[Case Gallery] First Modding
P
papito_70
Specs:
Mid-Tower with P4 3.20Ghz, Nvidia 7600GS, 2GB Ram, Asus Mobo, Ultra PSU 500W, WD 160Gb, Lite on DVD-RW and CD-RW.
Mods:
Side window with 2 fans, 1 Blowhole in the top, 1 internal usb with a zalman controller.
Black Painting in the inside.
panchoman
Sold my stars!
9,595 (1.54/day)
Processor Amd Athlon X2 4600+ Windsor(90nm) EE(65W) @2.9-3.0 @1.45
Motherboard Biostar Tforce [Nvidia] 550
Cooling Thermaltake Blue Orb-- bunch of other fans here and there....
Memory 2 gigs (2x1gb) of patriot ddr2 800 @ 4-4-4-12-2t
Video Card(s) Sapphire X1950pro Pci-E x16 @stock@stock on stock
Storage Seagate 7200.11 250gb Drive, WD raptors (30/40) in Raid 0
Display(s) ANCIENT 15" sony lcd, bought it when it was like 500 bucks
Case Apevia X-plorer blue/black
Audio Device(s) Onboard- Why get an sound card when you can hum??
Power Supply Antec NeoHe 550-manufactured by seasonic -replacement to the discontinued smart power series
Software Windows XP pro SP2 -- vista is still crap
really nice mod. also you made a typo on the title :)
3991vhtes
2,785 (0.44/day)
My house.
Processor AMD Athlon 64 3800+ Venice 2.4GHz
Motherboard ASUS A8V-VM SE
Cooling Stock
Memory 1GB DDR400
Video Card(s) DiamondViper Radeon X1650PRO 512MB PCI-e
Storage Seagate 250GB SATA
Display(s) Acer AL2002W 20" LCD Widescreen
Case cheap
Audio Device(s) Creative SoundBlaster
Power Supply 500 watt
Software Vista Ultimate
Benchmark Scores 4.1 Vista index
you spelled modding as mooding
Polaris573
Senior Moderator
4,268 (0.60/day)
Little Rock, USA
Processor LGA 775 Intel Q9550 2.8 Ghz
Motherboard MSI P7N Diamond - 780i Chipset
Cooling Arctic Freezer
Memory 6GB G.Skill DDRII 800 4-4-3-5
Video Card(s) Sapphire HD 7850 2 GB PCI-E
Storage 1 TB Seagate 32MB Cache, 250 GB Seagate 16MB Cache
Display(s) Acer X203w
Case Coolermaster Centurion 5
Audio Device(s) Creative Sound Blaster X-Fi Xtreme Music
Power Supply OCZ StealthXStream 600 Watt
Fuse-Wire
855 (0.14/day)
Scotland, Far away from normality as possible
System Name The Box
Processor DualCore AMD Athlon 64 X2 2300MHz (11.5x200) 4400+
Motherboard AsRock N 68-S
Cooling Basic 90mm fans
Memory OCZ XTC Platinum 2GB DDR-2 800 SDRAM
Video Card(s) ATI Saphire x1650 Pro Series
Storage Maxtor 6L300R0 (300GB) Maxtors S (250GB)
Display(s) 19" LCD CTX
Case EYE-T
Audio Device(s) Realtek ALC650 @ Intel 82801DB ICH4 - AC'97 Audio Controller [B-0]
Power Supply 600W colors-IT super quiet
Software Microsoft 7 Ultimate
very nice, especially the cables
Deleted member 24505
theres 2 d's in modding :p
system is ok,not bad for a first stab. :)
sirrep74
24 (0.00/day)
sterling, illinois
Processor amd sempron 3100+
Motherboard msi ms 7142
Cooling currently air thinking about going to water
Memory 2g pony
Video Card(s) geforce 6200
Storage 1 40g maxtor(os),1 80g(everything else)
Display(s) 1 15" e1514 lcd
Case stock e-machine w3105 w/a self modded window
Audio Device(s) none
Power Supply 400w power king w/loomed wire
Software windows xp
good job
giving you a seven because the wire loom is a pain the the butt to do
<a href="http://www.speedtest.net"><img src="http://www.speedtest.net/result/188763362.png"></a>
234 (0.04/day)
Brasil - São Paulo - São Caetano do Sul
System Name NOS
Processor Core Extreme QX6850
Motherboard Maximus Formula
Cooling VANTEC STING RAY CPU Block, 3x120mm fan's with Radiator, Seltz 1200lt/h
Memory 4GB Crucial Ballistix 1066MHz 5-5-5-15
Video Card(s) PCI-express ATI Radeon HD2900XT 1GB DDR4 512bits
Storage 5 HD's 160GB SATAII Seagate ST3860815AS 7200.10
Display(s) LG 22'' model 22LS4R
Case 3Rsystem's R810 with mod's for watercooler system
Audio Device(s) Supreme FX II
Power Supply ULTRA X3 1000W modular PSU
Software WINXP PRO SP3 x86
are u using a Flex cable system in PSU, if u are using it u can remove the black tubes ( possible sleeving kit ) from the psu cables and hiden the
see and vote in my case http://www.techpowerup.com/gallery/1034.html
bye ;)
387 (0.06/day)
Los Angeles, CA
Processor Intel i7 4790K
Motherboard ASRock z97 Extreme
Cooling NZST Kraken
Memory 16gb
Video Card(s) 2x EVGA GTX 1080 FTW2
Storage Samsung 950 EVO
Display(s) 28'' Samsung
Case NZXT H700i
Power Supply EVGA 850G2
Since you have a micro ATX mobo you should try to utilize the cutouts in the motherboard tray to help manage your wires a bit.
5,147 (0.76/day)
AZ
System Name Thought I'd be done with this by now
Processor i7 11700k 8/16
Motherboard MSI Z590 Pro Wifi
Cooling Be Quiet Dark Rock Pro 4, 9x aigo AR12
Memory 32GB GSkill TridentZ Neo DDR4-4000 CL18-22-22-42
Video Card(s) MSI Ventus 2x Geforce RTX 3070
Storage 1TB MX300 M.2 OS + Games, + cloud mostly
Display(s) Samsung 40" 4k (TV)
Case Lian Li PC-011 Dynamic EVO Black
Audio Device(s) onboard HD -> Yamaha 5.1
Power Supply EVGA 850 GQ
Mouse Logitech wireless
Keyboard same
VR HMD nah
Benchmark Scores no one cares anymore lols
clean, and nice, but 5 cause the of the case, put that in a better case and you'll get a 9.
