Format RAW drive to recover data?
lahatte
13 (0.03/day)
I have a drive that has lost it's way, and shows as RAW in the Windows Disk Manager. I cannot access the drive.
I am wondering if it might be possible to format the drive to get an NTSC partition back on it, then use a Recovery tool used to get data from a formatted drive.
Has anyone ever tried that successfully?
Count von Schwalbe
Nocturnus Moderatus
3,236 (2.78/day)
Knoxville, TN, USA
Have you tried chkdsk? I had a drive become RAW at random and chkdsk fixed it temporarily - long enough to get the data off. Data recovery programs are not an ideal solution as you get a lot of junk data as well.
lahatte
13 (0.03/day)
Chkdsk is having difficulty reading it. Did you use the /F or just run it in read mode?
Count von Schwalbe
Nocturnus Moderatus
3,236 (2.78/day)
Knoxville, TN, USA
No idea - it was a long time ago. Try it both ways?
I just ran it to see what the issue was and next thing I know it was a fully working bootable device. The computer deleted it again so I recovered it in the same way, and transferred the data to another drive.
858 (1.20/day)
Belgium
System Name Prometheus
Processor AMD Ryzen 7 9800X3D
Motherboard ASUS ROG Crosshair X870E Extreme Gaming Wifi
Cooling AIO Cooler Master MasterLiquid 360
Memory 32GB DDR5
Video Card(s) Gigabyte GeForce RTX 3060 OC Edition 12GB
Storage Samsung 970PRO 2TB, Samsung 990PRO 4TB, WD SN850X 2TB, Samsung 980PRO 2TB. WD GOLD HDD 8TB
Display(s) Corsair XENEON 32UHD144 32" 4K UHD gaming monitor
Case Cooler Master HAF
Audio Device(s) Creative Sound Blaster AE7 + Logitech Z-5500 500W 5.1.
Power Supply Corsair AX850 Titanium.
Mouse Logitech MX Master 3
Keyboard Corsair K95 RGB
Software W10-11 Enterprise- Linux Mint 22.0 Cinnamon Edition.
Is it the 870EVO from your other post? Better go on there, so all the information stays in one post.
Solaris17
Super Dainty Moderator
27,186 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
/F tell it to repair damage. Formatting is the worst possible thing you can do.
OneMoar
There is Always Moar
8,802 (1.63/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
tools like r-studio can recover data when the MFT / partition info is toast
Ahhzz
Super Moderator
9,047 (1.47/day)
System Name OrangeHaze / Silence
Processor i7-13700KF / i5-10400 /
Motherboard ROG STRIX Z690-E / MSI Z490 A-Pro Motherboard
Cooling Corsair H75 / TT ToughAir 510
Memory 64Gb GSkill Trident Z5 / 32GB Team Dark Za 3600
Video Card(s) Palit GeForce RTX 2070 / Sapphire R9 290 Vapor-X 4Gb
Storage Hynix Plat P41 2Tb\Samsung MZVL21 1Tb / Samsung 980 Pro 1Tb
Display(s) 22" Dell Wide/24" Asus
Case Lian Li PC-101 ATX custom mod / Antec Lanboy Air Black & Blue
Audio Device(s) SB Audigy 7.1
Power Supply Corsair Enthusiast TX750
Mouse Logitech G502 Lightspeed Wireless / Logitech G502 Proteus Spectrum
Keyboard K68 RGB — CHERRY® MX Red
Software Win10 Pro \ RIP:Win 7 Ult 64 bit
7,607 (1.47/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
If you left it powered on, kiss the data goodbye.
NAND does self recondition due to pseidoSLC mode. It does garbage collection internally. So basically it wipes itself while being powered on. Only way for certain drives is to boot it via uart or solder the NANDs if those are unencrypted and read RAW data.
All other tools are aimed for rust spinners and more simple SD card mediums, that doesn't do TRIM. Some do, as Samsung USB3 flash drives, they reside Silcon Motion controller that does TRIM.
1,928 (0.31/day)
System Name Ryzen5900X
Processor AMD Ryzen 5900X
Motherboard Gigabyte B550 AORUS PRO AC
Cooling NZXT Kraken X62
Memory 4x G.Skill F4-3600C17D-8GTZ
Video Card(s) AMD Radeon RX 6800XT Midnight Black
If you REALLY need the data back, I would try this: https://www.grc.com/sr/spinrite.htm . Always had the best luck recovering data with this one, but it's not free.
There is also a free alternative for home use. Lazesoft Recovery Suite 4.7 Home Edition.
Ahhzz
Super Moderator
9,047 (1.47/day)
lahatte
13 (0.03/day)
Thanks for the responses. Just FYI, I went ahead and did a quick format on it, which made it so the OS could see it. Then I used EASEUS Data Recovery tool to scan it for data to recover.
It is in the recovering stage now. The drive had just under 1TB filled of the 4TB. So far the recovery has gotten most all of that, which is fine, because the main thing I need is what directories were there so I can re-install stuff to replicate what was there on another drive.
This drive gets the clamps!
It is, but I created a new thread because it's a bit of a different topic, and when future travelers search for this topic or similar, well... :)
de.das.dude
Pro Indian Modder
9,154 (1.71/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad| J1nnx took Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
i have had good results with test-disk software. its a DOS based thing that can be run form windows. I had acidentally deleted a partition and i was able to recover it with this. its free as well.
435 (0.07/day)
New York
System Name Unobtainium
Processor 3600X
Motherboard Gigabyte X570S Aorus Elite AX
Cooling DH15 Chromax Black
Memory 32GB Ripjaws 3200MHz
Video Card(s) EVGA 3080 Ti FTW Ultra w/ Alphacool Eiswolf
Storage 500GB SN750 | 3.84TB Micron 7450| 4TB SP XS70
Display(s) Asus 144Hz display + LG Ultrafine 4k
Case Evolv X
Audio Device(s) Schiit Hel + AKG Q701s
Power Supply Seasonic FOCUS PX-750
Keyboard Filco Majestouch II
R-Studio is a good program. Use it at work a lot.
