First results for delidded Ryzen 7000 series direct die cooling by Der Bauer
576 (0.33/day)
Florida
Processor 5800x3d
Motherboard MSI Tomahawk x570
Cooling Thermalright
Memory 32 gb 3200mhz E die
Video Card(s) 3080
Storage 2tb nvme
Display(s) 165hz 1440p
Case Fractal Define R5
Power Supply Toughpower 850 platium
Mouse HyperX Hyperfire Pulse
Keyboard EVGA Z15
Believes AMD made the IHS too thick and his results seem to back that up. 20 degree difference from stock.
Maybe AMD should think about a factory delidded chip...
17,777 (4.67/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710
20 celsius drop holy shit. lmao
doesn't look like it is as easy as delidding in the past though.
@W1zzard you should work with this guy someday since you both in Germany.
Deleted member 185158
He'd have to test a bunch of thicknesses to have that conclusion.
The plate is there so AMD can sell 200w chips and you can just get a nice air cooler to slap on it. Or we'd all have to buy 200$ waterblocks from EK. And a de-lid tool also. And some LM probably....
Aw F'it a NH D15 will suffice with simple thermal paste.
9,340 (5.03/day)
Louisiana
Keyboard G710+x3
People delidding intel 79..x series saw the same 20c drop in temps so there's nothing really earth shattering beside he didn't messup the chip delidding it.
52 (0.01/day)
I have a Xeon E5-2696 v4, 2200MHz 22 core processor. Works on Huananzhi X99-TF mainboard with 4 piece Samsung 16GB 2400MHz Reg Ecc DDR4 memory total 64 GB. Without any extra trick, it gets 17168 points on Cinebench with a Thermaltake Frio OCK Snow Edition 240 Watt air cooler, works within real cool temperature margin lower than the delidded Ryzen 7000 AMD processor on the video.
So what the all extra work for is? Money waste, including buying expensive AMD processor, with expensive Asus mainboard with new 2 piece expensive DDR5 rams. I have bought my Xeon E5-2696 v4 one month ago from eBay $173, now it is $178 lately.
576 (0.33/day)
Florida
Processor 5800x3d
Video Card(s) 3080
Storage 2tb nvme
Keyboard EVGA Z15
I have a Xeon E5-2696 v4, 2200MHz 22 core processor. Works on Huananzhi X99-TF mainboard with 4 piece Samsung 16GB 2400MHz Reg Ecc DDR4 memory total 64 GB. Without any extra trick, it gets 17168 points on Cinebench with a Thermaltake Frio OCK Snow Edition 240 Watt cooler, works within real cool temperature margin lower than the delidded Ryzen 7000 AMD processor on the video.
I mean sure if you want to run blender all day that's a good option.
Didn't they not solder that IHS?
Right, but its just the start. I'm sure that will be covered in time.
That's his point in the video, AMD did it for convenience not performance.
ir_cow
4,867 (0.81/day)
USA
regardless of being delid, you shouldn't exceed 1.3 V for long durations. So the limit is 5.5 GHz, or about 100 Mhz more. Of course much cooler running.
12,148 (1.72/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
Intel is flexing their CPU causing overheating, if the thicker IHS doesn’t prevent flexing it serves no purpose, if it prevents flexing for 98% of users it’s worth it overall.
18,584 (2.65/day)
System Name AlderLake
A i7 12700K gets well over that and uses less power, ofcourse if you got cheap power where you live it isn't that bad.
Count von Schwalbe
Nocturnus Moderatus
3,374 (2.76/day)
Knoxville, TN, USA
I believe a lot of the thickness comes from the need of AM4 cooler compatibility, as the new die and socket are much shorter.
They've been doing it for convience since socket 754 then... this would mark the first change in the plates design in about 2 decades.
Since the chip is still 40mms, why the change to LGA is my ultimate question.
5,399 (3.69/day)
Colorado, U.S.A.
Software Windows 11 Home
Not so keen on relying on anodizing as an insulator.
stinger608
11,250 (1.88/day)
Wyoming
System Name 2023 Ryzenfall
Processor AMD Ryzen 5800X
Cooling SilverStone AH240 AIO
Case Corsair Air 540
Audio Device(s) On board
807 (0.64/day)
People's Republic of Banania
Processor Threadripper 3955WX
Motherboard M12SWA-TF
Cooling Arctic Freezer 4U SP3
Memory G.Skill Trident Z DDR4-3733 (2x8GB)
Video Card(s) 5700XT + 3x RX 590
Storage A lot
Display(s) ViewSonic G225fB
Case Corsair 760T
Audio Device(s) Sound Blaster Z SE
Power Supply be quiet! DPP12 1500W
Keyboard IBM F122
Software 10 LTSC
-20C... remember Coffee Lake? delid+undervolting was the only way to run these at reasonable temps if you were to overclock by a single MHz.
cadaveca
My name is Dave
17,232 (2.49/day)
My review package thing from Intel had a coffee mug in it. the mug was broken. Given the platform and your thoughts, that is now comical. :p
