- Jul 31, 2024
- 4 (4.00/day)
Processor | AMD Ryzen 7 5700X |
Motherboard | ASUS ROG Strix B550-F Gaming Wifi II |
Cooling | Noctua NH-U12S Redux |
Memory | 4x8G Teamgroup Vulcan Z DDR4; 3600MHz @ CL18 |
Video Card(s) | MSI Ventus 2X GeForce RTX 3060 12GB |
Storage | WD_Black SN770, Leven JPS600, Toshiba DT01ACA |
Display(s) | Samsung ViewFinity S6 |
Case | Fractal Design Pop Air TG |
Power Supply | Corsair CX750M |
Mouse | Corsair Harpoon RGB |
Keyboard | Keychron C2 Pro |
VR HMD | Valve Index |
Hey all, possibly stupid question.
I'm thinking of using a Meze 300cm cable (99 series) on a pair of JadeAudio JT1 cans. Here's the sticking point: the Meze cable is 3.5mm TRS that terminates in split 3.5mm TS. The cable for the JT1s is 3.5mm TRRS into split 3.5mm TRS. It's of note that the JT1's included cable has an inline mic.
Should I be concerned at all whether the Meze cable is compatible? I'm only using these for unbalanced stereo output on my computer. Just want to make sure I'm not making a $20 mistake here.
