Fan Curve keeps resetting to default for GPU
sargetun
14 (0.01/day)
So I have a RX 5700 XFX DD ultra(xt bios if it matters) and have a custom fan curve I set in Radeon software. The default fan curve is horrendous, never going above 50% and staying at like under 20 around peak temps, so I just set a simple one, attached a screenshot to show what I use and if anyone also has any suggestions to change I'm fully willing. Before I set the curve or if I restart/turn off my pc and turn it on later everything saves but the fan curve, it even still shows manual but the curve I set only stays consistent if the pc is on, the global graphics remains the same, any other OC I do stays the same, so I am not sure why this is happening. If it is a known issue of some sort, is there any other advised software I should use? If I don't set a fan curve the card thermal throttles and even has shut down, I checked paste and aio it's doing its fine, I've read the card gets hot a lot anyways so I'm not too worried, with the fan curve set it doesnt seem to peak past 80c even on hotspot. If it helps im also using radeon version 20.1.3
~~EDIT: After reading over the post I see the junction temp is actually obviously bugged as well, it seems that this happens randomly as well, that or the fan speed there, I didnt get a screenshot to show but i was playing squad and was streaming from there,went to check stream and checked my fan curve make sure it stayed, and it showed 55000 rpm lol
