:
Morgoth
Fueled by Sapphire
4,253 (0.66/day)
Netherlands
Motherboard aorus x570 pro
Cooling air (GPU Liquid graphene) rad outside case mounted 120mm 68mm thick
Storage 300gb hdd OS backup. Crucial 500gb ssd OS. 6tb raid 1 hdd. 1.8tb pci-e nytro warp drive LSI
Display(s) AOC display 1080p
Case SilverStone SST-CS380 V2
Mouse corsair gaming mouse
Keyboard Microsoft brand
i can try it but i dont have a molex to 3/2 pin adapter
DaMulta
16,168 (2.36/day)
Oklahoma T-Town
Storage SSD 64GB
Let me know how it works if you do try it.
WarEagleAU
Bird of Prey
10,812 (1.58/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
Who cares why, its his, let him do with it what he wants. I dont see why it wouldnt work, and it should work quite well. Aside from maybe software control, I dont think a LC has fan control on it, does it?
cdawall
27,683 (4.04/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
2nd'd some pumps are adjustable like the MCP655 i'm getting it just depends
Morgoth
Fueled by Sapphire
4,253 (0.66/day)
Netherlands
Damulate what pump are you using?
DaMulta
16,168 (2.36/day)
Oklahoma T-Town
Storage SSD 64GB
Morgoth
Fueled by Sapphire
4,253 (0.66/day)
Netherlands
good i'm using that to gona try it tonight ;)
