first loop build help
Jaxon111
1 (0.00/day)
I am thinking of starting a water cooled build project and need some help the build is mainly for aestics i don't really care about the actual temps
I want to know if i need
specific water blocks for different tubing size
how much of each water cooled part i need
if my parts are compatible
if i should upgrade anything
my budget was 5000 AUD
i might overclock probably not tho
i have basic knowledge of water cooling but wanted help because of how many customizations there are forgot to add the heat gun and bending block (idk what its called) but there like 100 AUD all together
https://au.pcpartpicker.com/list/hjBkxH
