GameMax Introduces Infinity Pro Chassis With Dual-Chamber and Panoramic View
GFreeman
1,642 (2.42/day)
GameMax, an emerging brand of PC gaming components, including gaming cases and power supply units, is thrilled to announce the new Infinity Pro gaming chassis. The chassis features a dual-chamber layout with a panoramic tempered glass design. The GameMax Infinity Pro is perfect for showcasing the beauty of internal components and RGB illumination, with tempered glass panels on the front, side, and top of the case. The GameMax Infinity Pro comes equipped with five 120 mm PWM ARGB fans and a fan and ARGB controller hub, providing sufficient cooling for high-end gaming configurations right out of the box. Additionally, the fan and ARGB controller hub include 81 built-in lighting effects and support motherboard RGB sync technologies when connected to the motherboard's RGB header.
The GameMax Infinity Pro gaming chassis also supports back-connector motherboards such as the ASUS BTF motherboards, GIGABYTE STEALTH motherboards, and MSI PROJECT ZERO motherboards. For cooling, the chassis supports up to 360 mm radiators for liquid cooling. The chassis supports a maximum of 8x 120 mm fans. The GameMax Infinity Pro gaming chassis is available in black and white models.
Key Features
  • Spacious Dual-Chamber Design: Offers ample space with a divided layout for improved airflow and organization.
  • Three-Sided Tempered Glass: Full transparency on the top, front, and left panels, providing a clear view of internal components from all angles.
  • Compatible with BTF Motherboards: Despite the dual-chamber design, the case fully supports BTF motherboards.
  • Concealed Liquid Cooling Setup: Supports 360 mm radiators with concealed tubing routed behind the panel for a cleaner look. Recommended with GameMax extended tubing for optimal fit.
  • Pre-installed 5 ARGB/PWM Fans with Controller: Includes 5 daisy-chained ARGB/PWM fans featuring premium aluminium-textured hubs. The synchronized lighting creates a seamless flow effect. Comes with a remote-controlled hub offering 81 built-in lighting modes and motherboard sync support for enhanced customization.
Pricing and Availability
The GameMax Infinity Pro is now available at select partner resellers. See pricing below.
  • GameMax Infinity Pro - Black: $95.90
  • GameMax Infinity Pro - White: $95.90
2,455 (1.54/day)
Bulgaria
Front i/o hmm, one USB 3.0 type B and one type C(3.(1?,2?) gen2, but probably not x2. On webpage of product it's not clear .
1,998 (0.53/day)
Calabash, NC
System Name The Captain (2.0)
Processor Ryzen 7 7700X
Motherboard Asus ROG Strix X670E-A
Memory 32GB (2x16) Kingston Fury Beast CL30 6000MT/s
Keyboard Varies based on mood; currently Razer Blackwidow V4 75% and Hyper X Alloy 65
*zooms in* Are those....break out covers I see for the expansion slots? :wtf: :twitch:
Hell. No.
