Force3D Ushers Forth HD 4870 SKU Specifications
Navin
8 (0.00/day)
Force3D has, today, announced the specifications of its first SKU powered by AMD's HD 4870 GPU. A core speed of 750 MHz, paired together with 512 MB of GDDR5 memory running at a frequency of 3.6 GB/s are the order of the day, whilst technicalities such as the presence of 800 stream processors and a 256-bit memory interface prove commonality with AMD's HD 4850 offering. Using Extreme settings, Force3D's own 3DMark Vantage results claim that their HD 4870 iteration has a speed advantage of 58% over the HD 3870X2.
993 (0.15/day)
Los Angeles...U.S.A
Processor i7 920
Motherboard EVGA X58
Cooling eight 120mm fans, Swiftech GTZ cpu block, 3 120mm radiator, MCP655 pump, primochill tubing
Memory 6 gig G-Skill DDR3 1600
Video Card(s) GTX 285's (SLI)
Storage 500GB Western Digital
Display(s) 3 Asus 23 in inchers
Case Lian Li A77B
Audio Device(s) on board 7.1
Power Supply Corsair 1000
Software win 7 64
Looks sweet... :) 58% faster than X2? If that is indeed correct, this card will become a must have item.
Gambit_ZA
12 (0.00/day)
South Africa
Processor Intel E6750
Motherboard Intel DP35DP
Cooling Stock
Memory Corsair 2GB Matched Pair - Low Latency (DDR2 800Mhz)
Video Card(s) ASUS 8800GTS 320MB
Storage Seagate 250GB 7200rpm 16MB cache
Display(s) LG 204WT 20''
Case Raidmax Smilodon
Audio Device(s) Stock
Power Supply Coolermaster 650W Extreme Power
Software Vista Ultimate (32bit)
InnocentCriminal
Resident Grammar Amender
6,477 (0.90/day)
System Name BeeR 6
Cooling Corsair H100i
Case Fractal Design Arc Mini
Power Supply Corsair HX750W
Welcome to the forums Navin!
W1zzard
Administrator
27,569 (3.70/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
If you didn't know (I didn't): Force3D is the ATI brand of Inno3D
InnocentCriminal
6,477 (0.90/day)
System Name BeeR 6
Your welcome!
Bad pun. ;)
ShinyG
185 (0.03/day)
Romania
System Name My Computer
Processor Intel 2600K@4.4Ghz
Motherboard ASUS Z68
Cooling Scythe Mugen
Memory 2x4Gb
Video Card(s) Sapphire HD7850
Storage 1xA-Datat SSD 64GB; 1x WD RE3 500GB; 1x Maxtor 750GB
Display(s) Dell Ultrasharp 2005FPW
Case Antec 900 + cable management + Zalman fan ctrl
Audio Device(s) Asus XONAR DS
Power Supply Corsair 520HX
Software Win 7 Pro
Benchmark Scores I've fried plenty o' parts when not OCing. Need to start doing it again to avoid problems...
Something doesn't sound right about that bandwidth: 3.6GB/s
I think the 3870 pumps out something like 72GB/s, so if we're to believe this article, the 4870 has a memory bandwidth of a Radeon 9250 with a 64bit memory controller...
3,942 (0.62/day)
System Name Widow
Processor Ryzen 7600x
Motherboard AsRock B650 HDVM.2
Cooling CPU : Corsair Hydro XC7 }{ GPU: EK FC 1080 via Magicool 360 III PRO > Photon 170 (D5)
Memory 32GB Gskill Flare X5
Video Card(s) GTX 1080 TI
Storage Samsung 9series NVM 2TB and Rust
Display(s) Predator X34P/Tempest X270OC @ 120hz / LG W3000h
Case Fractal Define S [Antec Skeleton hanging in hall of fame]
Audio Device(s) Asus Xonar Xense with AKG K612 cans on Monacor SA-100
Power Supply Seasonic X-850
Mouse Razer Naga 2014
Benchmark Scores FFXIV ARR Benchmark 12,883 on i7 2600k 15,098 on AM5 7600x
Does that say 512mb? ...WHAT?
Lame.
Navin
8 (0.00/day)
The figure of 3.6 GB/s they mention, is referring to the frequency of the memory, not the bandwidth.
Force3D, as per the PR linked to the story, are quoting that the bandwidth is 107 GB/s on the 4870 SKU, versus 72.96 GB/s on the 4850 SKU.
I hope this helps.
