Games Not Smooth and Tiny FPS Drops.
BeadyRoller
10 (0.01/day)
Hi guys, had this problem for a while now and it's driving me crazy.
I have high FPS in most games but even at high FPS the games don't feel smooth, it's hard to explain really. I may have 120FPS but it feels more like 40-50 sometimes, especially when looking around. It's sort of like screen tearing but not really and I wouldn't really class them as stutters either, it's just not... smooth, feels choppy. I don't know how else to describe it. Sorry I can't be more precise.
I also get small FPS drops in every game. Even if I drop from say 140-130 I'll get a tiny little stutter. It really ruins the immersion for me.
I've recently upgraded my PC to a 5600x and 3070 graphics card and the problems still persists.
Rest of my specs are:
B550 A-Pro Motherboard
16gb 3200mhz Corsair Vengeance DDR4 RAM
Corsair RM750 Power Supply
1TB 970 EVO M.2 Drive.
I even have a G-SYNC monitor, it's a DELL S2716DG 144hz. I have noticed that if the FPS goes higher than 144hz it goes really choppy which is weird.
Things I have tried:
Updated the BIOS.
Put V-SYNC on in Nvidia CP and off in the actual game.
Downloaded RivaTuner to cap FPS so it never dips below a certain number.
Lowered my monitor refresh rate to 120hz - funnily this seemed to have a positive effect but if it dips below 120 it starts to feel choppy again - this was alongside VSYNC being on in Nvidia CP by the way.
Checked RAM is running on XMP.
Monitored frametime using RivaTuner - the spikes are definitely correlating with choppiness on the screen.
Enabled Resizable Bar
Unplugged USB 3 cable from motherboard (read it worked for someone)
Tried the Blurbuster article of turning Vsync on as well as GSYNC in NVidia and off in game.
So yeah, I'm at a loss and it's really getting me down that I've spent all this money and it's not smooth. Really frustrating.
Anyone have any suggestions?
Appreciate any help, thanks.
11,880 (2.19/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Which nvme placement have you used.
I expect there's two.
2,721 (0.54/day)
Greece
Motherboard MSI B550 Tomahawk
Cooling ZALMAN CNPS9X OPTIMA
Case SHARKOON M25-W 7.1 BLACK
Keyboard Trust GXT280
If the PSU works well (voltages check would be good to be done firstly), then the nVME SSD could be the cause of it most than anything else.
474 (0.31/day)
System Name Dusty
Processor 5900x
Memory Corsair Vengence LPX 32GB
Video Card(s) MSI RTX 3070 Gaming X
Storage yes
Case Fractal Design Define R6
Power Supply EVGA SuperNOVA 750w
VR HMD Oculus CV1
Is Hardware-accelerated GPU scheduling in windows on or off?
Mine was on, previously, causing all games to halt every 55ms, like clockwork. Making every game and framerate feel like 20, even if the meters said 120.
BeadyRoller
10 (0.01/day)
https://ibb.co/c1Xbnqp
Just took a photo for you. I don't know if that's the right one or not?
How do I go about checking voltages?
Mine is on, will turn it off and see if that improves anything. Were you getting stutters as well?
11,880 (2.19/day)
Manchester uk
VR HMD Oculus rift
No that looks like it's in the right one, not that then :)
474 (0.31/day)
System Name Dusty
Processor 5900x
Storage yes
VR HMD Oculus CV1
Correct, I had games that ran at 120+ fps, but it felt like it was 20fps. I graphed it out using Nvidia FrameView in my case and found that the frametimes had a consistent spike at X ms whenever I played a game. Although I could not correlate it to any other measurments taken with hwinfo. These uneven frametimes made a high framerate feel like a slideshow.
It solved itself when disabling GPU scheduling in windows.
I do not recall my whole troubleshooting procedure or how I figured out to test that, but I remember that fixed it for me at least. So it doesnt hurt to try. Remember to restart after toggling it off.
BeadyRoller
10 (0.01/day)
Just had a go and unfortunately it's still happening. I really don't know where to go next. Could it be an internet issue maybe?
