GE257AA SoundBlaster X-Fi XtremeGamer Audio Card (PCI) needed, or help me with an alternative sound card.
oldcomputeruser
1 (1.00/day)
Hi, I am an old computer user. I have an xw8600 HP workstation. Running Zorin 16 (Linux) os. modern graphics card, 500GB ssd with full ram all running well. I have no audio at all. Was told when I bought bare bones xw8600 workstation that motherboard audio had never worked. I thought I could add an old creative 24 bit sound card that was PCI appropreiate like a SB0410. HP data specs list just the GE257AA sound card from creative as compatable. any advice appreiated to restore any type of audio. Also I have 4 HDMI ports from my modern graphics card available. Can I use a HDMI port to create audio on a creative 2 speaker desktop system.
613 (0.12/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper, Logitech G600
Keyboard Razer Huntsman Elite
FreedomEclipse
~Technological Technocrat~
24,290 (3.75/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Yes and yes, but it depends if the speakers have an HDMi port for you to plug into.
There are a lot of soundbars (some made by creative) samsung and other audio manufacturers that will have a HDMi slot available for you to hook up to a laptop or computer otherwise you would need something like an AVR that sits in the middle of the chain that you can plug your HDMi and speakers into to output sound.
43,061 (6.72/day)
Need to find linux drivers for specific soundcards before you just buy 1, otherwise you'd need to create 1.
551 (3.32/day)
You may look into second hand usb audio interfaces.
My second hand USB-Audio Interface M-Audio AIR 192|6 works flawless with my gnu gentoo linux. Just a fancy name for an external sound card.
A bonus it's usb 2 connected. I assume you will have a usb 2 port, right?
Code:
[    6.120793] usb 7-2.4: new high-speed USB device number 4 using xhci_hcd
[    6.254112] usb 7-2.4: New USB device found, idVendor=0763, idProduct=410c, bcdDevice= 1.05
[    6.257184] usb 7-2.4: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[    6.260232] usb 7-2.4: Product: AIR 192 6
[    6.263266] usb 7-2.4: Manufacturer: M-Audio
[    6.501599] usb 7-2.4: Quirk or no altset; falling back to MIDI 1.0
Code:
Bus 007 Device 004: ID 0763:410c M-Audio AIR 192 6
QuickSpecs HP xw8600 Workstation
