[Case Gallery] GEAR's SM8
12 (0.00/day)
BC Canada
System Name SM8
Processor i7 4770k
Motherboard Asus Sabertooth Z87
Cooling XSPC Blocks and Bits Dual Pump Top and Tube Res
Memory 16GB Corsair Vengeance 1600 White LP
Video Card(s) 2 X GTX 670
Storage Kingston HperX 120GB SSD
Display(s) Benq XL2420T
Case Caselabs SM8
Power Supply Corsair AX850
Software Win 7
Specs:
Computer Hardware:
Case: Caselabs SM8
Fans: 2 x Coolermaster 120mm Front Intake Front Intake
Mobo: ASUS Sabertooth P67 TUF Thermal Armour
CPU: i7 2600K
Memory: 16GB Corsair Vengeance DDR3 1600 CL9-9-9-24
SSD: Kingston HyperX 120G(Boot Drive)
HDD: Seagate Barracuda 500GB(Storage Drive)
DVD RW: LG Super Multi
PSU: Corsair AX850 with Blue Sleeved PSU Cable Set
GPU: Nvidia GTX670 2-Way SLI
Cooling:
CPU: XSPC Raystorm Waterblock
GPU: XSPC Razor GTX 670 Waterblock x 2
Rad: XSPC RX480(Mounted Inside Top of Case)
Fans: Scythe Gentle Typhoon AP-15 x 8(Push/Pull)
Res: BitsPower 250mm Ice Blue Tube
Pump: D5 Vario x 2 on BitsPower Dual Pump Top
Tube: Primochill Brilliant UV Blue 3/8 ID-5/8 OD Blue UV
Fittings: BitsPower and TFC Silver
Fan Controller: G-Vans FC9 4 Channel @ 50 Watts per Channel
Temp. Sensors: Phobya Temperature Sensor G1/4 with C/F Display x 1 (Res)
Phobya Temperature Sensor x 1 (Case Internal)
Drain: BitsPower Mini-Valve(Installed on Pump Top
Cables: All Sleeved
Lights: NZXT Sleeved LED Cable Kit - 2M - Blue x 1
NZXT Sleeved LED Cable Kit - 2M - White x 1
XSPC 3mm LED-Blue Installed in CPU WaterBlock x 4
XSPC 3mm LED-Blue Installed in GPU WaterBlocks(1 ea.)
XSPC 5mm LED-Blue Installed in Res
Mods:
Painting of Case Parts, Water Cooling, Light Switch to Front Panel, Custom Power cable by gdesmo
The HAF 932 I previously had ran out out of room for Water Cooling. Decided on the SM8 and haven't looked back.
453 (0.11/day)
St. Louis MO
System Name Devil Red
Processor Intel i7 3820 @ 4.7GHz
Motherboard ASUS Rampage IV Formula x79
Cooling Water cooling CPU, MOSFET,SLI GTX 690
Memory Corsair 32GB DDR3 1866 MHz
Video Card(s) (SLI) ASUS GTX 690
Storage 120GB Corsair SSD/WD 300GB VRaptor
Display(s) HP ZR30w Pro 30" LCD
Case Corsair 900d Modded
Audio Device(s) X-FI
Power Supply Corsair AX1200i
Software 3DsMax, Maya, ZBrush, Photoshop Master Collection, and some more software
Great build. You have the same pump top I am thinking of getting. How do you like it?
9,871 (1.88/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
pretty clean build but i dunno some cables should hide behind the tray to make it cleaner
but anyway nice build
12 (0.00/day)
BC Canada
System Name SM8
Processor i7 4770k
Case Caselabs SM8
Software Win 7
Thanks much for the kind words...the dual pump top works like a champ although I could use a little more sound dampening under the brackets. The leftover XSPC rad gasket material works great for that. I hear ya on the cable routing but that always seems to a WIP...lol. I'm planning on putting in rigid tubing real soon and a 12v and 5v power terminals to get rid of the Molex connectors. Thanks again!!
12 (0.00/day)
BC Canada
System Name SM8
Processor i7 4770k
Case Caselabs SM8
Software Win 7
EpicMARINE1812
3 (0.00/day)
Nice But a little to much going on
Its nice over all but the inside is nicely put together you put alot of time into this but also alot of money into it aswell. i find cases like this to be a bit annoying honestly its overplayed to many people do it these days and i get it the cleanly ness of it all serves a purpose but is it really a mod anymore? i still give it a 8 because it does take time and alot of patience to do it but modded not really.
