[Fan problems] Asus HD7770
85 (0.03/day)
Heya!
I seen lots of people post here questions and etc about their AMD/ATI gpus, so I am gonna do it too, since I got a problem with my card.
Now the problem with my card is that it has some weird fan profile that I can't change at all, no matter what application I use.
The card auto adjusts itself, whenever it gets to 50 degrees it sets fan speed to 60% and as soon it goes down to it sets fans to 20% and then ramps up again just to cool it down and it does that over and over and over, none-stop!
Once the card reaches above 65 degrees the fan sets itself to almost 100% and it sounds like a hurricane.
I have no warranty left and not much money to spare. So wondering is there anyway to fix this issue? Like a Bios change?
1,269 (0.35/day)
Birmingham UK
System Name El Calpulator
Processor AMD Ryzen R7 7800X3D
Motherboard ASRock X670E Pro RS
Cooling ArcticCooling Freezer 3 360ARGB AIO
Memory 32GB Corsair Vengance 6000Mhz C30
Video Card(s) MSI RTX 4080 Gaming Trio X @ 2925 / 23500 mhz
Storage 5TB nvme SSD + Synology DS115j NAS with 4TB HDD
Display(s) Samsung G8 34" QD-OLED + Samsung 28" 4K 60hz UR550
Case Montech King 95 PRO Blue
Audio Device(s) SB X4+Logitech Z623 2.1+Astro A50 Wireless
Power Supply be quiet! Pure Power 12 M 1000W ATX 3.0 80+ Gold
Mouse Logitech G502X Plus LightSpeed Hero Wireless plus Logitech G POWERPLAY Wireless Charging Mouse Pad
Keyboard Logitech G915 LightSpeed Wireless
Software Win 11 Pro
Benchmark Scores Just enough
Heya!
What software have you tried to use this far? The BIOS change would be an option if you have the proper knowledge and skills ( this is a risky thing) another thing to do would be to get a better aftermarket cooler (again involves some skills to replace it)
Mussels
Freshwater Moderator
58,413 (8.00/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
sounds like you need to dust out the heatsink and replace the thermal paste.
It gets hot, so the fan spins up
Overheats despite the fan spinning up, so it throttles the card
card is cooled down so fans slow down
Card then reverts to full speed, card starts to get hot again...
85 (0.03/day)
I been using MSI-Afterburner and Asus own GPUTweaker tool both work alright until the GPU hits 50 degrees after that I assume the internal fan profile hits in and takes over and overrides the software profiles and starts to make noise.
I have cleaned out the heatsink from dust with a compressed can of air and I have applied some none-conductive thermal paste as well as applied new thermal pads around the VRAM. The idle temps of the GPU is 22-24C, while doing light gaming, such as CSGO or Dota2 the GPU will never reach 50 degrees. However if I play games that are more demanding the GPU will hit a maximum of 66 degrees but the fans will spin almost at 100% which is insane and the GPU will not stop spinning after it cools down. I have to go to MSI afterburner to lower the fan down to 20-40% maxspeed, sometimes it won't work and I need to do a reboot.
1,269 (0.35/day)
Birmingham UK
Software Win 11 Pro
Those are respectable temps, it seems that a custom BIOS would do the trick for you but that is a big risk. I would advise to get a better cooler instead.
88 (0.03/day)
System Name Xena
Processor 2x X5660 2.8 Ghz
Motherboard Tyan S7010
Memory 48 GB DDR3 1333Mhz ECC registered
Video Card(s) Gigabyte GTX 660 ti windforce
Storage 3 TB WD red
Case MaxData platinum 500
Power Supply Chieftec APS-850CB
Software Win 7 X64 ultimate
I saw few times when GPU is dying that it gets higher temps than usual
First sign of that is: Screen sometimes goes blank and following message you get: display driver stopped working and successfully recovered
When things get worse you get randomly blue screens
If that is a problem which i described, only solution is buying new GPU
Mussels
58,413 (8.00/day)
Oystralia
those temps do seem OK, unless something else on the card is overheating that doesnt have a temp sensor (VRMs?)
85 (0.03/day)
I would like to try the BIOS thing since I am not really in the current state to put money into anything outside of my bills.
Nah I haven't suffered from any black or blank screens, nor have I suffered from BSOD or had display driver stopped working and successfully recovered. I am just suspecting that something else is up with the card.
Could be so, but I would really like to try fix a BIOS change on the internal fan profile setting.
