Gaming Mice with vertical thumb buttons
921 (0.17/day)
SouthERN Africa
System Name inferKNIGHT
Processor Intel Core i5-4590
Motherboard MSI Z97i Gaming AC
Cooling Corsair H100i
Memory 2 x 4GB DDR3-1866 Crucial Ballistix Tactical Tracer (R/G)
Video Card(s) ASUS GTX 970 STRIX 3.5GB (+0.5GB? o.O)
Storage 1 x 256GB Cricial M550, 1 x 2TB Samsung 7200.12
Display(s) Samsung SyncMaster T260
Case Corsair Obsidian 250D
Power Supply Corsair RM750
Software Windows 8.1.1 pro x64
Hey there guys
So, it's been quite a while since I bought my Microsoft SideWinder X8 mouse and have been wondering if there is any comparable high quality gaming mice that also have vertical thumb buttons. I can't figure out why on earth this hasn't caught on, it's so much better. There are many great mice out there, but you either gotta bend your thumb right back to use the 'back' button for stretch it to reach the 'forward button, which is much, much less comfortable.
There gotta be more mouse manufacturers out there that jumped on the simple but great idea of having those vertically oriented, right? :wtf:
Fourstaff
10,060 (1.89/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
If you are willing to use Razer Naga and Logitech G600 then they techincally have "vertical buttons". I like the vertical arrangement on my X5, so I would like to see more of this too
921 (0.17/day)
SouthERN Africa
Hmph, so putting the MMO mice aside, I guess that basically means it's no surprise I'm turning up nothing then.
It's quite a mystery why this orientation hasn't taken over the conventional one, never mind having been completely omitted as it seems to have. I wouldn't say this is the best mouse, but those buttons are definitely excellent. It'd be nice to have some alternatives to choose from. :shadedshu
Mussels
Freshwater Moderator
58,413 (8.11/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
logitech G700, has four thumb buttons in a square-ish pattern.
INSTG8R
Vanguard Beta Tester
7,974 (1.11/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 2
Software Win 10 Pro x64
921 (0.17/day)
SouthERN Africa
I'm talking about something along the lines of (ignore the long macro button):
the logitech G700 isn't quite there:
newtekie1
Semi-Retired Folder
28,472 (4.19/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Simple, with a button orientation like that there is no place to rest your thumb that isn't on a button. Which means buttons often get pressed when the user didn't want to press a button. This design is certainly not better for most people, and it isn't hard to press the buttons on something like the G700, you don't have to stretch or bend your thumb back to do it.
TheMailMan78
Big Member
22,599 (3.62/day)
'Merica. The Great SOUTH!
Check the RAT 7.
921 (0.17/day)
SouthERN Africa
@newtekie1:
Not true at all. I rest my thumbs between the buttons and they actually form an ergonomic shape around my thumb. I have never ever pressed one of the buttons by mistake because they're firm (yet not stiff) and they're connected (as in the 2 buttons are a single piece with a hinge between the 2 buttons), which prevents pressing both at the same time & it not possible to press them when having your thumb between them.
@TheMailMan78: My one friend has a RAT7 & another a RAT9 (basically wireless RAT7), both of which I find to have horrific horizontal thumb button positioning that requires an uncomfortably sharp bend of the thumb to press, so that's way out, but I suppose your comment is more of sarcasm against n00bs.
TheMailMan78
Big Member
22,599 (3.62/day)
@newtekie1:
Honestly no. If you set it up with a higher palm rest and swing it back it fits nice. If you leave it "default" then your statement is 100% true. Its all in the configuration of your mouse.
The way mine is setup I dont even have to move my thumb and I can touch all 3 side buttons.
cadaveca
My name is Dave
17,233 (2.59/day)
Yes, but your mitts are the size of Christmas hams.:shadedshu He asked for vertical, anyway, and those buttons are horizontal. ;)
manofthem
WCG-TPU Team All-Star!
