First PC in 12 Years!!
PsxMeUP
4 (0.00/day)
The land of darkness and gloom
Ok, not counting laptops I'm considering getting a real computer for the first time in over 12 years! It will mainly be for gaming and processing (rar, photoshop, 3D Studio Max, Unreal Ed, video converting, multitasking, etc.). I plan to overclock the GPU and CPU and get 2 video cards in SLI/Crossfire in a couple of years, but not now. So here's what I plan on getting.
Processor: Intel Core i5 3570K 3.4GHz BOX
GPU: Gainward GeForce GTX 680 Phantom 2GB DDR5 PCI-E BOX
Mobo: Asus P8Z77-V
RAM: Corsair DDR3 2x4096MB 1600MHz CL8.0 XMP Vengeance
Case: Corsair Carbide Series 400R black
PSU: Corsair TX750V2 750W
I'm contemplating getting the Asus Sabertooth Z77 over what I got now, or something else, but don't know what's good. I've been conditioned to think a motherboard "has to be ASUS," but you know... 12 years is a long time; things might have changed! So is this ok? Will I need a better PSU when I start overclocking and get a second GPU? Is the CPU any good? I think I got all the Ivy Bridge / Z77 / PCI-E 3.0 crap figured out but need things verified by people who kept up with all this stuff. I am willing to spend a $100 more to get better stuff.
922 (0.16/day)
London, UK
Processor AMD FX 8350 Black Edition @ 4.2Ghz
Motherboard Gigabyte 990FXA-UD3 Rev 4.0
Cooling Corsair H100i
Memory Samsung Green 16GB 30nm 1600Mhz DDR3
Video Card(s) XFX HD 7950 DD 3GB @ 850/5000Mhz
Storage 240GB Intel 520 SSD + 2TB Seagate Barracuda
Display(s) ASUS PB278Q 27" QHD
Case Fractal Design R5 Black
Power Supply Seasonic Platinum 760W
Mouse Corsair Raptor M40
Keyboard Corsair Raptor K50
yep looks good to me. would serve you another 12 years just fine :)
TheMailMan78
Big Member
22,599 (3.59/day)
'Merica. The Great SOUTH!
Don't like the PSU. Look for a Seasonic X series.
522 (0.09/day)
If anything, maybe get the 680 with more memory(4GB) on it if this computer will be kept for even half as long as your last one. We should hopefully be seeing more affordable displays with higher resolutions than 1080i very soon(like Catleap ones) , which would benefit from more GPU memory(plus you do the photoshop stuff too).
Edit: That's assuming you'll be getting a new display sometime in the next few years
PsxMeUP
4 (0.00/day)
Everything looks good
What about Hard drive? A 120gb SSD would work nice with that setup
I've got too many HDDs as is: 3TB spread over 4 drives. I will get a SSD but later. I want to see if they make a difference so I want to start with normal disks then get an SSD to see the improvement. Plus I'm a little cautious. I heard there are better options than SSD and I don't quite understand everything (RAM Flash vs Flash SSD).
@TheMailMan78, I've changed my PSU choice so many times I'm fed up of changing it. I started with a BeQuiet Purepower L8 730W, then a Cooler Master, then was dead set on an XFX, now Corsair... It's just a PSU. I want it to get the job done and stay silent!
TheMailMan78
Big Member
22,599 (3.59/day)
Just a PSU? The PSU is the most important part of any build. THE MOST IMPORTANT. Seasonic X series is one of the highest rated PSUs on the market and it will be quieter then that 750TX by far. The "X" only turns its fan on when its under heavy load. The 750TX ALWAYS runs and has REALLY bad power ripple. I owned a 750TXv1 for years.
9,899 (1.73/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
The be Quiet he mentioned is built on a Seasonic board I think so is a good option too.
I'd go for which ever is cheapest of the two.
By the by SSDs make HUGE differences to boot up times and general system responsiveness, load up for things that are not even on the SSD is faster by a tad thanks to this.
Windows explorer FLIES with an SSD, everything will open instantly.
You can get 550MB/s ones for cheap now ( 120gb is around £70 in the UK )
I had a 120MB/s SSD and my boot time went from 2 minutes or so to a fully usable Desktop to 25 seconds. And like I said everything was more responsive ( not a placebo effect I promise!) Hell I'd even drop the 680 and get a 670 and overclock. Then get a SSD with the money saved. The 670 is right up the 680s arse the difference is negligible when both are overclocked.
Black Haru
1,567 (0.30/day)
Indiana
If you don't have an ssd, don't bother with the rest. Why run a top of the line computer when all your software is on an outdated drive.
