Freesync not working
62 (0.03/day)
System Name Crash
Processor i7 7700k
Motherboard Asus strix z270E
Cooling Arctic freezer 360
Memory T force 16gb 3200mhz (8x2)
Video Card(s) Sapphire Nitro+ RX 580 8gb SE
Storage Samsung 850 evo 500gb
Display(s) Dell se2717h
Case Phanteks luxe tempered glass
Power Supply Corsair RM 650x
Software Windows 10 pro
hey guys
plz if someone can help me to solve this problem.
my monitor is DELL SE2717H and It is supported Freesync (48-75) and i have sapphire RX 580 nitro+.
evreything is ok in amd radeon settings the Freesync is on but when i play a game like Goldeneye Source (300fps) i get screen tearing.
i dont know whats the problem.
Tallencor
TPU's First Patreon
789 (0.20/day)
N.S. Can.
System Name Francis
Processor 7700k @5.0 delid
Motherboard Rog Maximus IX Code
Cooling Corsair H100i V2
Memory 32 GB Gskill Trident Z RGB 3200 xmp
Video Card(s) MSI RX 480 Gaming x 8G
Storage Samsung960evo250GB os Samsung 860 evo 500GB (Games)Samsung 840 120 (Storage)
Display(s) Viewsonic XG 2701 Freesync
Case Corsair Crystal 570x
Audio Device(s) On board Supreme FX
Power Supply Evga 850 G3
Mouse Logitech G900
Keyboard Logitech G810
Software Win 10 Home 64
Benchmark Scores 11+12=19?
Easy. Freesync wont work past the 75 max refresh of your display. Keep the game within your monitors refresh rate of 48 to 75.
Mine is 45 to 144 range so if I'm playing a game like grim dawn I cap my framerate to not exceed 140 using riva tuner. The driver based tool works as well but I found some games wouldn't hook the limiter unless it was set in global settings as well. Its been shown that radeon cards will not cap at exactly what u set for a cap and more often than not exceed the cap by 2 or 3 fps introducing tearing.
The biggest gain from freesync isnt so much the top end tearing it's the variation of frames that happens during different loads. ie an explosion or lots of action on screen will drop frame rates quick. The GPU will push frames to the monitor faster than the monitor can handle it causing stutters and tearing by injecting a frame between two frames. Freesync stops this by syncing to the monitor and always pushing the proper amount of frames the monitor can handle. The catch being the range. 48 to 75 in your case. Below 48 jitters. Above 75 tearing.
Mussels
Freshwater Moderator
58,413 (8.06/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
if you're getting 300FPS, you clearly dont have Vsync/freesync enabled correctly
I dont have AMD hardware to be certain on this, but make sure Vsync is enabled as well as freesync - or cap your FPS to 75 somehow
62 (0.03/day)
System Name Crash
Processor i7 7700k
ok bro what about AMD FRTC ?
when i turn on FRTC and set the limit fps at 75fps the tearing still exists but when i put it to 74fps the tearing is gone.
is FRTC better then Riva tuner ?
and is Freesync at 75fps better then non sync at 90+fps.
im getting in all my games 70+fps in 1080p max settings like assassin creed odyssey.
thnx man for the reply but Vsync couse hight input lag.
Mussels
58,413 (8.06/day)
Oystralia
Vsync, or cap your FPS. Only options.
Personally i havent seen or had issues with Vsync and input lag except in very broken games.
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.54/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
This is what you should do (if still tearing at 74, try 73). The card will try to pace frames so it's smooth without going over the limit causing tearing.
2,960 (0.86/day)
Long Island
Freesync has a viable range from 40 fps and up, tho the impact begins to seriously tail off after 70 fps. G-Sync range is 30 fps on up but as it starts to tail off at 70 fps, you cans switch to ULMB. If your monitor is capable, you can use toasty strobelight to mimick the effect of ULMB
See "Other Brands of Blur Reduction" for monitor manufacturer provided solutions or "Classic Lightboost Blur" reduction here
https://www.blurbusters.com/faq/120hz-monitors/
Cap the fps to a couple below the monitor max hz.
