- Feb 15, 2024
- 243 (0.59/day)
- Bulgaria
System Name | Mid-Range |
Processor | Ryzen 7 5800X3D |
Motherboard | ASUS TUF Gaming B550 Plus WiFi II |
Cooling | AiO LS 520 White edition(MX-6 thermal paste applied) |
Memory | 2x16GB DDR4 3600Mhz CL18 Corsair Vengeance RGB PRO SL |
Video Card(s) | RX 7700 XT ASRock Steel Legend 12GB |
Storage | Kingston FURY Renegade 2TB /TeamGroup Cardea A440 1TB |
Display(s) | MSI G272QPF 27 inch 2560x1440p 170hz + Technika 1080p 24'' 60hz |
Case | NZXT H6 Flow ARGB + 2x140mm Lian Li Uni infinity mirror |
Audio Device(s) | RGB Kogaion Speakers/Naraka bladepoint MR720 headset |
Power Supply | EVGA Supernova G2 650Watts 80 plus Gold |
Mouse | A4 Tech Bloody Naraka W95 MAX |
Keyboard | A4 Tech Bloody Naraka S98 Mechanical |
VR HMD | no |
Software | Windows 10 Home SL |
Not really sure this is the right forum but i hope it is ..So I bought 1070ti gpu for my msi z87-g45 gaming mobo with i5 4690 non K version and i play a lot of CS2 while having 330-340 constant fps in menu and around 180-250 in-game ....and I saw that there is CPU bottleneck.Gpu was only 30-40 % utilized while cpu was always on 100% and I wanted to suck out the juice of my gpu.So I decided to upgrade my mobo ram and cpu in order to do so ,my new mobo is B450 gaming plus MAX AM4 socket with amd Ryzen 5 3600(which is times better than i5 4690) and ddr4 3200mhz RAM ,everything fine until I installed CS2 and saw that right after I start the game i have like 420 fps in menu then i starts dropping by 1-2-3 fps every second until it reaches somthing like 120-140. While gaming in competitive mode i get spikes from 170-240-270 ....Tried everything possible,doing windows configurations,reinstalled windows,installed newer bios,reinstalled gpu drivers,fixed hard drives optimisations,tried different commands for startup in the game ,turned off/on some programs ,reinstalled the game,updated windows ,changed ram slots , tried different bios settings,overclocked,underclocked,memory diagnostic tools etc...Also now the utilization is like 70-80% gpu in menu with 20-30-40% cpu I don't think its bottlenecking rn ,but something is really wrong because all I wanted is upgrading my fps thats why I paid extra to upgrade ram,mobo,cpu but in fact i turned out that i feel like I downgraded ...All I want is my fps higher and my parts are cabale of doing much more ...Seeing it hits 420 and then keeps decreasing with seconds while waiting in menu being Idle, BIOS overclock menu have ez mode and advanced, ez mode doesn't offer much so when I turn on the advanced I see so many options that I get confused , everything points out that this might be something with the bios options (also tried to turn off the virtualization + turning off the C state of the CPU - doesn't help) I don't have problems with other games except the fact that I used to have with my old configuration 170 fps on ultra settings ,and with the new one parts i have also the same frame rates ,same resolution same game settings ... My gpu and cpu temperatures are pretty good , using the max power draw they can ,my windows powwer settings are configured to high/ultra mode,no background processes ! The only imporvement I can see so far is that I used to have 70min and 90 avg fps in Battlefield 1 ,while now I have 120-140..that's the only upgrade I can feel so far