2,721 (0.54/day)
Greece
PSU voltages could be read from HWinfo. Another potential problem could be the monitor's cable being a low quality one with bad signal alongside freesync/g-sync being on/off.
BeadyRoller
10 (0.01/day)
Will order a new DP cable just in case it's that. What sort of thing should I be looking out for?
474 (0.31/day)
System Name Dusty
Processor 5900x
Storage yes
VR HMD Oculus CV1
You said you noticed that frametimes vary during these spikes, have you tried logging these things and taking a good look at them to see if you can correlate it to something else? Spike in frametime during a spike in CPU usage perhaps?
Are these spikes regular? (ie, every ~X time) or are they completely at random?
Internet should not matter in general, unless all your games are online and they are... weirdly made. Though it would help if you can list what games it happens in, and what games it does not happen in. I just hope one of the games is not warzone, because oh boy that game.
Doesn't hurt taking a peak in eventviewer as well. I recall a few years back I had a bad SATA cable that caused a hard drive to spasticly connect/disconnect and when that happened it caused stuttering.
If you could capture it occurring on video (shadowplay or the like is useful for that) could also be handy, since there are many different types of stutter and it always help to see it with ones own eyes as well.
1,697 (1.08/day)
Processor 5800X3D -30 CO
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
No game is completely stutter free, regardless of the hardware. This is especially true of fast paced multiplayer online games. What are your 1% and 0.1% lows during say 10 minutes of typical gameplay?
163 (0.14/day)
Processor 6900K @ 4.3Ghz
Motherboard Gigabyte x99 ultra gaming
Cooling H115i pro xt
Memory Tridentz 3200 32gb
Video Card(s) Galax RTX 4070
Storage 970 EVO 500gb
Display(s) AOC g2460pf
Case Non branded shit
Power Supply Corsair Rm550x
Mouse Logitech G603 Double click mode
Keyboard TGK205
Software Win 10
I'm facing this problem too, the games are on 80~160fps but seems like 30fps and curiously some times run very smooth. I realise this in dying light yesterday, when I look to one direction the frames are at 120fps but very choppy an when turn the camera 180º it runs total smooth. I tried to disable vsync and tried fast vsync too but sicerely I cant figure whats really happen, none of those atempts solve 100% and all games react different.
I returned to 472.12 driver, feels better but not solved :banghead:
I'm curious about the nvme question, how it cause stutters?
1,457 (0.34/day)
Australia
Did I just read this correctly? your on a 144hz monitor & your complaining its getting choppy above 144Hz?? I'd have thought pushing the system to go beyond the monitor's specs would cause problems, yes?
This is not like an OC cpu or gpu or ram, whereby one can test such things before running a game or something.
FreedomEclipse
~Technological Technocrat~
24,306 (3.75/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
If youre using windows 11. It's been well documented that that OS has been causing performance issues for AMD users
43,111 (6.73/day)
What model of vengeance do you have specifically?
Mussels
Freshwater Moderator
58,413 (7.89/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Updated the BIOS.
Theres a link in my sig where i found out network activity from my TV caused my games to stutter - sometimes the cause for unique issues is... unique. and weird.
Sometimes the issue is driver settings, sometimes its the display - and rarely, it's an external cause.
Can you try Nvidias Gsync pendulum demo, and test that out and see what ranges it stutters at? If you can make the stutter produce every time (make sure its fullscreen!) then you can begin tweaking monitor settings and PC settings to eliminate it
Main things to try:
Make sure you're actually at the correct resolution and refresh rate at the desktop
Make sure all games and programs are tested in true fullscreen, not windowed or borderless.
Gsync off
Vsync off (tearing is fine during testing)
Quit all programs with overlays. RTSS caused me plenty of issues in the past, being bundled with afterburner.
Check monitor settings - mine has a bunch of settings that make things garbage, like an aim stabiliser that brings in massive smearing, or an overdrive setting that... adds smearing.