1,491 (0.21/day)
66 feet from the ground
System Name 2nd AMD puppy
Processor FX-8350 vishera
Motherboard Gigabyte GA-970A-UD3
Cooling Cooler Master Hyper TX2
Memory 16 Gb DDR3:8GB Kingston HyperX Beast + 8Gb G.Skill Sniper(by courtesy of tabascosauz &TPU)
Video Card(s) Sapphire RX 580 Nitro+;1450/2000 Mhz
Storage SSD :840 pro 128 Gb;Iridium pro 240Gb ; HDD 2xWD-1Tb
Display(s) Benq XL2730Z 144 Hz freesync
Case NZXT 820 PHANTOM
Audio Device(s) Audigy SE with Logitech Z-5500
Power Supply Riotoro Enigma G2 850W
Mouse Razer copperhead / Gamdias zeus (by courtesy of sneekypeet & TPU)
Keyboard MS Sidewinder x4
Software win10 64bit ltsc
Benchmark Scores irrelevant for me
439 (0.07/day)
Manchester, UK
System Name Colin #2 - the revenge!
Motherboard Gigabyte B550 Aorus Elite V2
Cooling 4x Phanteks SK140 PWM & Arctic Freezer II 280 AIO
Memory TeamGroup Dark Pro 8 Pack 2 x16Gb dual rank B-die 3666MHz CL16
Video Card(s) MSI RTX 4080 Suprim X
Storage 980 Pro 500Gb + WD SN770 2Tb
Display(s) Acer XB280HK 4K GSYNC (next thing I need to upgrade!!)
Case Phanteks P500A
Audio Device(s) Realtek ALC1200/1220
Power Supply 750W Corsair RM750
That review was well worth the read! Beats the 260 in most things, especially when the eye candy is cranked up! :D
1,777 (0.30/day)
South Australia
System Name QUACK
Processor Intel i7 2600K (3.4 GHz, 8 threads)
Motherboard Asus P67P8-V3
Cooling Xigmatek Balder 120mm (4x120,1x140mm case)
Memory Patriot 2 Viper Sector 5, 8GB DDR3 1600 MHz
Video Card(s) Gigabyte GeForce GTX 960 G1 4GB
Storage 1x Samsung EVO 850 (500GB) SSD, 1x Fujitsu 256GB SSD
Display(s) Dell Ultrasharp U2311h 23" (so sexy)
Case CoolerMaster Gladiator RC-600
Audio Device(s) Onboard 5.1
Power Supply Antec 850w with yellow racing stripes
Software Windows 7 HP 64 bit
Lame.
Not really: hardly any games use more than that: PC User magazine did some tests and got a negligble increase of 512 MB to 1 GB on an nVidia card (can't remember which).
Other than that: I'm exited!
substance90
71 (0.01/day)
Bulgaria
Processor Intel C2D 6450 @ 3.4Ghz
Motherboard Asus P5B Deluxe Wi-Fi
Cooling Zalman CNPS-9700 NT
Memory 2x 1GB Corsair DDR2-950 DHX CL5-5-5-15 2T 2.25V
Video Card(s) Asus 8800GTS 640Mb @ 648Mhz, memory: 999Mhz
Storage Hitachi 500GB SATA-II
Display(s) Dell 2407WFP 24" widescreen
Audio Device(s) Creative SoundBlaster X-Fi XtremeMusic
Power Supply Chieftec 560W
Software Windows Vista/XP Pro Dual-boot
Not interested! 512Mb/256-bit.. that`s old! How come the 8800GTX, that`s 2 years old, beat almost all of the new cards... Come on, it`s time for something NEW.
V
v-zero
What's the point in going more RAM and a wider bus when it isn't advantageous to speed but costs more money?
EDIT: wow, average of 10% behind GTX 280, that's fantastic!
Megasty
1,263 (0.21/day)
The Kingdom of Au
Processor i7 920 @ 3.6 GHz (4.0 when gaming)
Motherboard Asus Rampage II Extreme - Yeah I Bought It...
Cooling Swiftech.
Memory 12 GB Crucial Ballistix Tracer - I Love Red
Video Card(s) ASUS EAH4870X2 - That Fan Is...!?
Storage 4 WD 1.5 TB
Display(s) 24" Sceptre
Case TT Xaser VI - Fugly, Red, & Huge...
Audio Device(s) The ASUS Thingy
Power Supply Ultra X3 1000W
Software Vista Ultimate SP1 64bit
You do realize even the lowly 4850 destroys the 8800GTX, heh, this thing is as fast as 3 3870s :eek:
888 (0.15/day)
System Name Meshify C Ryzen 2019
Processor AMD Ryzen 3900X
Motherboard X470 AORUS ULTRA GAMING
Cooling AMD Wraith Prism LED Cooler
Memory 32GB DDR4 ( F4-3200C16D-32GTZKW, 16-16-16-36 @ 3200Mhz )
Video Card(s) AMD Radeon RX6800 ( 2400Mhz/2150Mhz )
Storage Samsung Evo 960
Display(s) Pixio PX275h
Case Fractal Design Meshify C – Dark TG
Audio Device(s) Sennheiser GSP 300 ( Headset )
Power Supply Seasonic FOCUS Plus Series 650W
Keyboard Logitech G 15
What is ATI thinking? Only 512MB and only 256bit? Come on, they would have a killerproduct if it was 1024MB and 512bit. It's 2008, 512MB can last another 6-12 months tops.
