G.Skill DDR5 32GB 7600Mhz Trident Z5 Royal - does not work on its frequency! help me figure it out
24 (0.20/day)
Kharkiv , Ukraine
System Name kitchen pc
Processor Intel Core i7-13700KF / Thermalright LGA1700-BCF
Motherboard Gigabyte Z790 AORUS PRO X (s1700, Intel Z790)
Cooling Asus ROG Ryujin III 360 ARGB White
Memory G.Skill DDR5 32GB (2x16GB) 7600Mhz Trident Z5 Royal Silver
Video Card(s) Asus ROG Strix RTX 4090 OC WHITE / Asus ROG Herculx XH01
Storage Kingston FURY Renegade 4TB + Kingston KC3000 3D 1TB + Kingston FURY Renegade 2TB
Display(s) Asus 4K 32" PG32UCDM / ASUS ROG Aura Monitor Light Bar
Case Asus ROG Hyperion GR701 White
Audio Device(s) Beyerdynamic MMX 200 Wireless
Power Supply Be Quiet! Dark Power Pro 13 1300W / APC Back-UPS 2200VA AVR
Mouse ASUS ROG Chakram X Origin / Asus ROG Hone Ace XXL
Keyboard ASUS ROG Azoth Extreme
VR HMD -
Software WINDOWS 11 PRO
Benchmark Scores All games from 35 FPS and higher)
Hello everyone! First time on your forum.
Recently bought myself a new computer.
And the RAM works stably only at a frequency of 7400. At factory parameters and a frequency of 7600 - during testing the memory crashes on the 15th second.
Base voltage The system parameters are below:
>> Intel Core i7-13700KF 3.4(5.4)GHz 30MB s1700 Box (BX8071513700KF)
>> G.Skill DDR5 32GB (2x16GB) 7600Mhz Trident Z5 Royal Silver (F5-7600J3646G16GX2-TR5S)
The processor scored 75 points on the internal motherboard test - but this is a mediocre score (~90 is considered good), I don’t know if it’s worth paying attention to this indicator in my case.
The motherboard supports frequencies up to 8200+. There are profiles for RAM for each chipset manufacturer - but they do not provide stable memory operation.
7,264 (4.90/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
I'm gonna give it to you straight, there is a chance your processor cannot run 7600 - and this is further compounded by the poor motherboard choice. This claim that it supports 8200 is quite extraordinary - it's very unlikely that realistically, you will ever run anything at 8000 on a 4-dimmer motherboard.
My advice is apply XMP, reduce its frequency to 6400 and start increasing - testing on each step - 6800, 7000, 7200, and see what works for your chip and motherboard combo.
JrRacinFan
Served 5k and counting ...
20,124 (3.09/day)
Youngstown, OH
System Name Snow White
Processor Ryzen 7900x3d
Motherboard AsRock B650E Steel Legend
Cooling Custom Water 1x420
Memory 32GB T-Force Deltas
Video Card(s) PowerColor 7900 XTX Liquid Devil
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Tt CTE 600 Snow Edition
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Corsair K65 Mini
Benchmark Scores Avermedia Live HD2
I read up on that kit a little. Looks like there are quite a few others not able to get the rated speeds and the ram starts throwing errors around 7400. Best I can say is try @Dr. Dro 's advice with testing on each step up.
288 (1.02/day)
System Name Crapostrophic
Processor AMD Ryzen Z1 Extreme
Motherboard ASUS Custom PCB
Cooling Stock Asus Fan and Cooler Design
Memory 16GB of LPDDR5 running 6400mhz with tweaked timings
Video Card(s) AMD Radeon 780M APU
Storage 2TB Aorus 7300 Gen 4
Display(s) 7 Inch IPS Display @120hz
Case Plastic Shell Case designed by Asus
Audio Device(s) Asus ROG Delta
Power Supply 40WHrs, 4S1P, 4-cell Li-ion with a 65W PD Charger
Mouse Asus ROG Keris Wireless
Keyboard AKKO 3098B hotswapped to speed silver pro switches
Software Windows 11 Home (Debloated and tweaked)
Using the same board here, your IMC quality is a major factor for running higher memory speeds.
link to pic: https://i.ibb.co/fpMXfX0/Screenshot-2024-09-16-204629.png
is something wrong with the site.. -_-'
24 (0.20/day)
Kharkiv , Ukraine
VR HMD -
Я скажу вам прямо, есть вероятность, что ваш процессор не сможет работать на частоте 7600 - и это еще больше усугубляется плохим выбором материнской платы. Это утверждение, что он поддерживает 8200, довольно необычно - очень маловероятно, что вы когда-либо запустите что-либо на частоте 8000 на материнской плате с 4 диммерами.
