Games still changing on PC
38 (0.38/day)
Hungary
System Name PC
Processor I5 12400f
Motherboard Asus TUF b660m plus wifi d4
Cooling 3 intake, 1 outtake (these comes with the case) , intel stock cpu cooler ,
Memory G.skill ripjaws 2x16gb 3600mhz ddr4 (F4-3200C16D-32GVK)
Video Card(s) Manli rtx 3070ti
Storage Kingston SNV2S 1000gb
Display(s) Dell g2723H
Case IRID 503 ARGBv2
Audio Device(s) Including with monitor
Power Supply COOLER MASTER mpe-7501-acabw (750W)
Mouse Logitech g502 lightspeed
Keyboard Hama urage exodus 900
VR HMD NA
Software Windows 11 home (now)
Benchmark Scores Not benchmarked.
I don't know why, but the games change on my computer. It's 100% not just me. They change in a way that, for example, sometimes the input lag is more, sometimes less, but I don't adjust anything. For example, I restart the computer or it's different after shutting it down. They only change when I restart the game, but not always. For example, I just went away for a few days and unplugged my computer by unplugging it from the power strip. When I turned it back on, everything was different, but in the BIOS everything was the same, so it's not CMOS. In addition, I unplug it every day because I can't sleep, the light would be too bright. I know you can turn it off, it's already a habit. I've tried a CMOS reset. There was a time recently when I replaced ethernet with wifi, to see if that was the problem. It seemed to work for about 2 days, and then I started experiencing these problems again. Input lag and in some cases lag too. Maybe the problem is that I'm not turning off the power at the power supply? Or is it that I'm turning off the power?
Hardware: RTX 3070ti Manli, I5 12400f, ASUS b660m plus wifi d4, G.skill 4000MHz Trident Z 32Gb and Idk exactly 750W bronze.
132 (0.02/day)
Pittsfield, Massachusetts
System Name Gaming rig
Processor Intel i7 7700K at 4.4GHZ
Motherboard Asrock Z270M-ITX/AC
Cooling Cryorig H7
Memory Crappy 16GB memory
Video Card(s) Zotac 3060ti undervolted at .850mv
Storage WD m2 Sata SSD + WD 10TB HD
Display(s) 27 inch LG 1440p 144hz + 27 inch Lenovo Thinkvision 1440p 60hz
Case Thermaltake Versa H18
Audio Device(s) Klipsch Promedia 2.1 speakers
Power Supply EVGA 600W
Mouse Coolermaster MM711
Keyboard Steelseries Merc Stealth
What exactly are you talking about? What is changing?
27,752 (6.67/day)
Are these appearing in the Windows Start menu? If so, this is the Windows Store downloading and install suggested games for you to try. Is that what you're talking about?
2,180 (1.13/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
Could be your router might need a restart or it’s on its way out
