Furmark scores ?
Status
Not open for further replies.
1,042 (0.17/day)
Transylvania (RO) working in Barcelona (ES)
System Name Rzyen X
Processor Ryzen 7 7800X3D ^ PBO -30 ECO mode 1.15v SOC
Motherboard Gigabyte B650 Gaming X AX
Cooling Arctic Liquid Freezer II 420 A-RGB
Memory 32Gb Adata Lancer XPG 6000Mhz CL30 EXPO 1.260v
Video Card(s) Sapphire RX 7900 GRE Nitro+ OC - core 2800Mhz / mem 2600Mhz
Storage 1TB WD SN850X + 2TB WD SN770 + 2TB Adata Legend 850
Display(s) ViewSonic ColorPRO VP2776 - 27" 1440p^165Hz
Case Phanteks P600S White
Audio Device(s) Logitech Z2300 + Skullcandy Crusher Evo
Power Supply EVGA T2 1000W Titanium
Mouse RedDragon M686 RGB
Keyboard SPC GK630K Tournament
Software Windows 11 PRO
Benchmark Scores CB R23 - 18.703 pct / CB 2024 - 1.159 pct
I wonder if someone made a chart with Furmark scores in 1080p preset?
18,584 (2.68/day)
System Name AlderLake
I don't think that people on this forum wan't to try that out. Not many at least....
1,042 (0.17/day)
System Name Rzyen X
It's just a 60 sec benchmark, no big deal... just to compare score...
18,584 (2.68/day)
21,535 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
It is among the most stressful benchmarks around with a higher probability of burning up your card than most.
That said, most cards literally have current limits set in bios now, so all you're doing is a throttlefest. Pointless honestly, but I don't see the harm.
1,042 (0.17/day)
System Name Rzyen X
OK, here's mine at 1080p everything stock (cpu and gpu)
2,570 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 2X D5T Vario, XSPC BayRes, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01
Video Card(s) MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724
Storage Samsung 990 PRO 1TB M.2
Display(s) LG 32GK650F
Case Thermaltake Xaser VI
Mouse Logitech
Keyboard Logitech
Software Win11PRO
GTX970SSC with custom BIOS.
64K
6,773 (1.72/day)
Processor i7 7700k
Motherboard MSI Z270 SLI Plus
Cooling CM Hyper 212 EVO
Keyboard Logitech G105
19,371 (3.54/day)
exactly.. your card will drop boost bins running furmark. I wouldnt touch it with a 10' pole..its not testing clocks it would hold in game due to the throttling amd dropping of bins. I tested it myself...when i game i hold xxx clock. Running furmark STOCK, it holds the clocms several boost bins/dozens of mhz lower.
Find something else... ;)
12,325 (2.26/day)
Oregon
Keyboard EVGA / Logitech K400
4,267 (0.67/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
There we go:
1,042 (0.17/day)
System Name Rzyen X
Ok so this test its freaking scares peoples, so a 60 second benchmark can kill your GPU? I'm against Furmark testing to, but only when you stress your GPU for 10-20 minutes or above, in 60 second i think no harm is done to the GPU, because the max temp don't even reach close to the temps in Uningine benchmarks... Mine reached 67C and in Heaven i got 74C... Good luck :)
18,584 (2.68/day)
It seems people rather run other benchmarks, unigine is good, just not this furmark one.
64K
6,773 (1.72/day)
Processor i7 7700k
It's not about being scared it's about irrelevance. Modern GPUs throttle the clocks when Furmark is detected. So what's the point?
the54thvoid
Super Intoxicated Moderator
13,109 (2.39/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
In Scottish parlance, it tests 'fuck all'. It's useless, it's not a benchmark that actually measures anything. Might as well create a thread about the weight of graphics cards using kitchen scales.
It's a shit stability test and can cause problems. Given both AMD and Nvidia have safeguards to reduce power draw, it makes the test utterly redundant.
It's not 'fear' that stops people using it, its common sense.
3,024 (0.83/day)
i havent seen desktop GPU die from Furmark, but i have seen laptop gpu burn off from furmark. So i can say that using furmark on a laptop can result in GPU failure.
19,371 (3.54/day)
:toast::toast::peace::toast::toast:
Will the benchmark kill your card? Nope. Is this testing worthwhile? I say no on a couple of fronts...
1. This thread wasn't setup right. It will be a pile of results that is abhorrently inconvenient to navigate through and compare results. So, what's its point? To scan through pages and pages of results? Not my bag... perhaps others prefer this over an organized first thread which records scores and is good for comparing?
2. Its Furmark, nobody really gives a hoot about it in the first place.
3. Does the benchmark throttle out of the gate like the stress test does??? I'm curious, I don't know for sure. If it doesn't, then great, its valid... but see 1 and 2... :)
1,042 (0.17/day)
System Name Rzyen X
Ok... this thread can be CLOSED now... thanks :)
6,270 (0.91/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
That app test was known for frying out the VRM's and if I remember correctly it was AMD cards that were mostly affected.....So from reading here it seems GPU vendors are now aware of Furmark and have safegaurded their cards from that app frying the VRM's ......so if your looking to fry a card maybe just a rename of Furmark to something GPU friendly will bring back the VRM death option.
42,545 (6.67/day)
:slap::kookoo::banghead:Yeah keep on using the furmark virus!
2,100 (0.48/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
Kombustor. ;)
4,267 (0.67/day)
Sanford, FL, USA
Case Lian Li PC-Q25
Doesn't seem like it, my results after the name change was identical.
6,270 (0.91/day)
New York
Damn....looks like AMD got hip to the ole name change to GPU friendly apps......I remember we use to do this to get Crossfire working on games and benches that it wouldn't other wise or would make it run better bench results...looks like them days are over :confused:
6,881 (1.46/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
I should make a furmark dead/fried card list.
Status
