Fastest graphics card for i7-6700
104 (0.03/day)
Processor Ryzen 5 5600X
Motherboard Asrock B550M Pro4
Cooling Cooler Master 212 EVO Black
Memory 32GB Corsair Vengance XPL
Video Card(s) Sapphire Pulse RX 7800 XT 16GB
Storage 1TB PCIe Gen 4 SSD
Display(s) 32" LG
Case Cooler Master HAF 912 (legacy)
Audio Device(s) Altec Lansing 3-way (legacy)
Power Supply 850W XFX Black Edition
Mouse Logitech
Keyboard Logitech
Software Win10 Home 64bit
As the title suggests, I'd like to ask opinions on what would be the best card to pair with the oldish i7-6700 for QHD (1440p) gaming. CPU being a bottleneck to the card a bit is acceptable because I know every game is different. One game may be CPU limited, the next GPU limited. Thank you.
18,584 (2.68/day)
System Name AlderLake
My previous build was a Z170 i7 6700K build, I had paired it with a 2070 Super, 1440p, some games (like GTA V) there was a CPU bottleneck depending on the game.
Now running a i7 12700K with my 2070 Super.
104 (0.03/day)
Display(s) 32" LG
Mouse Logitech
Keyboard Logitech
Wow. The 2070k seems a little extreme. But at higher rez and a i7-6700k that you could OC, it might make sense to go with that card. I'm stuck with the non-K chip and no OC. Thanks.
Frick
Fishfaced Nincompoop
19,684 (2.86/day)
w
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
How much money are you looking at spending? That's basically the only relevant question, alongside what PSU you have.
pryinglynx.digital
28 (0.03/day)
Vancouver
6700k @ 4.7 with a 1080 @ 2144 no bottleneck in my current machine.
1080 Ti / 2080 might be pushing it, though.
Tatty_Two
Gone Fishing
25,945 (3.75/day)
Worcestershire, UK
Software Win 11 Home x64
A 1080 would possibly be a sweet spot.
104 (0.03/day)
Display(s) 32" LG
Mouse Logitech
Keyboard Logitech
I would like to stay at $300. If not, I'd even consider used as long as I was sure it wasn't a mining card.
Btw, I just remembered. I have a RX 590 that might be available to me used. But I know the owner enough to be sure it wasn't used for mining.
Psu is 500W Antec.
1,978 (1.49/day)
Lithuania
System Name Shizuka
Processor Intel Core i5 10400F
Motherboard Gigabyte B460M Aorus Pro
Cooling Scythe Choten
Memory 2x8GB G.Skill Aegis 2666 MHz
Video Card(s) PowerColor Red Dragon V2 RX 580 8GB ~100 watts in Wattman
Storage 512GB WD Blue + 256GB WD Green + 4TH Toshiba X300
Display(s) BenQ BL2420PT
Case Cooler Master Silencio S400
Audio Device(s) Topping D10 + AIWA NSX-V70
Power Supply Chieftec A90 550W (GDP-550C)
Mouse Steel Series Rival 100
Keyboard Hama SL 570
RTX 2080
843 (0.47/day)
Why not change CPU, can probably get cheap on eBay depending on what your board supports. Then can probably run with any card you like at 1440p.
You might be surprised what you can do with older hardware.
I'm running a 4790k @4.6 with a 6800xt at 4k and get 100 fps in light games like Fortnite and at least 60 in everything I've tried to play.
See no reason to change as a result.
104 (0.03/day)
Display(s) 32" LG
Mouse Logitech
Keyboard Logitech
I'm darn near at the top of the food chain for my board now with the 6700. If I get a 6700K, 7700, or 7700K, I don't think I'd gain enough to make it worth while. And my board doesn't OC. (The board/CPU was originally in a steel industry PC; a hand-me-down)
1,755 (1.19/day)
I've noticed that exact problem (CPU bottleneck) in both GTA V and GTA IV, but it is a CPU bottleneck or a main memory bottleneck?
18,584 (2.68/day)
The only 2 possibilities are a i7 6700K or a i7 7700K..
Ok Im running 6000Mhz DDR5 and this is the CPU usage when playing GTA 5, about 20~30% load.
