FS-Modded 939 mobo, TEC block, CPU & *awesome* RAM
3,278 (0.49/day)
UK-small Village in a Valley Near Newcastle
Processor I9 9900KS @ 5.3Ghz
Motherboard Gagabyte z390 Aorus Ultra
Cooling Nexxxos Nova 1080 + 360 rad
Memory 32Gb Crucial Balliastix RGB 4.4GHz
Video Card(s) MSI Gaming X Trio RTX 3090 (Bios and Shunt Modded) 2.17GHz @ 38C
Storage NVME / SSD RAID arrays
Display(s) 38" LG 38GN950-B, 27" BENQ XL2730Z 144hz 1440p, Samsung 27" 3D 1440p
Case Thermaltake Core series
Power Supply 1.6Kw Silverstone
Mouse Roccat Kone EMP
Keyboard Corsair Viper Mechanical
UPDATED: new Items: Intel E2140 & Meanwell S-320 PSU for powering 12-15V TECS
UPDATED SALE:
* Intel E2140. (£30 shipped)
Has original cooler, and slightly damaged box. Have taken this from 1.6ghz stock to 2.9 EASY, think i hit a wall around 365-370FSB. all of this was on stock cooler with a fractional voltage bump. :)
* Meanwell S-320 PSU. (10-14V 300W )(£50 shipped)
Ideal for powering 12-15V TECs, looks a wee bit worn but works perfectly, has a replaced variable resistor for voltage control since the puny original broke off. This was used to power the TEC module on sale in this thread
What I am selling include:
* A Volt modded Asus A8R32-MVP Deluxe (skt 939) (£55 or £90 with pelt block)
* 2GB of fantastic Corsiar XMS-4400PRo (does over 600MHZ @ 3/3/3/7) (£100) (SOLD)
* Hi-quality Peltier waterblock (TEC) (£35)
* Opteron 185 cpu (naked with IHS removed, tho included for re-attachment) (£65) (SOLD)
____________________________________________________________________
ITEM INFORMATION:
Motherboard model: ASUS A8R32-MVP Deluxe
(VOLT MODDED) (£55 or £90 with pelt block included)
Review site: http://techreport.com/articles.x/9467/1
CPU support • Socket 939-based AMD processors
North bridge • ATI CrossFire Xpress 3200
South bridge • ULi M1575
Interconnect • PCI Express x4 (2GB/sec)
Expansion slots • 2 PCI Express x16
• 1 PCI Express x1
• 3 32-bit/33MHz PCI
Memory • 4 184-pin DIMM sockets
(Maximum of 4GB of DDR266/333/400 SDRAM)
Storage I/O • Floppy disk
• 2 channels ATA/133
• 4 channels Serial ATA with RAID 0, 1, 0+1, 5 support via ULi M1575
• 2 channels Serial ATA with RAID 0,1 support via Silicon Image SiI 3132
Audio • 8-channel HD audio via M1575 and Realtek ALC882 codec
I have personally, with a bit of tweaking, taken the FSB of this motherboard up to 370 FSB, as well as volt modding the board to deliver upwards of 1.9 volts to the cpu for extreme overclocking. Voltage is controlled by a variable resistor as seen in the photo.(turning clockwise to 50% turn starts the climb in voltage, and is very sensitive thereafter, extreme caution should be used when modifying the voltage and should only be done while monitoring the voltage in real time. eg. via bios voltage monitor)
The socket around the motherboard has the receptical insulation neoprene foam "socket" for accepting the Peltier (TEC) block also being sold, which fits perfectly forming a water resistant barrier. (the original bracket mount simply sits over this motherboard neoprene and then the TEC block onto that. The motherboard has also been waterproofed by spraying with an acrylic plastic spray preventing any waterdamage from occuring. There is an adhesive metal backplate for screwing the TEC block onto or any other waterblock etc, or simply screwing the original bracket to via screws so oem heatsinks etc can be fitted.
I also have a spare backup backplate totally unused and with adhesive tape fixed on for use incase you flummix up the currently affixed one. (sold with peltier block only)
RAM model: Corsair TWINX 2048-4400PRO
(£100)
Review site: http://www.techarp.com/showarticle.aspx?artno=317&pgno=0
Kit Part Number • TWINX2048-4400PRO
Module Part Number • CMX1024-4400PRO
Module Capacity • 1024 MB (x2)
Module Speed Grade • PC-4400
Dual Channel Certified • Yes
Rated Memory Clock • 275 MHz
Maximum Transfer Rate • 4.4 GB/s
Rated Timings • 3 - 4 - 4 - 8
Supported CAS Latencies • 2, 2.5, 3
Rated Command Rate • 2T
Data Transfers Per Clock • 2
Rated I/O Voltage • 2.80 Volts
Heatspreader • Black-anodized XMS PRO aluminium heatspreader
Memory Chip • Infineon Rev. C DDR SDRAM (HYB25D512800)
Chip Operating Temp • 0 °C to +70 °C
Special Features • XMS PRO heatspreader
• 18 activity LEDs
This is just the manufacturers information, but these RAM modules can run far above 600MHz depending on your cpu @ 3/3/3/7 timings and 2.85V rock solid!!
I originally purchased them for around £250 and would make a killer part of any DDR1 setup!
MCW-5002-64T socket 939 peltier waterblock. (£35)
Manufacturers Website info: http://www.swiftnets.com/products/mcw5002-64T.asp
"The MCW5002-64T™ is a fully assembled liquid-cooled thermoelectric (Peltier) solution, specifically designed for AMD® "K8" class (socket 754 and 939) microprocessors.
This unit is intended for advanced users in extreme microprocessor cooling applications, such as extreme overclocking. The product requires appropriate insulation measures to prevent the formation of condensation in sensitive areas of the motherboard. Whereas Swiftech provides gaskets, and specific installation instructions for such assembly, utilization of this device is at the sole risk of the user"
Features:
* 226Watts 25A at 12V thermoelectric module
* 1/2" barb fittings, for maximum flow rate
* Patent pending Diamond-Pin Matrix© copper base plate for optimal heat transfer, and turbulent flow:
* "Dropped-deck" housing, to increase cooling fluid velocity through the Diamond-Pin Matrix© area.
* Bolts directly onto stock AMD retention frame
* Fully gasketed assembly for condensation control
Thermoelectric cooling benefits
* Up to 50°C drop in processor operating temperature
* Solid state module reliability (50,000 hours MTBF)
* More versatile than vapor compression systems: can be used with almost any chassis with our MCB-120 "Radbox" external radiator mounting system
* More economical and easier to implement than vapor compression systems
This module uses 1/2" tubing and comes with approximatly 2ft of 1/2" tubing permanantly fixed to the blocks barbs. It has been epoxy resin sealed due to initial leak problems and is now 100% sealed and totally incapable of leaking from the barbs. All that would need to be done is cut the current tubing down do desired length and then use a tube joining barb (extender barb) to attach to the rest of your cooling setup.
I will include a sticky backed sturdy metal backplate attaching to the motherboard with.
If purchased seperatly from the motherboard, you will need to simply insulate under the plastic retention bracket with some cheap neoprene.
I will include a tube of dialectric grease for use with sealing spaces etc and insulating the socket pins.
I have used this on both my old Athlon 64 San diego core and my recently replaced Opteron 185 (in this sale). Even when overclocked to 3GHz and throwing out 150+W of heat this cooler can keep the temperature of the 2 cpu cores below -0C at idle (down to -13C) and under load can keep the temperature a pleasant 20-24C.
Processor Model: Opteron 184 (£65)
Stock speed is 2.6GHz and can be ran at stock using as little as 1.15V.
Overclocking to 2.8GHz can be done on stock/just under stock Voltage
Overclocking to 3GHz requires between 1.45 and 1.5V
On this particular processor I have removed the Integrated Heat Spreader (IHS) for optimal thermal dissipation (especially when used with extreme cooling methods)
Please see this thread: http://forums.techpowerup.com/showthread.php?t=30464
Where I show how I removed the IHS on this processor incase you want more information ;)
I have the original OEM box, and will also ship the original IHS cap incase you want to re attach it, as well qas the original OEM heatsink, manual and Opteron case sticker.