10,960 (2.23/day)
Florida
Processor 3900X @ 4.0
Cooling DeepCool Castle 360EX
Storage Sabrent Rocket Q 1TB
Display(s) LG 34UC88
Case Thermaltake P3
Mouse Logitech G900
Default wasnt too comfortable. Even with adjusting, I still haven't gotten it quite right. Right now, the back button is right around my thumb knuckle.
TheMailMan78
Big Member
22,599 (3.62/day)
Well then I'm confused on what hes asking. :confused:
manofthem
10,960 (2.23/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
The thumb buttons on RAT7 are horizontal and OP is talking about mice with vertical buttons, or stacked on top of each other. My old mouse was like that and I prefer it, too bad it died.
TheMailMan78
Big Member
22,599 (3.62/day)
Ah ok. Now I get it! Thanks! :toast:
5,662 (1.14/day)
System Name Space Station
Processor Intel 13700K
Motherboard ASRock Z790 PG Riptide
Memory Corsair Vengeance 6400 2x16GB @ CL34
Video Card(s) PNY RTX 4080
Storage SSDs - Nextorage 4TB, Samsung EVO 970 500GB, Plextor M5Pro 128GB, HDDs - WD Black 6TB, 2x 1TB
Display(s) LG C3 OLED 42"
Case Corsair 7000D Airflow
Audio Device(s) Yamaha RX-V371
Power Supply SeaSonic Vertex 1200w Gold
Mouse Razer Basilisk V3
Keyboard Bloody B840-LK
Software Windows 11 Pro 23H2
The only real difference of what MS does is they put your thumb in a position of constantly being bent back a bit when it's resting in the holding position, then you extend it forward to click either of the side thumb buttons. Most use a contoured resting spot just below horizontally placed buttons.
I don't see how moving your thumb forward a bit is any better than raising it up a bit. At least with the commonly used design your thumb stays extended roughly the same length, creating potentially less time required to feel for the buttons. I doubt MS peripherals will ever be considered more game worthy than that of Razer, Logitech, etc.
921 (0.17/day)
SouthERN Africa
@Frag Maniac: That is completely untrue, because I don't constantly bend my thumb at all. I simply have it always resting the over the buttons, with them right in the centre of the thumb. I never have to pull it back or extend it forward and, in fact, I'm looking to see if there are other mice for exactly this reason.
Moving my thumb up & down is a very natural thumb motion & doesn't cause RSI damage in the tendons above the first thumb joint. I always had a sore thumb before when using the horizontal thumb buttons and have never suffered any discomfort with the vertical ones.
In games requiring rapid button presses, people I play with/against were shocked how much faster one can execute the action with the buttons orientated vertically, so I think your speculation there is also quite a bit off.
5,662 (1.14/day)
It's only untrue for you, I was speaking more of their probable intended use than yours, which seems atypical to me. Like the poster above implied, it's not common that people would want to grip a mouse with their thumbs ON the buttons, causing possible inadvertent clicks, and if it requires more pressure to click than mouse gripping would activate, then clearly just clicking them repeatedly could cause discomfort.
I also find it odd you suggest gamers would prefer it MS' way when the vast majority of gaming mice sold are by other brands. Don't you think if they really preferred vertical thumb buttons more players would be buying the SideWinder?
Again, this is one person's opinion with the claims of a few friends agreeing against a market filled mostly with players whom buy the other mice. Now you can call that "speculation" all you want, but your argument sounds rather baseless in doing so.
I call these "crusade" threads. Someone falls in love with something that's atypical, then tries desperately to convince everyone the others are doing it wrong. The reason it comes off as a "crusade" is when others offer reasonable, rational rebuttals, the thread author goes off on a self righteous defense stance, often tossing around passive aggressive insults, as if we have to bow to his claimed wisdom or deal with his attitude. :rolleyes:
Get used to the fact that many aren't going to agree with you on this.
Fourstaff
10,060 (1.89/day)
Home
He is not the only one, I like my up and down Sidewinder too. Its just too bad that the Sidewinder is not a popular mouse (marketing maybe?), if you see Logitech or Razer or some other popular equipment makers pushing one out I think the adoption rate will be higher.
1,027 (0.23/day)
New Jersey, USA
System Name Current Rig
Processor AMD 7800X3D
Motherboard MSI x670e Tomahawk wifi
Cooling Artic Freezer II 360
Memory G.Skill 32gb ddr5 6000mhz
Video Card(s) AMD 7900XTX 24 GB
Storage Samsung SSD 980 PRO 2TB
Display(s) Alienware 3420DW 120 Freesync
Case LianLi Lancool III white non-rgb
Audio Device(s) Onboard ALC
Power Supply Corsair Shift 1000W
Mouse G502 Hero
Keyboard Ducky Shine 5
Software Win 11 64bit
Benchmark Scores The second best!
5,662 (1.14/day)
I didn't say he was the only one. I'm sure that mouse has it's own form of a cult following, but minimal at best compared to other designs. I also don't think it's a mere matter of brand loyalty. Gamers, esp ones that pay a fair bit for a high DPI mouse, are pretty picky about the features on their equipment too.
921 (0.17/day)
SouthERN Africa
@Frag Maniac: it is neither easy to mistakenly click, nor difficult to purposely click. It is difficult to explain without you feeling it for yourself, really.
As Fourstaff said, it's probably poor marketing at play more than other factors. Even I was skeptical about the MS brand 'til I felt a friend's X5 myself. One can hardly argue that something that relatively doesn't exist on the market, has a poor adoption rate.
I'm speaking from my personal opinion, not friends, and unless I'm mistaken, that's the point of these things called forums. I called out your "speculation" regarding the feel and behavior of the buttons, since I have felt both horizontal & vertical, and your comment was written as that of a person estimating the experience without having tried it; not that your arguing which is more common is speculation. Nothing passive aggressive or otherwise about that.
As for your claim that I'm on a crusade, notice that I started this thread asking if people know of any other such mice, not to declare they're the best. When none were found, I responded that I don't understand why that is so, because of it seemingly being a great alternative. From the looks of it, the only one that seems to want to be in opposition here is you, then proclaiming others to have attitude.
I don't know why you gotta come into the thread to try dominate the discussion by diverting it at a tangent like that. :confused: Please, if you're not interested in discussing what I'm asking about, move on, rather than tryna make a psych eval of me. :shadedshu
@Hilux SSRG: You and me both fear that day. ;) I was more asking if other manufacturers are making such mice. The X8 is the pinnacle among the MS mice, but I think other manufacturers could come up with even better. Just wonder why they haven't...
At the risk of being a "crusader", I'm thinking of emailing and hearing from a few manufacturers on whether they've considered such orientation. Never know, maybe they haven't and would. :rockout:
Mussels
58,413 (8.11/day)
Oystralia
I think you mean G700? :confused:
http://images.amazon.com/images/G/01/electronics/detail-page/SWX8_sidebuttons.jpg&tag=tec06d-20
http://farm5.static.flickr.com/4094/4894952413_9d804d91ab_o.jpg
yeah i meant 700, that was a typo.
and maybe not there.... its better ;)
TWO pairs of vertical buttons! (they're angled so you can never mistake them, or press the wrong ones)
921 (0.17/day)
SouthERN Africa
LOL, fair enough. Would love to see a G750, let's call it, with those buttons turned 90 degrees clockwise about the front top button though. :)
1,308 (0.20/day)
The reason why gaming mice look like they do is because, believe it or not, the market is extremely conservative. Microsoft does their thing and it feels quite alright if it fits your hands and stile of gaming. People with violent jerky motions might not like the fact that you have your thumbs over the side buttons, because the grip is slightly worse than if you had your thumb on a piece of rubber or coated plastic.
The other big factor in mice design is marketing, why do you think we have 8200 DPI mice now when most people really need under 1000 DPI for reaching absolute controle at their sensitivity level. Most of the niche market gaming mice (Naga, WoW mouse and so on) are made solely to promote the brand, the profit from those must be marginal at best.
