Fluctuating FB usage at Idle GPU
Boy_saber
1 (0.00/day)
When idle the FB usage fluctuate like this.
Is it normal for the card and should I worry?
43,381 (6.75/day)
First what hardware, 2nd what is FB?
3 why are you using beta software?
4 use latest stable release, not beta to test and come back.
95Viper
Super Moderator
13,152 (2.21/day)
what is FB
FB usage is the frame buffer usage.
At OP... the Frame Buffer usage looks normal for idle... However, you put the circle around the VID usage.
Frame Buffer (FB) usage is above the circled VID usage.
Those values are measured in percentage.
43,381 (6.75/day)
Doesnt the win gui require acceleration now?