Also this is the card I am having troubles with.
HD7770-DC-1GD5
https://www.asus.com/Graphics-Cards/HD7770DC1GD5/
Mussels
58,413 (8.00/day)
Oystralia
Have you considered hard wiring the fan to an external power source?
I've rigged GPU fans to 9V/7V in the past and left them at set speeds (if you go too low the temps rise, too high and its always loud - but its an option)
85 (0.03/day)
This sounds interesting, could try to wire it out of the case and add a potentiometer for lowering and raising the voltage.
If there is no option for flashing then I might look into this.
1,901 (0.33/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
Just use MSI afterburnner n crank up the fan profile, https://www.msi.com/page/afterburner
Also suggest as others have to replace the factory TIM if the warranty is void, as that means the card is a few years old by now. Always good to replace the TIM after the GPU gets a few years old.
4,496 (0.83/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
OP did both. Read the whole thread....
88 (0.03/day)
System Name Xena
Storage 3 TB WD red
That's good to hear
I have 2 questions:
1. Those new thermal pads for VRAM - are they same size like old ones or they are fatter?
2. When you assembled graphics card after applying thermal paste - did you tight all screws around GPU with similar strength?
(also if you have 3 screws for GPU instead of 4 - that is huge problem)
85 (0.03/day)
That's good to hear
I have 2 questions:
1) The new thermal pads for the VRAM are at the same size as the old ones
2) I assembled it by screwing cross-wise so, start at one end and then to the other side diagonally. First, a bit then fully screwed once every screw was placed. It has 4 screws.
88 (0.03/day)
System Name Xena
Storage 3 TB WD red
You did it properly like a pro so problem is not on your side
I have 1 last tip for your problem because i had same problem
I think that problem is thermal taste, when thermal paste after some time starts to separate oil from itself
It's very small amount of oil but you can see it when you are applying paste on GPU or CPU
anyway that paste is useless because it conducts heat pretty badly
Now, you will probably ask: how to know did i have bad thermal paste (i am not sure that i saw any oil)?
Answer: easy, if you have bad thermal paste on idle temperature of the card is low , but when you start furmark test- Gpu temperature climbs almost instantly (a 2-3 seconds) to 65 or more steepen Celsius
If that is your case - than you should buy new thermal paste
FreedomEclipse
~Technological Technocrat~
23,889 (3.75/day)
London,UK
System Name DarnGosh Edition
Processor AMD 7800X3D
Cooling AM5 Contact Frame + Thermalright PS120SE
Memory G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
Sounds like you're not a fan of this problem OP
2,597 (0.56/day)
East Europe
System Name PLAHI
Processor I5-10400
Cooling 120 AIO
Video Card(s) PNY QUADRO RTX A2000
Storage Intel 670P 512GB
Case SilverStone Raven RV03
Audio Device(s) Creative Sound Blaster Z OEM
Mouse Logitech Triathlon
Keyboard REDRAGON MITRA
Software Windows 11 Home x 64
May be a second hand aftermarket GPU cooler ? Something you can get on the cheap ? DBA.DK?
85 (0.03/day)
I the thermal paste is quite new. I bought it two weeks ago from now, I bought Arctic cooler mx-4. The GPU temp doesn't reach to 65 or more within seconds, it actually takes a few min and this is only when playing heavy titles such as, BF1 or Fallout4. Problem is that the GPU won't often even reach this temp since it will start the fans when it reaches 50 degrees and when it reaches that high, it starts to spin up the fans to around 50-60% and this is annoying as it goes up and down quickly. So you can imagine that the GPU temp will hover around 50 and below and the fan will spin over and over again. Worst part is that I can't control it with MSI afterburner or Asus GPU tweaker tool.
Haha, yeah.
I haven't seen any cheap second hand aftermarket GPU cooler for my HD7770 and buying one online isn't cheap as I will have to pay for shipping(most of the time) and taxation.
88 (0.03/day)
System Name Xena
Storage 3 TB WD red
Last thing to try is AMD Overdrive - software included with graphics card driver
beside overclocking it gives user fan speed control on fixed (same) rpm all the time
You could set it on 40% or 50%, than start benchmarking your card while monitoring GPU temperatures (benchmark also include games that you mention before) and you are safe as long as temperatures are below 75 degrees Celsius
If that doesn't help, than only thing left to do is:
no more ideas /cry
1,568 (0.31/day)
Kolkata, India
System Name Coffee | Maximus
Processor Intel Core i7 9700K @ 5.2 GHz with AVX/4.8 GHz cache | i7 9700KF @ 5.0 GHz/4.7 GHz cache
Motherboard ASUS Maximus X Formula | ASUS Maximus VIII Ranger (modded BIOS for Coffee Lake)+TPM2.0 module
Cooling Cooler Master ML240 Illusion | Cooler Master ML120L RGB
Memory 2*16 GB (32 GB) Kingston Fury Beast @3600 MHz CL17 | 4*8 GB (32 GB) HyperX Fury @3200 MHz CL14
Video Card(s) Zotac RTX 3070 8 GB Twin Edge OC | Galax RTX 2060 Super 8 GB
Storage Samsung PM981a 1TB+Crucial P5 1TB+480GB SATA SSD+2 TB HDD | Crucial P1 500GB+2.5TB HDDs
Display(s) LG OLED 55 G3, 4K 120 Hz, VRR, ALLM, GSync, FreeSync | Samsung 43AU9070 4K TV, VRR, ALLM
Case Corsair Crystal 460X RGB | Lianli Lancool 215
Audio Device(s) Creative Sound Blaster Z SE w 5.1 Home Theater | Realtek ALC1150 (Supreme FX) w 2.1 speakers
Power Supply ASUS ROG Strix 750G (80+ Gold) | Cooler Master MWE 650 V2 (80+ Bronze)
Mouse Cooler Master MM731 19000 DPI gaming mouse
Keyboard Cooler Master CK721 65% mechanical gaming keyboard (tactile)
Software Windows 11 Pro x64 |Windows 11 Pro x64
Benchmark Scores Cinebench R20 MT 4200,ST 547 CPU-Z MT 4871, ST 620 | R20 MT - 4158, ST - 534, CPU-Z MT 4798, ST 603
Fan profiles can usually be controlled all the time from software (MSI Afterburner, ASUS GPUTweak and even AMD Control Center). I think the problem you are facing is due to having two similar software for the same thing that they might be conflicting with the settings. I would suggest you to keep either MSI Afterburner or ASUS GPUTweak and check the results. Also, go to AMD Control Center and check the settings there too. As I said, use any one software at a time.
Note: Even if you are not using more than one application but have them installed, some services can keep running in the background and might cause problems. Better to uninstall one of them.
With AMD Control Center, you cannot control the fan speed with temp changes but you can set it fixed by setting up a percentage.
Also, if you know what you are doing, GPU BIOS modding ain't that hard to do. You can take a backup of your factory BIOS and just edit the fan speed values using the appropriate BIOS editor (RBE should work for non-UEFI GPU BIOS). And even if you happen to do anything wrong, reflashing the card is easy if you have onboard VGA or processor graphics.
Based on your skills (from what I read here), I am confident enough that you will be able to mod the BIOS successfully to achieve your requirement if need be.
All the best. :)
85 (0.03/day)
All the best. :)
Thanks for the good input.
I have only tried each application one at the time and uninstalled as I saw none of them working at all.
I checked out RBE but there is no information if it supports HD 7770 and the latest revision only seem to state about the HD 6000 series. My system have no onboard graphics card, so might be tricky to reflash incase something goes wrong.
1,568 (0.31/day)
Kolkata, India
Take a backup of your existing BIOS using GPU-Z. Then attempt to load that file in RbE. If it loads up and shows all the information, you are good to go.
Also, have you tried AMD Control Center? Does the manual fan control work from there?
EDIT: Also, was the fan profile always like this i.e. when the card was new? Or this is happening all of a sudden?
AsRock
TPU addict
19,007 (3.01/day)
UK\USA
This^, much better idea than taking the risk of flashing.
Depending on the orientation of the computer and how big the cpu cooler is you might be able to put a fan on the back\top of the card over the PCB, how ever make sure the fan is blowing toward the PCB as putting it the other way would risk the blades hitting parts on the PCB.
85 (0.03/day)
I tried the AMD Control Center part, no as soon the GPU reaches 50C degrees the fans spin at 60% and the carousel of fans spinning up from 20 to 60% in just a matter of seconds as it tries to keep the GPU always at 50C degrees.
I will try the RBE part!
1,568 (0.31/day)
Kolkata, India
Yes I get it. What I am saying is that are you manually able to control the fan speed using Global overdrive settings?
