Games Keep Crashing
Durvelle27
6,780 (1.52/day)
Memphis, TN
System Name Black Prometheus
Processor |AMD Ryzen 7 1700
Video Card(s) ASUS DirectCU II R9 290 4GB
Mouse Logitech Trackman
Keyboard Logitech K350
Software Windows 10 EDU x64
Hey guys I need some help. I've been having issues where games are crashing after a few minutes playing them. The PC doesn't shutdown but the games crash back to the desktop normally with a error code. And I can't seem to figure out why. I'm using a
AMD Ryzen 7 5800X
Oloy 32GB DDR4
Gigabyte RTX 3070 Ti
Gigabyte P750GM
95Viper
Super Moderator
12,890 (2.21/day)
What error code?
Are you OCing anything?
All games? What about other software?
Durvelle27
6,780 (1.52/day)
Memphis, TN
What error code?
I can't remember as each game has it's own error code
everything is stock
Yep just about all my games
Durvelle27
6,780 (1.52/day)
Memphis, TN
Weirdly just in Warzone the GPU never went over 68 Degrees which is very strange. The CPU never breaks 70
95Viper
Super Moderator
12,890 (2.21/day)
I, really, do not think any of those errors are the problem, they are, mostly, dealing with windows internals.
The 3011 and 3012 are errors in the performance counter resource data.
The 455 error is another database error.
I, believe, lynx29, and weekendgeek, are headed in right direction.
2,830 (2.12/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~1800 Video Games
your PSU is very well known for blowing up, killing hardware and being incredibly bad in basically every single way.
it probably can't handle transients of the 3070 ti
get rid of this time bomb asap!
2,914 (0.52/day)
MN
System Name Personal / HTPC
I'd also peek in the System log of the event viewer - if you're having driver issues, those errors would be reported there.
Next time a game crashes, take a screenshot of the error message.
Durvelle27
6,780 (1.52/day)
Memphis, TN
Don't have the budget for a new PSU atm
No errors under systems
1,131 (0.89/day)
Bavaria ⌬ Germany
System Name ✨ Lenovo M700 [Tiny]
I second that. Your PSU is a potential fire hazard which could kill other PC components (Gamers Nexus ended up with a grilled GPU), in the worst case it could even burn down your house. :shadedshu: I would try to get a replacement as soon as possible. Push for a RMA of the GP-P750GM. I wouldn't leave your PC on unattended, esp. at night.
But it could also be this issue: A great day for DRM as Denuvo lapse renders tons of games temporarily unplayable
Do you get problems in certain games (with Denuvo) or any game?
8,082 (1.36/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
Do you have the budget to replace your entire system?
May I suggest keeping an eye on this as it's out of stock at the moment. W1zard recommends a 650 watt PSU for the 3070 Ti.
Seasonic CORE GM-650 $40 after $15 MIR
Maybe you can demand a refund on that Gigabyte PSU?
Durvelle27
6,780 (1.52/day)
Memphis, TN
May I suggest keeping an eye on this as it's out of stock at the moment. @W1zzard recommends a 650 watt PSU for the 3070 Ti.
I've had the PSU going on 1 year now so don't think a refund is possible
7,425 (1.77/day)
You could try with a (large) retailer especially if it's Amazon or maybe even Newegg?
1,131 (0.89/day)
Bavaria ⌬ Germany
There's a recall by Gigabyte for that PSU: GIGABYTE GP-P850GM & GP-P750GM POWER SUPPLY STATEMENT
Replacement will be handled directly by Gigabyte. Just contact their Gigabyte Support, if your PSU falls into the troubled range (see serial number).
Quote:
"Appendix 1 – Serial Number below can apply for Return and Exchange service
Model name:GP-P750GM: S/N From SN20243G001301 to SN20453G025430
Model name:GP-P850GM: S/N From SN20343G031011 to SN20513G022635"
There where apparently some instances where they refused the RMA, even though RMA criteria where met. So if they try that on you just contact GarmersNexus, they can help to put pressure on Gigabyte. Btw. even though your PSU did run fine for one year, it just needs one instance where “Over Power Protection” (OPP) is triggered (f.e. benching or after installing a more power hungry GPU), they next time you turn on your PC your PSU will turn into a fire cracker. :cool:
Durvelle27
6,780 (1.52/day)
Memphis, TN
My serial number does fall in the range actually
2,830 (2.12/day)
Germany
because it's almost every PSU they made until a couple months ago...
get rid of that thing before it kills your 3070 Ti or even you when it violently blows up and sets things on fire.
Durvelle27
6,780 (1.52/day)
Memphis, TN
I just tested Warzone again and got code Dev 6328
tabascosauz
8,025 (2.37/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
I hit Dev 6328 specifically, on multiple occasions, when running unstable memory back on my CJR, before I understood that tRCD/tRP 18 @ 3600 for Hynix is basically asking the impossible. At 3600 it's probably not Infinity Fabric that's being the problem, but you may want to run TM5 or HCI to make sure XMP of 3600CL18 is actually getting enough VDIMM at 1.35V. Many boards I've been through with Asus, MSI and Gigabyte, don't actually run the VDIMM they say they are in BIOS (quick look at the DRAM voltage sensor in HWInfo can yield very different results depending on board).
I've only gotten Dev 6328 as a result of memory, and it's by far the most common one I've seen. Gotten some other ones as a result of too aggressive a GPU undervolt in MSI Afterburner. Once I did get a Dev error due to a buggy game update and not as a result of hardware, but it was just once.
As much as I'd like to jump on the bandwagon crapping on Activision for their poorly coded game, I've not seen any game that is as reliable a RAM stress test as MW2019.
910 (0.64/day)
System Name 1. Glasshouse 2. Odin OneEye
Processor 1. Ryzen 9 5900X (manual PBO) 2. Ryzen 9 7900X
Motherboard 1. MSI x570 Tomahawk wifi 2. Gigabyte Aorus Extreme 670E
Cooling 1. Noctua NH D15 Chromax Black 2. Custom Loop 3x360mm (60mm) rads & T30 fans/Aquacomputer NEXT w/b
Memory 1. G Skill Neo 16GBx4 (3600MHz 16/16/16/36) 2. Kingston Fury 16GBx2 DDR5 CL36
Video Card(s) 1. Asus Strix Vega 64 2. Powercolor Liquid Devil 7900XTX
Storage 1. Corsair Force MP600 (1TB) & Sabrent Rocket 4 (2TB) 2. Kingston 3000 (1TB) and Hynix p41 (2TB)
Display(s) 1. Samsung U28E590 10bit 4K@60Hz 2. LG C2 42 inch 10bit 4K@120Hz
Case 1. Corsair Crystal 570X White 2. Cooler Master HAF 700 EVO
Audio Device(s) 1. Creative Speakers 2. Built in LG monitor speakers
Power Supply 1. Corsair RM850x 2. Superflower Titanium 1600W
Mouse 1. Microsoft IntelliMouse Pro (grey) 2. Microsoft IntelliMouse Pro (black)
Keyboard Leopold High End Mechanical
Agreed. Remove and replace the driver first.
Durvelle27
6,780 (1.52/day)
Memphis, TN
Thanks for that. Running a memory test now to see if that could be the issue
43,598 (6.56/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
I wouldn't power the PC on with that PSU in it. I suggest you try something else before it destroys hardware.
Durvelle27
6,780 (1.52/day)
Memphis, TN
Everyone keeps saying this but I don’t have a backup PSU to test