1,576 (0.23/day)
The Gulag Casino
System Name ROG 7900X3d By purecain
Processor AMD Ryzen 7 7900X3D
Motherboard ASUS Crosshair X670E Hero
Cooling Noctua NH U12A
Memory 64Gb G.Skill Trident Z5 neo RGB 6400@6000mhz@1.41v
Video Card(s) Aorus RTX4090 Extreme Waterforce
Storage 990Pro2Tb-1TbSamsung Evo M.2/ 2TbSamsung QVO/ 1TbSamsung Evo780/ 120gbKingston Now
Display(s) LG 65UN85006LA 65" Smart 4K Ultra HD HDR LED TV
Case Thermaltake CoreX71 Limited Edition Etched Tempered Glass Door
Audio Device(s) On board/NIcomplete audio 6
Power Supply Seasonic FOCUS 1000w 80+
Mouse M65 RGB Elite
Keyboard K95 RGB Platinum
Software Windows11pro
Benchmark Scores [url=https://valid.x86.fr/gtle1y][img]https://valid.x86.fr/cache/banner/gtle1y-6.png[/img][/url]
definitely sounds like a software/configuration issue.
I'd follow Mussels advice above. Good luck with it... I'll keep my eye out for this kind of problem.
Ive read that going into your Bios and selecting Above 4G Decoding can solve this hitching issue.
Although you've probably already done this Having set resizable BAR etc.
It could also be something to do with HPET High Precision Event Timer. You can download WinTimerTester and compare your results.
From Google - Search "Device Manager" on your PC. Scroll down to "System Devices" in the the sub-menu. Scroll to "High Precision Event Timer" and click it. Click "Actions" at the top of the window, and from that pop-up menu click "Disable".
Hope this helps. :toast:
21,624 (3.40/day)
Olympia, WA
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
Not since the fixes. I've yet to see anyone complain about it in actual use since they were pushed out.
FreedomEclipse
24,306 (3.75/day)
London,UK
21,624 (3.40/day)
Olympia, WA
System Name Pioneer
I can't say I (or anyone here on this forums W11 theead with Ryzen) have experienced anything like that. Odd. Maybe a bug with older AGESAs or something?
BeadyRoller
10 (0.01/day)
The spikes are at random, sometimes they can be 5 minutes in between each one, sometimes a minute etc. I should add these hitches aren't huge stutters but just enough to be very noticeable. It's got to the point where I'm looking out for the little stutters rather than enjoying the game. Will check Event Viewer and also get an example recording for you when I get a chance.
The games I play are DayZ, PubG, Warzone, Tarkov and Halo. Happens in every single one of them. Haven't installed any other games yet to test.
I appreciate that and if it was just happening in a few games I'd just put it down to the games but is every single one which makes me believe there's something happening somewhere in the background.
I obviously don't understand how these things work that's all. I'm not complaining, I just didn't realise things got choppy above 144fps.
Using Windows 10.
I THINK it's these "Corsair CMK16GX4M2B3200C16 Vengeance LPX 16 GB" but I'll double check that when I get a chance.
Main things to try:
Gsync off
I came across that when I did a Google search on the matter. Must have been your post! What did you do to check? Did you just have to unplug your smart TV every time you used the PC or something? I've checked Device Manager and there doesn't seem to be any devices connected that shouldn't be from what I can see.
Will give the pendulum thing a go, cheers.
Yeah, when I enabled BAR in the BIOS it automatically enabled 4G as well and didn't fix the issue.
Had a go at trying to disable HPET, couldn't find the option in my BIOS though, presumed that meant it was disabled as standard. Did disable from Device Manager. Also tried a command I saw on YT but didn't work for me, presume because it's already disabled.
163 (0.14/day)
Keyboard TGK205
Software Win 10
So I made some changes here and it seems to work well. I disable gsync, updated manualy monitor driver with aoc file from their site and disable GPU scheduling. Tried it on WWZ, FC new dawn and SOTR and it seems much better!
FreedomEclipse
24,306 (3.75/day)
London,UK
That 16gb ram you have. Is it two modules or just one?