It's the first time that I'm able to keep my 2070 Super at around 90~99% load in GTA V.
7,071 (4.83/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Audio Device(s) Apple USB-C + Sony MDR-V7 headphones
Keyboard IBM Model M type 1391405 (distribución española)
Psu is 500W Antec.
With these things in mind, the RX 590 is a good deal. If you cannot get it for some reason, buy yourself an RTX 3050, it will play nicely enough with your aging i7-6700 processor. Make sure you got at least 16 GB of RAM too. It will do fine for an entry level, basic gaming PC that has 1080p in mind.
42,723 (6.69/day)
Hawaii, or newer
Toothless
Tech, Games, and TPU!
9,663 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
1080. Buddy of mine is running a 6700 with his and does VR, any game easily. A 1080ti/3060 would be held back.
104 (0.03/day)
Display(s) 32" LG
Mouse Logitech
Keyboard Logitech
Hawaii, or newer
Hawaii? As in the AMD Hawaii architecture? That goes back to the R9-200 series cards. They were still power hogs back then.
dgianstefani
TPU Proofreader
5,116 (2.00/day)
Swansea, Wales
System Name Silent/X1 Yoga
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader/1185 G7
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front, LINKUP Ultra PCIe 4.0 x16 white
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper V3 Pro 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape, Razer Atlas
Benchmark Scores Legendary
Toothless
9,663 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Don't.. do Hawaii. 2xx series are refreshes (280 is a 7950)
42,723 (6.69/day)
Im talking 290X 8G/390/390X.
I'd only say a 6G 7970/280X as bare minimum.
Still very effective considering fermi, 980/980ti, 1080/1080ti, rtx 2080/2080ti, 3080/3090/ti and 4090/ti can all be considered power hogs
1,978 (1.49/day)
Lithuania
System Name Shizuka
RX 590, RTX 3050? Jesus Christ. People get a grip, this isn't Core 2 Quad or some random nearly useless e-waste, this is basically i3 10100F, but a bit older. It will take much faster cards perfectly fine and is still okay even for 4K gaming at 60 fps. It's still perfectly decent CPU.
42,723 (6.69/day)
It is suggested as the mimimum gpu to get.
Toothless
9,663 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
OP was.. looking for fastest tho.
2,671 (0.57/day)
East Europe
System Name PLAHI
Processor I5-10400
Cooling 120 AIO IWONGOU
Video Card(s) PNY QUADRO RTX A2000
Storage Intel 670P 512GB
Case Silverstone Raven 03 (RV03)
Mouse Logitech Triathlon
Keyboard REDRAGON MITRA
Software Windows 11 Home x 64
Well, the RX590 is fine if gaming is the only thing you are interested in and since it comes from a friend of yours may be the way to go.
That said, I wouldn't get it. The whole Polaris generation doesn't have support for many hardware codecs including VP9, which is your Youtube codec. I would go the Nvidia route. Nothing older than GTX1650, since it supports anything without AV1. And GTX1650 Super is only slightly slower than RX580, which is a fine gaming card. Also much less power hungry (the gtx1650 Super I mean). The RTX3050 is a nice little card and it has all the current HW codecs which will means playing a HEVC movie won't kill your CPU :D
Edit: for $300 bucks I guess you can get used RTX2060/ 2060 Super something like that.
478 (0.34/day)
Processor AMD 7600x
Motherboard Asrock x670e Steel Legend
Cooling Silver Arrow Extreme IBe Rev B with 2x 120 Gentle Typhoons
Memory 4x16Gb Patriot Viper Non RGB @ 6000 30-36-36-36-40
Video Card(s) XFX 6950XT MERC 319
Storage 2x Crucial P5 Plus 1Tb NVME
Display(s) 3x Dell Ultrasharp U2414h
Case Coolermaster Stacker 832
Power Supply Thermaltake Toughpower PF3 850 watt
Mouse Logitech G502 (OG)
Keyboard Logitech G512
For a non K 6700 your probably topping out at
1080/2070 non super
5700 non XT/5700XT
Any more and you will hit CPU bottlenecks trying to max the cards out
42,723 (6.69/day)
Youtube doesnt need a gpu to run smoothly
6600/XT bnib now.
