Found a weird Radeon HD 7950 with 1536 shaders and no temperature readout
1,877 (0.74/day)
Arizona
System Name Space Heater MKIV
Processor AMD Ryzen 7 5800X
Case Phanteks Enthoo Pro M
Mouse Logitech MX Master 3
Keyboard Glorious GMMK 2 96%
While thrift shopping yesterday, I came across this guy for $35.
Upon first glance, it just looked like a normal 7900-series GPU. The sticker that the thrift store put on it said it was a Radeon HD 7950.
After sticking it into my testing system, things got a bit weird.
The first weird thing is that it only has 1536 shaders, whereas a normal HD 7950 has 1792. The other weird thing is that the temperature reports as 0C, and the fan always runs at 40%.
It has a dual BIOS switch, and the other BIOS has only 768 shaders enabled and lower clock speeds, with the fan locked at 60% instead.
Interestingly, when set to BIOS 1, it works perfectly in my dad's 2010 Mac Pro (other than the temperature readout). The boot select screen and GPU acceleration work perfectly in macOS.
Taking the card apart, some more interesting things popped up.
The sticker on the back says "MONICA" instead of the card's normal name. From what I've found, this means it's a developer sample.
It has Hynix VRAM chips.
I tried flashing a normal HD 7950 BIOS to it, but aside from breaking video output, it also didn't unlock any shaders or fix the temp readout.
Does anyone know what the deal is with this card? Is it just a normal Mac Pro version, or is it some weird (potentially rare) developer version?
I've included both BIOS files.
  • AMD-Monica_BIOS-2.rom
  • AMD-Monica_BIOS-1.rom
546 (2.77/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
It's a 7870 XT. Didn't see many of them.
Scratch that. It has the memory config of an r9 280 or 8950, but the rest is like a 7870XT (and granted that all the Tahiti chips are basically the same.) I'm not really sure what you have there. i'll keep looking. interesting.
1,877 (0.74/day)
Arizona
546 (2.77/day)
Texas, USA
2,548 (1.19/day)
Olympia, WA
System Name Sleepy Painter
Processor AMD Ryzen 5 3600
Video Card(s) MSI RX580 8GB
Case NZXT Gamma Classic Black
Audio Device(s) Asus Xonar D1
Mouse Logitech MX518 Legend
Keyboard Red Dragon K552
1,877 (0.74/day)
Arizona
2,548 (1.19/day)
Olympia, WA
Yeah, that was pretty much the only thing I had found about it.
Personally, my guess: This is what happened to the silicon that couldn't make the cut for Mac/Mac Pro cards.
The 'low power' / 'mid power' vBIOS switch is intriguing, though.
Only commercial use I can think of for such, would be something like video slot/poker machines or Medical Imaging equipment. -where one unit might be passively cooled, and another actively; but, all the GPUs were bought in-lot qty.
546 (2.77/day)
Texas, USA
And the card reports itself to be a 280x?
2,548 (1.19/day)
Olympia, WA
I'd feel confident in
A. The previous owner was also some flavor of enthusiast-tinkerer, and took advantage of the dual vBIOS. -Flashing the 'rebrand upgrade' vBIOS for otherwise the same/similar card.
B. GPU-z's having a fit because it's an odd card; and the 280X 'better fits' the ID, etc. GPU-z is reading :confused:
Ruru
S.T.A.R.S.
13,471 (3.02/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
1,877 (0.74/day)
Arizona
I'm running the Radeon ID/NimeZ drivers, so that's why it says R9 280X. It normally reports as a 7900 series.
546 (2.77/day)
Texas, USA
For 35 bucks, i'd say it is a great candidate for swapping around some bios to see what it will do.
Coming across something like that is always cool. Big style points on the find.
43,874 (6.80/day)
States a Dev Card, so a prototype
Alternative was this
1,877 (0.74/day)
Arizona
Do you know of any particular BIOS I could try on it to fix the temperature readout and shader count?
43,874 (6.80/day)
I don't have an answer for that 1.
Keep in mind that I believe after the HD6000 series AMD started Lasering off certain defective parts of the chips, my card is 1 gen newer and there is no unlocking it to a 290X as of shaders. Also temp reading might not even be implemented on that board until a later or pre release came about (hardware present for it). We can try to look for a bios though.
These are verified files based upon your Device ID and Sub System ID, 1002 twice is definitely an AMD Reference style for sure.
@sam_86314
Ruru
S.T.A.R.S.
13,471 (3.02/day)
Jyväskylä, Finland
Didn't some 290 cards have unlockable GPUs? Also some Fury cards had unlockable shaders.
43,874 (6.80/day)
These 2 files bump the clocks up.
Rest of the files
Very very rare, i checked on mine some time ago and a tool stated it cannot be, i believe it was on ocn or ocuk.
The only other option @sam_86314 is to try a HD 7970/GHz Edition Bios or a 280/280X bios, but with this I really suggest a spi flasher so you can recover
Too bad you couldn't make this card into a 6GB model
@LabRat 891 and @damric seem to be the ones to go by for these kind of mods. I just primarily handle restoring cards to a factory working state.
14,393 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Best match I could come up with is this, but the GPU variant number on yours doesn't match anything I can find.
Outback Bronze
Super Moderator
2,147 (0.43/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 48GB G.Skill 7200
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Samsung 34" G8
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Asus
Keyboard Corsair
Software Win 11
TBH it actually more looks like a 7970, if it's made by AMD going by original HSF. It has an 8 pin + 6 pin.
Here is a pcb image of W1zzards 7950 review. It only has 2x6 pin:
