FRAPS DX9 Error on Startup
1,555 (0.26/day)
Shepparton, Victoria, Australia
System Name Toaster!
Processor Intel Core i7 10700KF @ 3.8/5.1GHZ
Motherboard ASUS Prime Z490-P Motherboard
Cooling Noctua NH-D15 CPU cooler.
Memory G.Skill Trident Z RGB 64GB (4x16GB) 3600MHz CL16 DDR4
Video Card(s) ASUS ROG Strix GeForce RTX 3090 OC 24GB
Storage Samsung 970 PRO M.2 NVMe SSD 1TB
Display(s) Asus ROG PG43UQ 4K UHD 144Hz G-Sync HDR 43in + 2 x ASUS VG258Q FHD 144Hz Freesync 25in Monitor
Case Corsair Obsidian 900D
Audio Device(s) EPOS Sennheiser GSX 1000 V2 amplifier + EPOS Gaming GSP 601 Headset
Power Supply Corsair AX1000 Titanium Modular
Mouse Razer Deathadder
Keyboard Corsair K70.
Software ALL HAIL WINDOWS 10.
Benchmark Scores Old system: http://www.3dmark.com/fs/6805248
I have DX11, is that what's causing this error on start up? Tried reinstalling DX9 but it always comes back.
5,432 (0.90/day)
Australia
I have never had that problem, but i would not have the program run on start up, only on demand. Try that see what happens?
9,248 (1.61/day)
Montreal, Canada
System Name Homelabs
reinstall fraps
2,644 (0.46/day)
System Name MRCOMP!
Processor 5800X3D
Motherboard MSI Gaming Plus
Cooling Corsair 280 AIO
Memory 64GB 3600mhz
Video Card(s) GTX3060
Storage 1TB SSD
Display(s) Samsung Neo
Case No Case... just sitting on cardboard :D
Power Supply Antec 650w
reinstall fraps
This +1 ^
that should fix up any problems with direct x and Fraps..... your most likely just missing a file.
1,555 (0.26/day)
9,248 (1.61/day)
Montreal, Canada
Go to windows\system32 and copy d3d9.dll as well as all d3dx9_**.dll should be 24 to 43 to the FRAPS folder
1,539 (0.28/day)
Canada/Québec/Montreal
System Name Main PC
Processor PII 925 x4 @3.724GHz (266x14) 1.525v NB 2660 1.425v
Motherboard Gigabyte AM3 GA-890XA-UD3 (790x+SB850)
Cooling Scythe Mugen 2 rev.B
Memory Hyperx 8GB (2x4) 1600@1418 8-7-7-20-27-1t
Video Card(s) GTX 680
Storage 256GB SSD / 2TB HDD
Display(s) LCD Samsung 24" 16:9
Case Cooler Master HAF 912
Audio Device(s) On-Board HD
Power Supply CM 750w GX |3.3v@25a|5v@25a|12v@60a
Software Kubuntu dual boot /Windows 7 Ultimate 64bit
Benchmark Scores later...
1,555 (0.26/day)
9,248 (1.61/day)
Montreal, Canada
1,555 (0.26/day)
kromatik
1 (0.00/day)
how I fixed this
I have a solution for this ... just applied this on my laptop after running into the same error.
I unchecked the option to run FRAPS when Windows starts, and I created a scheduled task to start it (via Task Scheduler) instead. The trick here is that you can choose to trigger the task at logon, but with a 30 seconds delay. This way I was able to avoid the error and still have FRAPS start automatically.
robinmgp
1 (0.00/day)
I have the same problem too but I'm on windows 8.1! Anything that uses directX says i dont have directx installed. they used to work perfect! when i opened dxdiag.exe it said everything was ok. so i tried an uninstaller but it said that i didnt even have direct x anymore. Here's a picture:
Directx setup says i already have 11 or newer. PLEASE HELP!
johnspack
Here For Good!
6,018 (0.97/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 1x27" 1440 display 1x 24" 1080 display
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Archlinux, Manjaro, Win11 Ent 24h2
Benchmark Scores It's linux baby!
Toothless
Tech, Games, and TPU!
9,538 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
I've ran into this issue multiple times, and all I do is keep trying until it gives in and works.
Or, if you have an NVIDIA card, just use Shadowplay...
johnspack
Here For Good!
6,018 (0.97/day)
Nelson B.C. Canada
Keyboard Ducky
It's funny, I have an Nvidia card, and there are times, or games, where snagit ect just won't capture... fraps does. It really is a good little standby capture app.....
1,555 (0.26/day)
My issue resolved itself magically.
