front panel exhaust fan
675 (0.10/day)
Michigan, US
System Name Clarise
Processor AMD Athlon 64 X2 4200+ (Toledo) @2.8 (255 X 11)
Motherboard Asus A8v Deluxe rev 2
Cooling Gigabyte 3D Cooler Pro + 5 Case Fans
Memory 2GB G-Skill (2.5-3-3-6 1T) @ 467mhz
Video Card(s) XFX 7600GT 256MB GDDR3 @ 640-814
Storage Western Digital WD5000AAKS 500GB (Sata) Maxtor 120GB (Sata) Western Digital 120GB (ide)
Display(s) 19" HP Pavilion M90 / 33" Sony Wega Trinitron
Case Antec Lanboy with a few mods :0)
Audio Device(s) Creative Audigy 4 Pro - Bose Free Style 2.1 Speakers
Power Supply Rosewill Extreme Edition 500W 34A 12V rail
Software Windows XP Pro & Vista Ultimate
hey i got borred last night and added another fan to my case. it was a pain in the butt, but i think it looks pretty good. what do you guys think?
i_am_mustang_man
1,838 (0.27/day)
Boston
Processor AMD X2 AM2+
Memory 2GB DDR2
Video Card(s) 7900gto
Storage 80GB+120GB 7200RPM IDE + 250GB SATA2 + 500GB SATA2
Display(s) 26" 1920x1200
Case Antec Nine Hundred
Audio Device(s) OnBoard
Power Supply Ultra 600W with X-Connect
Software Vista Ultimate
pretty sick imo
675 (0.10/day)
Michigan, US
System Name Clarise
i had it as an intake but it kept sucking the front door to my case shut. so i flipped the back fan and front one so there is a steady flow of air from back to front across the CPU fan. it dropped my CPU temps from 120 (idle) to 100-105 (idle) with the cpu fan at 2200 rpm. goes to mid 90's eith cpu fan at 4500rpm
i am going to install another switch like the round black one in the pic to run both the front and back case fans as soon as i can find a matching switch. the current one controls my window fan front case fan (bottom, or in my case since i flipped the case upside down, top) a socket 462 AMD fan in the front pannel blowing on my hard drives and my old 939 fan currently sitting on my memory till i find a way to mount it.
BigJunit
117 (0.02/day)
UK - Avon
Processor AMD Athlon 64 X2 5200+ @ 3.2Ghz
Motherboard Asus CROSSHAIR nForce 590 SLi
Cooling Custom Watercooled 1/2' Loop (CPU & GPU)
Memory OCZ 2GB PC2-6400C4 Platinum Revision 2 XTC Series DDR2
Video Card(s) Nvida BFG Geforce 8800GTS OC2 320mb
Storage 320gb Seagate SataII & 400gb Freecom External
Display(s) HP 22' Widescreen DVI 1650x1050
Case Asus Custom
Audio Device(s) Asus (5.1 came with board)
Power Supply Jeantech 600w Modular
very nice job, difficult to mount a fan on the drive plates (i tried once before)
Very clean & tidy cut - love it
675 (0.10/day)
Michigan, US
System Name Clarise
thanks, this one wasnt that bad, i did it to my room mates computer aswell, and that one was a pain in the ass, the plates were twice as thick, and i had limited tools to do it with, cause my dremmel died on me a few weeks ago.
675 (0.10/day)
Michigan, US
System Name Clarise
i am going to change it out with a blue led fan here in a few days
Deleted member 24505
the air should really be going from front to back tho.nice job tho'
1,793 (0.26/day)
Nebraska, USA
System Name W.I.P.
I got bored and did something similiar a few weeks ago. Looks nice and with a blue led fan itll look even nicer...:toast:
345 (0.05/day)
suffolk uk
Processor Core 2 duo - e8400 @ 3ghz
Motherboard Asus P5k-e
Cooling 1 pumps 2 blocks 2 rads 10x 120mm fans
Memory 4GB - OCZ PC2-8500 1066mhz (4-4-4-15)
Video Card(s) BFG 8800gts
Storage 1x Seagate Barracuda - 160gb SATAII
Display(s) 19" tft
Case Mozart TX
Audio Device(s) X-FI
Power Supply 700w coolermaster
Software xp home
if you door is double thickness, drill small holes like a grill on the inside and the cut an aperature at the top so that the air can be drawn in, job done..........
or get the same case as me, check my sig.
good job though.
Completely Bonkers
2,576 (0.39/day)
Processor Mysterious Engineering Prototype
Motherboard Intel 865
Cooling Custom block made in workshop
Memory Corsair XMS 2GB
Video Card(s) FireGL X3-256
Display(s) 1600x1200 SyncMaster x 2 = 3200x1200
Software Windows 2003
Did you dremel that circle? WOW. Good job with the dremel, Dremel-JEDI!
acousticlemur has gone against normal convention and reversed the airflow!!!! And you know what? He's right.
(listen to the OOOOOOOOOOOOOHHHHHHHHHHHSSSSSSSSSSSS. That can't be right!)