I am open to offers, but, the RAM especially is rare and you cannot buy this anymore, and its performance is simply KILLER :rockout:
3,278 (0.49/day)
All items must go!
Plz feel free to send me offers
If they dont sell, I wont let Santa out of his cage! And no quad cores for you! MUHAHAHAHAHA :roll:
2,276 (0.35/day)
Cairns QLD, Aussie
System Name GaMEr / HTPC
Processor FX8320 4.5ghz so far NB- 2815mhz / X2 255 @ 3.2ghz (Temp till BD)
Motherboard 990FX-UD5 / GA-MA785GPMT-US2H
Cooling XSPC - 240rad 480rad 5 x 120mm out, 6 x 80mm in / H220-edge 1/2" & 2 x 120mm Magma
Memory 4gb PI 6,8,6,18 1T 1706mhz / 4gb Crucial D9's 1400 @ 6,6,6,18,1T
Video Card(s) 3gb HD7950 / Onboard
Storage 2 x 120gb Sandisk ultra plus 2tb WD / 60gb vertex 2 + 2 x 2tb WD Greens
Display(s) 3x24in Dell Ultra (portrait) / NEC 32" FullHD LCD
Case LL PC71A Full tower / Antec fusion black with Imon remote Modded for WC
Audio Device(s) OB / Auzentech cinema 7.1
Power Supply TT 700w TR2 / TT 600w Litepower modded with Noctua S12 fan.
Software 7 Ult / 7 premium x64
Love that ram man... back from the days when corsair made the good shit... Good luck with the sale..
3,059 (0.43/day)
Baltimore MD
Heatware
3 0 0
Processor Ryzen 5900X
Motherboard ASUS Prime X470 Pro
Cooling Arctic liquid freezer II 240
Memory 2 x 16 Gb Gskill Trident Z 3600 Mhz
Video Card(s) MSI Ventus 3060 Ti OC
Storage Samsung 960 EVO 500 Gb / 860 EVO 1 Tb
Display(s) Dell S2719DGF
Case Lian Li Lancool II Mesh
Mouse Logitech G703
Keyboard Logitech G513
Software Win 11
agreed good luck with the sale great rig 939skt is definitely not dead and that opty will keep pace with any am2 cpu for gaming
i wish your where located in the states so i could buy that ram cause it would win out over any ddr2 in a latency bench
3,278 (0.49/day)
id consider shipping there, ill need to think bout the best way tho
sneekypeet
not-so supermod
29,636 (4.33/day)
Heatware
334 0 0
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
I used USPS Air(international) to ship a GFX card to Infrared in the UK, he then used Royal Air (not sure of name) to ship it back. Cost was around $15USD, and the GFX card was way heavier than your RAM.
Free bump while im at it!
nflesher87
Staff
4,518 (0.68/day)
Texas
Heatware
136 0 0
wow, that's barely more than shipping within the US
bump for you mandelore, you're an overclocking king :rockout:
3,278 (0.49/day)
New reduced prices, cmon, buy buy buy ;)
so I can spend spend spend lol
3,059 (0.43/day)
Baltimore MD
Heatware
3 0 0
Mouse Logitech G703
Software Win 11
the 50 off the ram is that off 100 or was it previously higher
3,278 (0.49/day)
the ram is now £100, I edited the prices to reflect the price reduction
Wile E
Power User
24,318 (3.64/day)
Heatware
9 0 0
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
It's a shame that block doesn't fit AM2, or I might consider it.
Free Bump.
3,059 (0.43/day)
Baltimore MD
Heatware
3 0 0
Mouse Logitech G703
Software Win 11
i thought am2 and 939 used the same retention bracket ??
