FIVR things are greyed out.
algorist
3 (0.00/day)
Even if I unlocked locks in bios and windows features were disabled
like CFG Lock, Overclocking Lock, intel virtualization technology, Hyper-v, ...
I'm using LG gram 15zd90q-gx56k
I5-1240p
Windows 10
How do I do then?
Here're my screenshots for the main window, FIVR, TPL.
unclewebb
8,123 (1.33/day)
Intel has removed voltage control from almost all 12th Gen mobile CPUs. You can undervolt the ultra expensive 12900HK and the HX series but that is about it.
Post a screenshot of the ThrottleStop FIVR window.
algorist
3 (0.00/day)
I added screenshots for main, FIVR, TPL windows.
Do you mean there's no way to undervolt or overclock things in my case?
Sorry for the inconvenience, but please confirm again because of my bad English.
unclewebb
8,123 (1.33/day)
Thank you for posting some ThrottleStop screenshots.
ThrottleStop used to show Locked at the top of the FIVR window for 11th Gen and previous CPUs. It was easy enough to go into the UEFI and toggle CFG Lock off to unlock voltage control.
With 12th Gen, CPU voltage control is Not Available. ThrottleStop can only read the voltages. It is not possible to unlock or change any of the voltages. You can only change the voltage if you have a 12900HK or a 12th Gen HX processor.
There is no software available to change the voltage of your Core i5-1240P.
Using ThrottleStop to change all of the turbo ratios to 44 does not work. These CPUs are locked. You cannot run an all core overclock using the maximum 44 multiplier on a locked CPU. The CPU will ignore your request.
algorist
3 (0.00/day)
Thank you for your detailed descriptions.
I understood but wanted to find a way to undervolt or maximize clock thing.
But I finally can give up on this after read your reply.
Thank you again.
