- Oct 9, 2007
- 47,102 (7.58/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
GameMax, an emerging brand of PC gaming components including gaming cases and power supply units, announces the launch of the GX-1050 PRO BK and GX-1050 PRO WH 80 Plus Platinum power supply units, compliant with the ATX 3.1 and PCIe 5.1 standards and comes with a native 16-pin 12V-2x6 connectors. The power supply features a powerful 12 V rail designed for high-performance gaming systems supporting the latest high-end NVIDIA RTX graphics cards.
The GameMax GX-1050 PRO WH is the white edition that comes with matching flat white cables. On the other hand, the GameMax GX-1050 PRO BK is the standard black version with flat black cables. The GX PRO WH/BK's modular cable design create neat and clutter-free cable management having only the necessary cables installed.
Cable-Free Technology
The GameMax GX-1050 PRO WH/BK power supply unit is built using advanced manufacturing technologies. The Cable-Free Technology uses SMT manufacturing process that installs components directly to the PCB without the need of soldering and copper wires.
The GameMax GX-1050 PRO WH/BK PSUs are equipped with a 135 mm Silent FDB Turbo Axial Fan that delivers more airflow and cooling at lower noise levels compared to traditional fan designs. The Fluid Dynamic Bearing runs silent and offers longer lifespan. The PSU features intelligent temperature control allowing it to run silently at low loads.
Features
Pricing and Availability
The GameMax GX-1050 PRO WH/BK 80 Plus Platinum power supply units are now available on GameMax Amazon stores and partner resellers for US$159.99 MSRP.
Features
- Black and White models to color-match your gaming PC
- 80 Plus Platinum Certified
- ATX 3.1 and PCIe 5.1 compliant
- Modular Cable Design with Flat White Cables
- Native 16-pin 12V-2x6 connectors with 600 W maximum power
- High-Quality 105°C Japanese Nichicon Capacitors
- Tight EMI Protection
- 135 mm Silent FDB Turbo Axial Cooling Fan with Intelligent Temperature Control
- Cable-Free Technology
- Multi-Layer Protection: OVP, UVP, OPP, OCP, SCP, OTP