But he is right, on one condition: The PC is under a desk and against a wall.
  • If the PC is under a desk... that hot air gets trapped
  • This means that the local ambient temperature increases... sometimes as much as 10C or more
  • By throwing the hot air out of the front... and away from under the desk... then the air goes out into the room.
  • The local air is now room temperature not super-heated local temperature
  • "Cool" air drawn in is therefore cooler and the PC is more efficient at cooling
NOTE this is only valid for PC's stuck under the desk. Even though the "reverse" flow may be optimal there is a reason we DONT blow out the front. It creates an uncomfortable hot draught and dust. IMO the preferred solution is still eject out the back... draw from the front and underneath the PC. But this requires FREE airflow from the back of the PC to the room.
Also remember the HISTORY of the PC case. First NO fans. Then ONE fan... on the PSU. (And obviously blowing OUT). Then two fans... PSU and CPU... then three fans... PSU, CPU and GPU... then four fans... +case fan... etc. It's no wonder we all just ASSUME suck in the front and push out the back.
675 (0.10/day)
Michigan, US
System Name Clarise
no i wish i had a dremel, it broke on me, i did it with a utility knife, needle nose pliers, and a lot of swearing. that is why i am so proud of it!! and no it is on top of my desk but the desk is in a corner and the back of it is inches from the wall
This pic is pre fan mod, but it shows where the computer is on the desk, and that it is upside down! i wanted to see the purdy stuff inside! :)
Completely Bonkers
2,576 (0.39/day)
Ah... there's your problem. Upside down case. Heat getting trapped in top of box. PSU sucking air out the bottom... But all the hot CPU air rising to the GPU and getting hotter still. Drill a bit passive blow hole in the bottom (now top) of your case. Cover with mesh to protect from falling objects.
675 (0.10/day)
Michigan, US
System Name Clarise
there is a front case fan in the "top" blowing out, hidden behind the front cover and it vents right infront of my sound card box thing on the top
Completely Bonkers
2,576 (0.39/day)
Swap cases to solve your airflow problems:
Why not get two... put one on top of the other (upside down).
You could then rent your PC to auto-manufacturers for wind tunnel testing. LOL. ;)
675 (0.10/day)
Michigan, US
System Name Clarise
holly shit that thing is insane! are those 250mm???? here are pics of my front fans....top one with green clips blowing out. and amd socket A fan blowing in on my Hard drives
Completely Bonkers
2,576 (0.39/day)
See what you are doing? Trying to fan pimp... when there's a low rider in town? LOL :roll:
1./ I hope the green fan at the "top" is blowing OUT. (and the other top fan is blowing out)
2./ Dremel the swiss cheese away from those top fans... replace with wire fan guard. 50% improvement guaranteed. (as long as the door is open).
3./ HDD's are blocking your 2rd fan down. Inefficient and noisey.
Actually, I think the whole thing sucks. Since you like hard core cases... I recommend you get a server case with more room in it. You will be able to mount the HDD's so they are not sandwiched... and manage your airflow better.
PS. Hot air rises. Optimal solution is hot out the top... cold in the bottom. Consider a custom case. Got a workbench? Can you weld? Or work in wood?
675 (0.10/day)
Michigan, US
System Name Clarise
----haha, yeah i get borred sometimes!
----YES
---need to replace my dremel it is dead
---there is actually a decent amount of air blowing through them, and the temps dropped
---yeah but when i get around to a new case i will just build a new computer, this one is like 3 years old
---i was thinking about putting a squirell cage on it!! :roll: :laugh: :toast:
675 (0.10/day)
Michigan, US
System Name Clarise
so i could see inside it. they design the cases backwards compared to how the desks are designed. and i figured....why not, i have never seen one upside down. heh, what the hell. so i flipped my cd/dvd drives and my floppy and put it over there and said "hey, now that is just sexy" :)
EnglishLion
461 (0.06/day)
Peterborough, UK
Processor Intel Pentium Dual Core E2160
Motherboard ASUS P5E3 Deluxe
Cooling Akasa EVO 120
Memory 2 x 1Gb OCZ Gold DDR3 1066Mhz 6,6,6,18
Video Card(s) GeCube ATi X1950Pro 512Mb PCIe (Accelro X2)
Storage Samsung 320Gb SATA2
Display(s) Samsung SM206BW 20" Widescreen TFT 1680x1050
Case Coolermaster Centurion 532
Audio Device(s) On board AC'97
Power Supply Hiper Type-R 580W
Software Windows Vista Home Premium
Benchmark Scores See my OC Blog @ http://www.rowan-house.net/
Have you got an outside wall behind the case? If so cut a hole through and fit a short duct from outside to rear (intake) fan and draw really cold air in! Especially in winter!
675 (0.10/day)
Michigan, US
System Name Clarise
yeah but it is a concrete wall, and the house is rented. good idea but prolly not gonna do it. :)
345 (0.05/day)
suffolk uk
Display(s) 19" tft
Case Mozart TX
Software xp home
check my rig for fans - case temps of 22 deg c.