Мой совет — используйте XMP, уменьшите частоту до 6400 и начните увеличивать ее, проверяя на каждом шаге — 6800, 7000, 7200, и посмотрите, что подойдет для вашей комбинации чипа и материнской платы.
There is a profile for my memory at 7600. But it doesn't fit - when you set it up, memory crashes during a load test. Therefore, I think to experiment with increasing the voltage to 1.4 - 1.47 or 1.5. The motherboard supports memory up to 8266 (you can see it on the website) and there is a section where the guys overclock the memory on this board. Indicating the memory manufacturer, timings, and voltage.
24 (0.20/day)
Kharkiv , Ukraine
VR HMD -
JrRacinFan
20,124 (3.09/day)
Youngstown, OH
Storage 20+ TB
I agree with you, but it looks like your kit is different from the kit in question.
288 (1.02/day)
its a 2x24GB 7600MHZ G.Skill kit..M-Die, his is probably A-Die..
a bit relevant, but my reply still stands, not all chips are guaranteed to run whatever speeds the sticks the user buys as the higher memory frequency highly depends on IMC quality and other factors as well, I have binned all my chips and all so far runs 8000MT's and beyond (2x13900KS, 1x14700K, 1x13600K 1x14600KF all binned using the ROG z790 Apex Encore)
Memory overclocking on Intel doesn't just depend on the memory VDD and VDDQ.
I also have an A-Die G.SKill kit (2x16GB at 6400MT's) that run 8200MT's on the Apex but rarely runs 7600MT's on any of my 4-dimm Boards (z690-E Strix, Maximus z790 Extreme, Gigabyte Aorus Pro X)
7,264 (4.90/day)
São Paulo, Brazil
Such frequency is extremely diffficult to achieve on a motherboard that has four memory slots. Not to mention many processors have difficulties achieving these speeds themselves, especially those that are sold as Core i5 and Core i7. It is not guaranteed on a Core i9 either. I cannot lie - it is possible that you will never reach 7600 on this motherboard and processor combination.
I would consider 7200 to be more realistic and acceptable for 24/7 operation. However, it shouldn't be a big cause for concern, the performance difference between these two speeds should be rather negligible.
The Apex Encore is a game changer, though. This motherboard is supremely good and specifically engineered to achieve the highest memory frequencies out there. The volts I needed to get 6400 stable on my MSI Z690 Ace were awful in comparison with the Apex Encore and it's the exact same CPU that was used on both. Even then if the CPU itself is a dud, not even this motherboard will save it
5,847 (0.80/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Razer Pro Type Ultra
288 (1.02/day)
I made an edit above, either ways, I do own several 4-dimm boards and compared to the voltages used on the Apex Encore, they are really not far off when being used on my 4-dimm/2DPC boards, like I said, its always the IMC, all my chips are binned with an IMC grade around 80 (89 being the highest grade so far on a sample of 13900KS) and above, IMC grade below 80 will only run 8000MT's at pure brute voltages, while lower than 8k will be a walk in a park.
24 (0.20/day)
Kharkiv , Ukraine
VR HMD -
I repeat, at a speed of 7400 it works PERFECTLY!
10,909 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6000 1:1 CL30-36-36-96 FCLK 2000
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
Increase SA voltage.
Try 1.30v and run xmp test. Then bump up to 1.32
288 (1.02/day)
for that frequency 1.25 should be plenty, also not just the SA voltage, also other voltages such as the VDDQ_TX(CPU) and the VDD2(IMC)
someone who doesn't know what those voltages are for might fry their chip, so do change the values with caution and do it accordingly.
10,909 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
It's not - on my setup 13799kf XMP 7600 is only stable at 1.29-1.3v. If i set it to auto and let it float back to 1.25 it BSODs.
288 (1.02/day)
different boards react with voltages differently, might be that much for your case, might be less for others, on my Strix z690i, I run 7400MT's on the 2x16GB A-Die kit with the 13600K I binned with just 1.25v on SA and IMC around 1.2875v(BIOS) with the sticks on 1.45vdd/vddq with CL 34, CL32 needs a tad bit more like around 1.48v.
10,909 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
I mean that's fine and all but 1.45v DDQ/TX usually auto sets with high-end XMP, so typically those don't need to get pumped - from FAFO i can tell you what worked to stabilize my 7600mhz kit on a 13700k.
