First Time overclocking Memory
UniqueEab
3 (0.05/day)
First Time overclocking Memory and first time posting any where on any Forum need your opinion and support.
as far as my understanding goes i have got a good latency score on AIDA but i was wondering if it is good at all ??
i just raised my DRAM voltage a bit for stability and my setup is as follows:
i9-11900k
z590 MSI MPG
4400mhz CL19 Patriot - (you people call it cheap samsung b-die ) PVS416G440C9K
i never touched my subtimings so i was wondering if i can get some advice
115 (0.12/day)
Processor Intel i5 9400f
Motherboard MSI Z390 Gaming Plus
Cooling SilentiumPC Fera 3
Memory 2x 8GB Corsair Vengeance LPX 3200 16-18-18-36
Video Card(s) MSI GTX 1660 Super Ventus XS OC
Storage 500 GB Kingston A2000; 1 TB Kingston A2000; 1 TB HGST Travelstar
Display(s) AOC 24G2U
Case SilentiumPC Signum SG1
Audio Device(s) Creative Pebble Plus; Logitech G533
Power Supply beQuiet Systempower 9 500W
Mouse Logitech G403 Hero
Keyboard HyperX Alloy Origins (Red)
tFAW and TRFC can definitely go lower and tREFI can be raised. Those should be the best improvents. You can take a look at my cheap samsung C-Die timings. Primaries and frequency is obviously worse, but secondaries and tertiaries should be a decent comparison.
edit: Also for latency checking I recommend the Intel Memory Latency Checker
UniqueEab
3 (0.05/day)
Thank you so much.
3,275 (2.14/day)
System Name Mean machine
Processor 12900k
Motherboard MSI Unify X
Cooling Noctua U12A
Memory 7600c34
Video Card(s) 4090 Gamerock oc
Storage 980 pro 2tb
Display(s) Samsung crg90
Case Fractal Torent
Audio Device(s) Hifiman Arya / a30 - d30 pro stack
Power Supply Be quiet dark power pro 1200
Mouse Viper ultimate
Keyboard Blackwidow 65%
I haven't touched 11th gen so I don't know what's going on with those but with a 10900k i was hitting 66k read / write and 36ns latency on AIDA. 4400c16 ram.
Max your trefi to 65535 and try to raise ram frequencies, is 3600 all you can get out of it?
UniqueEab
3 (0.05/day)
Those are my new Final results after following the DDR4 Overclocking guide ( https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md ).
Do you guys think i can go any further.
On Gear 1 im unable to raise the frequency any higher unfortunately i remember before i booted once a couple of months ago at 4000 Gear 1 but never again im not sure if there is something that i can to get better results or if i drop my latency a bit more.
