- Feb 1, 2019
- 4,061 (1.73/day)
- UK, Midlands
System Name | Main PC |
Processor | 13700k |
Motherboard | Asrock Z690 Steel Legend D4 - Bios 13.02 |
Cooling | Noctua NH-D15S |
Memory | 32 Gig 3200CL14 |
Video Card(s) | 4080 RTX SUPER FE 16G |
Storage | 1TB 980 PRO, 2TB SN850X, 2TB DC P4600, 1TB 860 EVO, 4TB WD SA510, 2x 3TB WD Red, 1x 4TB WD Red |
Display(s) | LG 27GL850 |
Case | Fractal Define R4 |
Audio Device(s) | Soundblaster AE-9 |
Power Supply | Antec HCG 750 Gold |
Software | Windows 10 21H2 LTSC |
So prices tumbled after going crazy a couple of years back, I did consider the r7, but they still following the practice of making you buy drive bays separately and they look very flimsy so went with the r5. Definitely didnt like the bottom compartment on the r7 for drives. Reminded me of the p180 bottom compartment which is a nightmare.
This will be for the AMD machine in my sig as the P180 is a nightmare for drive management, but I noticed the build quality isnt up to the same standard as my much older r4. Pieces that dont fit cleanly, rattling, lower quality drive bays, thinner metal. However feature wise on paper its a good evolution, removable door that can also switch side of opening, bottom dust tray removed from front, extra 2 ssd bays back of motherboard plate, smaller less glary led, more spaced out USB and labelled (although r4 uses blue for gen 3 so still obvious which are gen 3 ports), better modular configuration for drive bays so allows better air flow, better cover design for top and side fans.
I am curious though if the r5 build quality dropped on its launch or maybe its something thats happened over time to keep costs down, and what the build quality is like on their newer cases.
