Fractal Design Torrent and ARCTIC Liquid Freezer II 280
1,070 (0.16/day)
System Name My Current Desktop
Processor i9 12900KF
Motherboard Asus ROG STRIX Z690-E GAMING WIFI
Cooling ARCTIC Liquid Freezer II 360
Memory G.Skill Trident Z5 RGB Series 32GB (2 x 16GB) DDR5 6400 F5-6400J3239G16GA2-TZ5RS
Video Card(s) RTX 3090 FE
Storage SAMSUNG 980 PRO SSD 1TB
Display(s) Samsung G80SD
Case Fractal Design Torrent White
Audio Device(s) Schiit Bifrost2
Power Supply Corsair HX850
Mouse Razer Basilisk v3 pro
Keyboard Keychron Q6 Max (brown)
Software Win 11 Pro
Looking to get this combo for a new 12900k build.
I can't seem to find any pics of finished looks with this combo even though pcpartpicker says they're compatible.
The TPU review of the case shows removing the front fans and installing a Fractal brand 360 AIO on included rails.
I think the front fans are the same size as the AIO, so it should mount up to the stock front plate, just not certain.
Thanks for your input!
2,373 (0.59/day)
Audio Device(s) A LOT
The front fans are 2x180 while the radiator is 2x140 — you’d need a bracket to attach the radiator to them. You could mount the radiator at the bottom, but at that point you may as well go for a different case as those fans are meant for GPU cooling.
It might work at the front with the included brackets, but I haven’t seen it done personally. The included brackets would have to align with the 180s, and you’d need to buy longer screws to keep those fans.
900 (0.66/day)
System Name 1. Glasshouse 2. Odin OneEye
Processor 1. Ryzen 9 5900X (manual PBO) 2. Ryzen 9 7900X
Motherboard 1. MSI x570 Tomahawk wifi 2. Gigabyte Aorus Extreme 670E
Cooling 1. Noctua NH D15 Chromax Black 2. Custom Loop 3x360mm (60mm) rads & T30 fans/Aquacomputer NEXT w/b
Memory 1. G Skill Neo 16GBx4 (3600MHz 16/16/16/36) 2. Kingston Fury 16GBx2 DDR5 CL36
Video Card(s) 1. Asus Strix Vega 64 2. Powercolor Liquid Devil 7900XTX
Storage 1. Corsair Force MP600 (1TB) & Sabrent Rocket 4 (2TB) 2. Kingston 3000 (1TB) and Hynix p41 (2TB)
Display(s) 1. Samsung U28E590 10bit 4K@60Hz 2. LG C2 42 inch 10bit 4K@120Hz
Case 1. Corsair Crystal 570X White 2. Cooler Master HAF 700 EVO
Audio Device(s) 1. Creative Speakers 2. Built in LG monitor speakers
Power Supply 1. Corsair RM850x 2. Superflower Titanium 1600W
Mouse 1. Microsoft IntelliMouse Pro (grey) 2. Microsoft IntelliMouse Pro (black)
Keyboard Leopold High End Mechanical
The Torrent is great for air cooling. Less so for water cooling.
2,373 (0.59/day)
People keep saying that but it’s definitely an option
I believe hardware labs makes 180mm radiators too but that may have been a limited run
1,070 (0.16/day)
Software Win 11 Pro
That vid looks awesome but I'm looking for a CLC. Maybe I'll do a custom loop down the line, but something that big warrants getting a GPU block too. Steve did not look happy disassembling the FE cards lol.
The blocks do look great though!
I think the bottom 3 fans are plenty for my 3090 FE for now.
I think a 360 should be good personally.
AsRock
TPU addict
18,968 (3.03/day)
UK\USA
Brackets come with the case in a separate box ( and will ). Although if i were to add a rad i would defiantly look in to a 180 just to max the possibility's out.
Personally i think fans should be kept int he bottom just help to move the air around int he case some.
2,373 (0.59/day)
Right, but they mount to the chassis so as to replace the 180s — can they be mounted to the 180s with long enough screws? @Darksaber
I meant that the CLC could be mounted there, fans included, depending on hose length, but I’d hate to have that hot air blowing at my GPU.
AsRock
TPU addict
18,968 (3.03/day)
UK\USA
So keeping the 180mm fan were they are originally and attaching the rad to the 120mm brackets from inside, then attaching the 120mm brackets to the 180mm fans ?, if so then no.
No screw holes line up for them to screw in too or space as the brackets are a little to narrow by about 4-6mm to be able to make screw holes for it :), how ever i could see some washers solving that issue though.
You would have to get a little creative with it, and would have to be careful not to over tighten as the washer would only be 40-50% on the bracket.
Screw length would depend on thickness of rad,maybe nut bolt lock tight come to mind if the rad is really thick other wise should screw in fairly well but depends on the thickness of the washer too.
Sadly i do not have a rad to fully test it and we have no hardware stores close by any more.
Mussels
Freshwater Moderator
58,413 (8.06/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
I was about to say this - it'll come with adaptors
One of my PC's has 2x200mm front intakes and a 280mm rad (2x140mm) and somehow it works out great - the bracket design forces the air in just fine.
I run the RE version of these blocks if you have any questions, performance is great but they're not perfect
1,070 (0.16/day)
Software Win 11 Pro
I ended up going with a 360 rad in from since it fits nicer in the case with less empty space above and below the rad. I put the original 2x180 from the front blowing up onto the video card on the bottom.
Now I just need to work on voltages, CPU doesn't hit 70c on normal loads, usually 40-50c on games that are not heavily CPU bound, but hits 100 quick with the prime95 torture test. ambient temps are 25c. GPU generally stays around 65c with modern games at 1440.
I also noticed the CPU frequency drops often with the port royal test which I assume is the speed step default?
Sorry for the crap photo, too much daylight.
2,373 (0.59/day)
Hate to say it but this is a terrible case for a CLC
1,070 (0.16/day)
Software Win 11 Pro
I've seen this vid a remembered the part where the pump should not be above the rad but forgot bubbles will then float to the top... :banghead:
I'll flip it, there's plenty of hosing.
these are the CPU freq drops I mentioned.
Mussels
58,413 (8.06/day)
Oystralia
the CPU will drop normally since the boost is meant to be time limited. Heck it only takes milliseconds for something else to bottleneck, and the CPU will downclock.
It'll also drop if theres too much heat - the fact you saw 100C means either
1. the pump RPM is too low (set it to 100%, seperate to the fans)
2. the mount/TIM is bad
3. the BIOS settings are too aggressive
1,070 (0.16/day)
Software Win 11 Pro
I only saw 100 with prime95, nothing else even comes close.
peak cpu temp during this benchmark was 54c most was around 30-35.
Cinebench gets 1 core to 90 after 10 min.
