jb3nny
- Oct 23, 2006
- 97 (0.01/day)
- Kingston - Ontario
Processor | Amd 64bit 939 3000 @ 2.1Ghz |
Motherboard | Gigabyte Mobo GA-K8NSC-939 |
Cooling | A lot |
Memory | 2x 512 OCZ |
Video Card(s) | X800 AGP 256 Pro Vivo @ 16 Pipes |
Storage | 320 Gigz of Maxtor IDE Ultra Dma Harddrives |
Display(s) | 22" Dell Widescreen.. Yipee!! |
Case | Chemming Silver w Window |
Audio Device(s) | Sound Blaster Audigy Platinum Soundcard |
Power Supply | 430W Antec PurePower |
Software | WinXP SP2 / Ubuntu 7.04 Fiesty! |
Help!!!
I flashed my card to the hisx800xt just to mess around and did a force flash it rebooted and i had wierd in game stuff so i rebooted and reflashed to modded x800 bios that i had been using. No probs ... then i rebooted after some more gaming only to find that it was hanging after verifying the dmi pool. The only way i could get it to boot to windows was to change the boot order. Now that only worked for like 2 boots. So i reflashed my mobo bios with the gigabyte flash tool. That was a success so i restarted... now i get BSOD on reboots right before i hit the log in screen... Its a page fault error....page fault in non paged area.... i cant boot into safe mode or regular windows or with last known good config. I cant even do a windows repair install as it BSOD. Also i did a fixboot and fixmbr still nothing. I read that this BSOD error is usually caused by bad memory - i reseated it booted with only one diM for both and i dont think its my ram. Could it be that i fried my vid cards ram or that it failed. Any help is appreciated as im royally fooked. Also i reseated all my connects in my case.
HELP!!! Thanks.....
HELP!!! Thanks.....