5,975 (1.29/day)
Hi! I'm from the Internet
System Name Selene / Yoda
Processor Fx 8350 @ 4.4 / Phenom II x6 1090t @ 3.6
Motherboard Gigabyte 990FXA-UD3 r4.0 / Gigabyte 890XA-UD3
Cooling H100i / Xig Dark Knight
Memory 4x 8gb G.Skill Snipers / 4x 4gb G.Skill Ares
Video Card(s) Gigabyte R9 290x / XfX DD & VisionTek HD6850's C'fired
Storage 256gb ssd, 2x 2tb Wd Blacks & 1x 1tb Wd black / 1x 1tb
Display(s) Dell Ultra Sharp 2408 WFp / Hp w2207
Case Raidmax Vampire / Chieftec Alum. Dragon Blue
Audio Device(s) Onboard Hd Audio / Onboard Hd Audio
Power Supply Corsair TX 850 watt / Corsair TX 750 watt
Mouse Logitech G500s
Keyboard Corsair Strafe
Software Win 10 pro / Win Vista Home prem. 64 bit
Benchmark Scores What are benchmarks anyway?
What kind of display do you have? Are you still on a crt? (nothing to be ashamed of thats for sure I still use one for gaming)
1,226 (0.25/day)
Omaha, NE
System Name Graphics Card Free...
Processor Ryzen 5 5600G
Motherboard MSI B450 Gaming Plus MAX Wifi
Cooling Cryorig M9a w/ BeQuiet! PureWings 2 ~ 92mm
Memory Corsair Dominator Platinum DDR4 3200 ~ 16GB(2x8GB)
Storage Samsung EVO 870 SSD - 1TB
Display(s) AOC 24G2
Case Cardboard...
Power Supply eVGA SuperNova 550w G3
Mouse Logitech t400 Zone Touch Mouse
Keyboard IBM Model "M" Keyboard
Software Manjaro ~ KDE Plasma
Benchmark Scores She's a Runner!
Agree on Mailman's option. A Seasonic X series is a solid performer. I have them in service at the office and they've been very reliable. I personally go for the X650 but you might need another 1 or 200 watts with your plans. The San Ace fan in the X650 is worth the cost of admission alone.
If you're looking for an SSD, I don't keep up with the latest offerings, so I don't know if there are new SSD's available that are higher rated, but we've been very satisfied with the Samsung 830 series. Excellent performers and we haven't run into a single hitch on any of the dozens we own.
With the Samsung 830's, I've also been using their low profile DDR3 1600 memory in my own rigs...quite pleased. Very overclockable...and forgiving.
Best,
LC
6,743 (1.40/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
All good advice so far.
Asus does make good motherboards but they arn't the only one. Overclocking results are 90% processor and 10% motherboard. I really like the temp sensing ability of the sabertooths though.
231 (0.05/day)
Ohio
System Name Cogito Ergo Switch
Processor i7 3930K @ 4.8Ghz
Motherboard Asus Rampage IV Extreme
Cooling Custom Water (CPU/MB/GPU Blocks, 420+240rads PP)
Memory 16GB G.Skill Ripjaws Z 2133 9-11-10-27 @ 2380 9-10-10-28
Video Card(s) EVGA GTX670 FTW 2GB SLI @ 1344core/7648mem + EVGA 650Ti PhysX
Storage Samsung 830 256GB SSD (Boot) + 1TB WD10EZEX (Games/Apps) + 1TB WD10EALX (Prog) + 2x 320GB WD/HGST
Display(s) Dell U2412HM + U2312HM + 2x P2212Hbe + Viewsonic 21.5" 1680x1050
Case NZXT Switch 810 White - MODDED
Audio Device(s) Creative X-Fi Titanium HD PCI-Express
Power Supply NZXT HALE90 850W - Custom Sleeved Cables (White, No Heatshrink)
Software Windows7 Pro x64
I also think that the Samsung 830 drives are the best option, with top of the line performance but also the reliability not previously associated with such performance (think OCZ). In-House Controller, Synchronous/Toggle-NAND 25nm Flash, and the best housing I have seen on a drive = ultra-reliable and ultra fast. Unlike the Sandforce drives, the specs Samsung posts aren't "theoretical", and in fact are rather conservative by most tests; and again, unlike the majority of drives, it is fast regardless of the data type. I believe that the Intel 520 drives are the only better option, but you can get a 256GB Samsung for not much more than a 120GB Intel! And the difference is a few percentage points at most, performance wise, but I can't speak to long term reliability.
Also, NZXT HALE90 PSUs are worth a look. JohnnyGuru tests put them up there with Seasonic and above Corsair/CM/Antec... I feel that they are extremely underrated and far too often overlooked.
Also, you may find that Z77 Board prices change a bit with the new Maximus V Formula and Extreme launching soon, driving prior "top dog" prices down to remain competitive, bc while I am not a fanboy of any company (besides BMW), I have yet to hear anything showing that Asus does not have the best feature sets on their MBs out of all the players; some may add extra SATA3 ports with Marvell controllers (yuck) or USB3.0 ports or whatever, but I have yet to see a better mix, on average, than Asus. There are always exceptions, but I have put my money where my mouth is.