3,278 (0.49/day)
1,052 (0.15/day)
Ards
System Name Jezebelle
Processor i5 4690K
Motherboard MSI Z97M-G43
Cooling Noctua NH-U12
Memory 2x8GB Ballistix Sport
Video Card(s) GTX 1070 Ti
Storage Sandisk Ultra II 480GB, Sammy 1TB F3
Display(s) BenQ Xl2411Z
Case Fractal Define Mini
Audio Device(s) Onboard Realtek 7.1 HD, does the job!
Power Supply Enermax Infiniti 720W
Keyboard Logitech G15
Software Winblows 10 Pro
BUMP for a great piece of modding :D
441 (0.07/day)
Manchester, UK
System Name Colin #2 - the revenge!
Motherboard Gigabyte B550 Aorus Elite V2
Cooling Arctic P14 PWM PST (3 pull and 3 push) 2 pushing through an Arctic Freezer II 280 AIO
Memory TeamGroup Dark Pro 8 Pack 2 x16Gb dual rank B-die 3733MHz CL16
Video Card(s) MSI RTX 4080 Suprim X
Storage WD SN850X 1Tb + WD SN770 2Tb
Display(s) MSI MPG321URX
Case Phanteks P500A
Audio Device(s) Realtek ALC1200/1220
Power Supply 750W Corsair RM750
VR HMD PSVR2
I'll take the opteron if still available? :) Very tempted by that memory as well!
3,278 (0.49/day)
yes its available. I have the original heatsink and packaging, will include the IHS cap incase u want to reapply thermal compound on the die and glue it back on. no shame in doing that ;)
where do you live? edit: nm, manchester ;)
pm me if you are still interested. at work till 5pm gmt time 2day
3,278 (0.49/day)
Update: Sold Opteron 185 & RAM
2,724 (0.41/day)
Blighty
Processor R7 5800x3D
Motherboard MSI x570 Tomahawk
Cooling XSPC Raystorm Edge,EK QS P420M,EK D5pwm Revo Res
Memory 32gb Corsair Vengeance RT 3600 cl16
Video Card(s) Zotac 3070ti Amp Extreme
Storage Samsung 980pro 1tb x2
Display(s) MSI MPG321QRF QD
Case Corsair 7000D
Power Supply EVGA 1000 P2
Mouse G900
Keyboard Corsair k60 RGB PRO
Software Win 11
Meh, the rams gone, i know someone who wanted it, oh well, free bump!
3,278 (0.49/day)
Thanx anyways mate, free bumpage always welcome ;)
DaMulta
My stars went supernova
16,168 (2.40/day)
Oklahoma T-Town
Heatware
11 0 0
System Name Work in progress
Processor AMD 955---4Ghz
Motherboard MSi GD70
Cooling OcZ Phase/water
Memory Crucial2GB kit (1GBx2), Ballistix 240-pin DIMM, DDR3 PC3-16000
Video Card(s) CrossfireX 2 X HD 4890 1GB OCed to 1000Mhz
Storage SSD 64GB
Display(s) Envision 24'' 1920x1200
Case Using the desk ATM
Audio Device(s) Sucky onboard for now :(
Power Supply 1000W TruePower Quattro
would that block fit on am2?
sneekypeet
not-so supermod
29,636 (4.33/day)
Heatware
334 0 0
System Name EVA-01
Hey DM look at post #13 ,He has linked to the apropriate hardware to convert it!
FREE BUMP!
DaMulta
16,168 (2.40/day)
Oklahoma T-Town
Heatware
11 0 0
Storage SSD 64GB
Yea I know, I just wanted to ask again.
hat
Enthusiast
21,750 (3.28/day)
Ohio
Heatware
20 0 0
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
A bit of topic... you write like a girl =)
Anyways, killer hardware, good to see it going into the hands of others who know how to use it!!
3,278 (0.49/day)
who writes like a girl??
and exactly who was the "know how to use it!!" part directed at? I certainly hope not me ;)
Wile E
Power User
24,318 (3.64/day)
Heatware
9 0 0
I think he might be referring to me and DM, and our TEC misadventures. lol.
