G.SKILL Announces High-Performance ENKI Series AIO Liquid Coolers
1,519 (0.88/day)
G.SKILL International Enterprise Co., Ltd., the world's leading manufacturer of extreme performance memory and gaming peripherals, is excited to introduce a new product line of all-in-one CPU liquid coolers, the ENKI series AIO. Named after the ancient Sumerian god of water, the ENKI series AIO is a custom-designed AIO CPU cooler that focuses on high cooling performance by eliminating heat-transfer bottlenecks and engineered to efficiently extract heat from the CPU, through specially-selected low thermal resistance thermal paste, across the custom-tuned convex copper cold plate, and into the high-density radiator via widened, low-evaporation coolant tubing. Available in 360 mm, 280 mm, and 240 mm radiator sizes, each ENKI series AIO includes 9-blade hydro-bearing cooling fans, ARGB lighting, and easy-to-install mounting bracket kits.
Custom-Tuned Convex Cold Plate & Stair-Shaped High-Density Micro-Fin Design
To achieve high-performance cooling and maximum contact with the CPU, the ENKI series AIO liquid cooler utilizes a custom-tuned convex cold plate design to minimize the travel distance of heat from the CPU through the thermal paste and into the solid copper cold plate. On the other side of the cold plate, stair-shaped high-density micro-fins are used to optimally guide the coolant intake-outtake flow for efficient heat transfer from the cold plate and into the coolant.
High Flow-Rate Coolant Tubing & High Density Radiator Piping
In order to quickly deliver coolant between the cooler head and the radiator, high flow-rate coolant tubes with 8 mm inner diameter are chosen for the task. Each coolant tube is also constructed with thicker rubber walls for low coolant evaporation and are enclosed in nylon-braided sleeves for durability. The radiator is designed with high-density piping, which increases the surface area to facilitate efficient heat dissipation from the coolant and into the fins for effective cooling. Specifically, the 360 mm and 240 mm variant is designed with 3~4 more radiator pipes than typical radiators, while the 280 mm variant has 6 more radiator pipes.
High Static Pressure 9-Blade Fan & Low Thermal Resistance Thermal Paste
The ENKI series AIO liquid cooler is equipped with high performance 9-blade hydro-bearing PWM cooling fans, selected for its high static pressure to maintain constant air flow. Included within the accessory pack, is a tube of server-grade thermal paste that features ultra-low thermal resistance, which enables quick heat transfer from the CPU to the copper cold plate.
Customizable ARGB & Product Availability
Each ENKI series AIO liquid cooler is equipped with 3-pin ARGB motherboard connectors, allowing customizable RGB lighting via motherboard lighting control software. Available in 360 mm, 280 mm, and 240 mm, the ENKI series AIO also comes with a 5-year limited warranty. This product line of AIO liquid coolers will be available via G.SKILL distribution partners in 2021.
Official Video
409 (0.24/day)
System Name Old friend
Processor 3550 Ivy Bridge x 39.0 Multiplier
Memory 2x8GB 2400 RipjawsX
Video Card(s) 1070 Gaming X
Storage BX100 500GB
Display(s) 27" QHD VA Curved @120Hz
Power Supply Platinum 650W
Mouse Light² 200
Keyboard G610 Red
G.SKILL! Liquid Coolers?! Interesting. Can't wait to see the TPU review of the 280 mm model.
1,005 (0.15/day)
Processor i9 10850k
Motherboard Asus strix Z-490-e
Memory G.SKILL Trident Z 4000mhz
Video Card(s) Asus STRIX RTX 3080
Storage 1tb Samsung 970 EVO,1tb hdd,750gb hdd
Display(s) Asus 27" 144htz 1440
Case Lian Li lancool 2 mesh
Power Supply Seasonic GX-850
Keyboard Logitech Pro
I’m in the market for an aio hook me up with results.
26 (0.02/day)
System Name Blacky
Processor Ryzen 5 5600
Motherboard Asus Strix B550-E wifi
Cooling Arctic cooling liquid freezer III 360 Argb
Memory 4x corsair vengance pro
Video Card(s) RTX 3080 Neptune OC 10G
Storage 2TB HDD Seagate+2tb patiot vp4100+256gb s40g
Display(s) Viewsonic VX2428J
Case pccooler c3 500tg black + Phanteks Fan
Power Supply Super flower V pro 1000w
Mouse CM Mastermosue pro l
Keyboard DIY 87 rgb outemu silent white
asetek oem?...
1,762 (1.01/day)
Besides putting their own spin in terms of the RGB design on the cooler, and also slapping their own brand name on it, I fail to see how this segregates itself from the horde of AIO coolers out there. Basically they are using the same OEM from the looks of it, and indeed looks like an Asetek design.
12 (0.01/day)
Denmark
Processor AMD Ryzen 3950X
Motherboard MSI MEG Godlike
Cooling NZXT Kraken X72
Memory G.Skill TridentZ Neo 3600MHz
Video Card(s) EVGA RTX 2080
Case Lian-li PC-O11 Dynamic
It is in fact not one of our (Asetek) designs :)
812 (0.41/day)
Processor Intel i9 13900KS Allcore @ 5.8
Motherboard z790 Apex
Cooling LT720 360mm + Phanteks T30
Memory 32GB @8000MT/s CL36
Video Card(s) RTX 4090
Storage 990 PRO 4TB
Display(s) Neo G8 / C1 65"
Case Antec Performance 1
Power Supply Prime Ultra Titanium 1000w
Mouse G502 X Plus
Keyboard K95 Platinum
Everyone seems to want to have AIO and Monitor products these days.
Hmm, I wonder where the insane profit margins are!? ;)
12 (0.01/day)
Denmark
I see, I stand corrected. Just a wild guess based on the design. :p Thank you for correcting me.
Oh not to worry at all :) Just figured I'd try and be helpful with clarification :)
Actually we always carry a list of current production units on our website :)
6,274 (1.53/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
Anutha day, ANUTHA boring, same ole same same AIO....
nuthin new here kiddies, back to nappy time now :)
17,444 (4.68/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710 (Red/Black)
That was a cool video though, not in market for one, but seeing the liquid through the tube first person style was pretty neat. never seen that before. I wonder if it was real, or just animated.
9,411 (3.40/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Even though there is nothing wrong with Asetek based AIOs I always get non Asetek models (Nepton 280) currently I am looking at the Silverstone Glacier or Alpahacool Eisbear Aurora. I will wait for a review on this one but it could be added to the list.
