**FIXED** MSI RX 570 4GB issues
4,520 (0.70/day)
Perth AU
Processor Intel Core i9 10980XE @ 4.7Ghz 1.2v
Motherboard ASUS Rampage VI Extreme Omega
Cooling EK-Velocity D-RGB, EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
Memory G.Skill Trident Z RGB F4-3000C14D 64GB
Video Card(s) Asus ROG Strix GeForce RTX 4090 OC WC
Storage M.2 990 Pro 1TB / 10TB WD RED Helium / 3x 860 2TB Evos
Display(s) Samsung Odyssey G7 28"
Case Corsair Obsidian 500D SE Modded
Power Supply Cooler Master V Series 1300W
So i got given this card as it had issues ex-mining GPU <, so here are the issues it has, it will post 5% of the time the rest of the time it wont have any video, there are no artifacts in windows or games but it will last about 5-10 seconds with load and then it will gray screen, so any ideas or is this thing had it lol? the bios on the card no idea if its correct or not i did try other bios's this one seem to work the others would lock windows up.
GPU-z stress test makes the screen go green lol
4,520 (0.70/day)
Perth AU
No love for the RX 570
9,629 (3.28/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Most likely it does not have the correct BIOS. If you don't provide the details of the card such as the model or what does the sticker on it says I doubt anyone can help you with that. I am always baffled as to how do you people expect anyone can help you if you provide next to zero information.
Bit of advice for the future, avoid cards that have been used for mining. I know the prices are very tempting but you never know if you will end up with a useless piece of junk.
1,618 (0.28/day)
dont (good) miners alter their bios to use very specific clockspeeds & memory voltages/timings/etc? too low memory voltage would be unstable for games but could be fine for mining, you might as well flash an official bios just to be sure
since you have a known mining card, it's of use to experiment with it, i wish review sites would do this
4,520 (0.70/day)
Perth AU
Card has been flashed with the correct bios also i got the card for free!
The card doesn't post its very hard to get to post so maybe its not bios related .
Just an update i fixed the issue....
4,520 (0.70/day)
Perth AU
ill leave what i did to fix it here just in-case someone runs into this issue, most likely a miner.
I removed the cooler and small heatsink over the VRMs, re-did the paste on the die and put it back together, I then re-flash the card using cmd and ati flash, i force flashed it with the correct bios over 20x times, for some reason the bios chip had issues and the bios just wasn't being flashed correctly, most likely a issue with the bios chip re-flashing it over and over fixed any corruption it had, after doing this the card posted and pasted 24 hours of stress testing with no issues.
43,281 (6.74/day)
Put in the title FIXED please.
Thank goodness you know what you are doing as those who come here haven't a friggin clue
4,520 (0.70/day)
Perth AU
I would but I'm unable to edit posts older than a day for some reason..