W1zzard
Administrator
27,569 (3.70/day)
Memory 48 GB
you people crying about 256-bit only obviously have no idea what you are talking about. please calculate bandwidth gddr3 1000 mhz @ 512 bit and then gddr5 1000 mhz @ 256 bit.
if the 4870 was $649 with 512-bit and 1 GB you'd all cry that its so expensive
1,703 (0.26/day)
Oshkosh, WI
System Name ChoreBoy
Processor 8700k Delided
Motherboard Gigabyte Z390 Master
Cooling 420mm Custom Loop
Memory CMK16GX4M2B3000C15 2x8GB @ 3000Mhz
Video Card(s) EVGA 1080 SC
Storage 1TB SX8200, 250GB 850 EVO, 250GB Barracuda
Display(s) Pixio PX329 and Dell E228WFP
Case Fractal R6
Audio Device(s) On-Board
Power Supply 1000w Corsair
Benchmark Scores A million on everything....
^yeah.... im sure there's a reason for the 256bit bus.... there has to be, people that make computer chips are pretty darn smart :D
107gb/second it says--wasnt the 2900 with 512 bit slightly less than that?
888 (0.15/day)
Ok, I know that the GDDR5 compensates GDDR3 at 512bit, but 512MB extra would really put it over the top. I am pretty sure that it wont take long untill we see the 4870 1024MB for the GTX260 price.
The 4870 upgrade will be my last upgrade up to 2010. I can already play my favourite games on 2048x1536, but I want to play them with high AA and AF settings and that will require more then 512MB ( correct me if I am rong ).
V
v-zero
Yep, the reason is price. It is very costly to implement a 512-bit bus as ATi found, you have to have many more layers on the PCB and it's all a bit messy to design. On the other hand, prices for fast RAM that will keep the bandwidth high are always dropping and a 256-bit bus requires much less work and fewer layers to implement.
Megasty
1,263 (0.21/day)
The Kingdom of Au
Cooling Swiftech.
Storage 4 WD 1.5 TB
It over compensates it by a fair margin. The 512mb 4870 doesn't need 512-bit mem. A 1gb version might due to the insane bandwidth of GDDR5 but then how much would the thing cost. ATi might be holding back a little but they have that same right as NV. There's no doubt in my mind that they will push these cards to the limit. ATi has never launched its flagship first. The only thing about a 1gb 4870 is that it should be priced around $350-400. If a 4850x2 comes about it will be a bit faster than that 4870 so it will occupy the $400-450. This is the kind of stuff that happens when you cap your cards at $500 :eek:
2,490 (0.39/day)
Your house.
System Name Jupiter-2
Processor Intel i3-6100
Motherboard H170I-PLUS D3
Cooling Stock
Memory 8GB Mushkin DDR3L-1600
Video Card(s) EVGA GTX 1050ti
Storage 512GB Corsair SSD
Display(s) BENQ 24in
Case Lian Li PC-Q01B Mini ITX
Power Supply Corsair 450W
Mouse Logitech Trackball
Keyboard Custom bamboo job
Benchmark Scores Finished Super PI on legendary mode in only 13 hours.
Checked any reviews lately? The 8800 GTX is bested in almost every benchmark by just the 4850 -- who knows how much higher the 4870 will be.
X-TeNDeR
110 (0.02/day)
Sharpening The Underdog's Teeth
Processor AMD Athlon II X4 630 Propus C2 (2.8GHz) 95w
Motherboard Asus M4A89GTD Pro/USB3 (AMD 890GX/SB850)
Cooling Scythe Yasya+MX-3, 3x140mm+1x120mm case fans
Memory Mushkin 2x2gb DDR3 1600MHz 6-8-6-24 1.65v
Video Card(s) Club3D Radeon HD 4850 512mb (Stock Fan+MX-3)
Storage WD 1TB SATA3 + WD MyBook 1TB ext+Toshiba 160gb ext
Display(s) LG W2486L '24 FHD Led 1920x1080
Case Lancool Dragonlord K62R1 (AMD Edition)
Audio Device(s) ASUS Xonar DX+Microlab X16 2.1+Senn 448 'Phones
Power Supply Seasonic M12II-620 80+ Bronze Modular
Software Micro$oft Windows 7 Ultimate 64 Bit
I don't think we need a 1GB GDDR5 card. this will make it too expensive to compete well with nvidia. and yeah, beside future proofing, the gain with 1GB is small.
I think AMD-ATi will actually use 1GB GDDR4 setup for the 4870.. maybe even GDDR3. more ram with less bandwidth, and a small or no price bump.
All in all, a great round for AMD-ATi, at last! :D :toast:
AMD-ATi FTW!
6,959 (1.06/day)
Australia, Sydney
RV770, theoretically will make good use of that memory (wtf 3.6Ghz mem clock? Quad pumped? o_O), and I think this wont be like the HD3870 and HD3850 where the HD3850 could be OC'ed up to HD3870 performance.