7,176 (1.04/day)
Processor AMD Ryzen 7 7700 Raphael \ i5-1135G7 Tiger Lake-U
Motherboard ASRock B650M PG Riptide Bios v. 2.02 AMD AGESA 1.1.0.0 \ Lenowo BDPLANAR Bios 1.68
Video Card(s) Asus GeForce RTX™ 4070 Dual OC GPU: 2325-2355 MEM: 1462| Intel® Iris® Xe Graphics
Display(s) LG UltraGear 27GP850-B 1440p@165Hz | LG 48CX OLED 4K HDR | Innolux 14" 1080p
Software Win11 Pro 23H2 UK | Arch (Fan)
if you r going to have this system for a long long time why not get the Asus P8Z77-V PRO/THUNDERBOLT?
u get onboard Intel Thunderbolt solution ino it's not that used yet but i think it will with time bcs it's an awesome solution for external drives with speeds up to 10gbps per channel and u can connect up to 6 devices on it.
for a little more info about Intel Thunderbolt go here: https://thunderbolttechnology.net/products
this board here would be the board i will take if i was going to get the Z77 chipset that's not ripping off my wollet for getting the Asus Maximus Formula V i so bad wants :( (i just don't have like 430usd laying around for a board)
846 (0.17/day)
Nairobi, Kenya
Processor Intel Core i7-14700K
Motherboard ASUS ROG STRIX Z790-H
Cooling DeepCool AK500 WH
Memory Crucial Pro 32GB Kit (16GB x 2) DDR5-5600 (CP2K16G56C46U5)
Video Card(s) Intel ARC A770 Limited Edition
Storage Solidigm P44 Pro (2TB x 2) / PNY CS3140 2TB
Display(s) Philips 32M1N5800A
Case Lian Li O11 Air Mini (White)
Power Supply Seasonic Prime Fanless Titanium 600W
Keyboard Dell KM714 Wireless
Software Windows 11 Pro x64
All true one of the best upgrades i have ever done in my computer i got one now its two weeks old and i love it its a Seasonic X-660, and the power protection features are 6 unlike most current PSUs have only 4 or less, Solid Performer for real and quiet as hell, i did research for 6 months and by the first few days everything pointed out to Seasonic X Series as a solid PSU, now i own one and i highly think I'll try and be loyal to the Seasonic brand for any other personal build for a very long time with their PSU i feel it made my build complete with satisfaction. With Seasonic X Series I'm finally in the right track I'm finally found, I found peace.
PsxMeUP
4 (0.00/day)
This has been very enlightening, thanks everybody. I might actually go with a GTX 670 instead of 680 since they are virtually identical. I'll use the money saved to improve the PSU and Motherboard. I wouldn't mind getting a 4GB GTX 670 but the only one available from my store is the Zotac GeForce GTX 670 4GB. It's really hard to find reviews on it and I'm not impressed with the base and OC specs. I'll get a single 1920 x 1080 flatscreen monitor so maybe 4GB is a bit overkill on a single card.
7,176 (1.04/day)
on SLi or Crossfire it don't double ur memory only gpu :laugh:
512 (0.10/day)
The oem for the Corsair AX series is Seasonic. I did alot of research on PSUs and ended up with the AX650. The fan turns off at idle and is dead silent under stress. And the best part is the 7 year warranty.
5,976 (1.06/day)
Cybertron aka Canada
Processor Intel Core i5-3570K
Motherboard Asus P8Z77-V Pro
Cooling Noctua NH-D14
Memory 8GB Mushkin Blackline DDR3-1600
Video Card(s) Gigabyte GTX 670
Storage Intel 520 60GB, Seagate Barracuda XT 2TB
Display(s) BenQ 24" XL2420T
Case Corsair 550D
Audio Device(s) Sennheiser HD600, Audeze LCD-3F, Mytek Stereo 192 DSD, La Figaro 339, Burson HA-160, Geek Pulse X
Power Supply Corsair AX650
Mouse steelseries Sensei MLG edition
Keyboard Cooler Master QuickFire Pro
Software Windows 7 64-bit Home Premium
you over spec'd it for gaming.
you should be going with a Quadro card and taking advantage of 10-bit monitors. I would change the processor to a 2600k. you should have no less than 16GB of ram for content creation. some Adobe products take advantage of SSD so make sure you have a 120GB to boot and a scratch disk.
Frick
Fishfaced Nincompoop
19,153 (2.84/day)
Piteå
System Name White DJ in Detroit
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
I'd go with either 1 8GB stick or even better 2 x 8GB sticks.
5,976 (1.06/day)
Case Corsair 550D
8GB is enough for most people however Photoshop and some other applications can use 16GB+ if you want them too. plus you can create a ram disk.
9,871 (1.88/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
yeah, the bigger memory is better
especially when you do multitasking :toast:
846 (0.17/day)
Nairobi, Kenya
That's why i went straight to the source,"Seasonic"
Frick
19,153 (2.84/day)
Piteå
Just saw this and this is pure BS. Read this here review. Did you notice the "V2" part in the name? THat indicates it's a new unit. Ripple is excellent, and the fan is quiet.
EDIT: Also, "THE MOST IMPORTANT" doesn't mean you have to go for the absolute best.