288 (1.02/day)
your IMC might as well be capable, its not the board or the sticks, point is its always and will be the quality of the IMC. I have seen 13700K's that does 8k MT's its nothing new if you know how IMC binning works, and not play the russian roulette on silicon lottery.
JrRacinFan
20,124 (3.09/day)
Youngstown, OH
Storage 20+ TB
Yup! I agree with you. The JEDEC standards are anywhere from 4000 to 6400 at 1.1v on DDR5. So when you get these highly clocked they are rated UP TO **xxx insert speed here**, essentially overclocking out of the box.
10,909 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
very loosely the 4 voltages are:
1. SA - system agent is the primary voltage that controls volts to the IMC
2. VDDQ-TX - signal strength between IMC and Ram kit
3. VDD2- (DRAM) volts
4. VCCIO - signal strength between IMC and CPU
The 3 bottom ones SHOULD already be preconfigured and should auto set correctly by the board and XMP (1.4V in your case for VDD), VCCIO is the one that will increase thermals on the CPU - to stabilize on a weaker IMC or a droopy board you will need to increase SA volts or loosen the timings/speed on the kit, VDD shouldn't really do anything if the kit is stable at XMP - and those kits *should* have been QA'd at the factory.
In some cases the board can autodetect and yeet subtimings too tightly (TRFC etc.) - but you shouldn't have to touch those at XMP. Bios updates can help with this and memory compatibility in general, so do make sure you're on the latest bios as well.
ir_cow
4,623 (0.77/day)
USA
I'll throw my hat in the ring here. Testing a fair amount of motherboards, those QVL lists are BS. It is just a dick measuring contest for vendors. 7400-7200 is more likely the "highest" stable frequency for that Gigabyte Z790 AORUS PRO X with 2 DIMMs. These QVLs are done with a golden sample CPU and without regards to the CPU voltages needed to reach those speeds. Sure 8200 MT/s works with System Agent at 1.5 V, but that's not going to be safe long term.
That being said, lets assume 7600 MT/s will work. You most likely have to adjust the CPU voltages yourself.
Try:
SA: 1.25V
VDDQ-TX: 1.35V
VDD2: 1.35V
If it works / passes memory stress tests, lower the SA first to 1.2V. If not raise it to 1.3V Go again. Pass and now lower the other two to 1.3V. Repeat until you have the lowest voltages each for all 3.
For reference with the ASUS Z790 Apex I only need SA: 1.15V VDDQ-TX: 1.25 VVDD2: 1.25V for 8000 MT/s. One of the benefits of a 2 DIMM slot motherboard, you get away with lower voltages.
I had a different experience. I need 1.35 SA for 4slot or more for 8000 MT/s, with only 1.15v needed for Apex. Similar for TX and VDD2.
Igor shown that the MP value is meaningless. Mine a 72, yet 8400 is stable and 9000 boots. I had another 14900K and it could barely do 8000 and it had a 82 score.
24 (0.20/day)
Kharkiv , Ukraine
VR HMD -
Try:
SA: 1.25V
VDDQ-TX: 1.35V
VDD2: 1.35V
Hello ! tnank you ! Today i will try ! I’ll write about the result, definitely!
288 (1.02/day)
the Aorus Pro X sample I have with my 13900KS (IMC SP 80) only needed 1.27v (on BIOS, but reads out 1.25v).
technically yes, I just simply enjoy doing things overboard, coz why not?
depends if you have a sucky IMC and intends to use it on 2DPC boards then you're probably brute forcing voltages all over, its not totally useless IMHO, my chip with an IMC SP of 89 does things on the Apex Encore very easy, same with the Aorus Pro X where it was 1st tested, on the Aorus Pro X, it uses a tad more less SA and IMC voltage to re-train every boot stably on 8K MT's.
I have had a turd IMC before (IMC SP 72) and that was never retrain stable even with brute forcing voltages, even on the Apex Encore it required a ton loads of voltage but to no avail can't even finish a 30-minute y-cruncher VST/VTT run. I set my baseline to IMC grade 80 since of all the samples with this IMC quality, they all ran 8k MT's on the Pro X and on the Encore, they are also guaranteed to run 4266 MT's DDR4 on Gear 1 on my Z790-A Strix D4 board with either a Hynix DJR kit or a Samsung B-Die kit.
JrRacinFan
20,124 (3.09/day)
Youngstown, OH
Storage 20+ TB
288 (1.02/day)
When I said "you" I meant the general population. Not you specifically. LOL You sily.
hahaha..thought you were singling me out..hahaha..
