Geforce 8800GTS 320MB picture and benchmarks
Darksaber
Senior Editor & Case Reviewer
3,090 (0.43/day)
Victoria, BC, Canada
System Name Meshlicious Monster
Processor Intel Core i5-10600T
Motherboard MSI Z490I Unify
Cooling NZXT Kraken Z53 with 2x Noctua Redux 1300 RPM PWM fans
Memory ADATA 16 GB 3200 Mhz DDR4
Video Card(s) MSI GeForce RTX 3070 Gaming X Trio
Storage TeamGroup 1TB NVMe SSD
Display(s) Asus ProArt 27" 1440P, 75Hz
Case ssupd Meshlicious with mesh side panels
Power Supply Fractal Design Ion 660 W Platinum ATX
Mouse Corsair Dark Core RGB Pro Wireless
Keyboard Microsoft Sidewinder X4 Keyboard
Software Windows 10 Home
TheINQ has a 8800GTS already and is willing to show us what it looks like before everyone else. The card looks quite similar to the 8800GTS 640MB. It has only 10 memory chips, each 32MB large. They are hynix hy5as573225a. It scores a solid 8800 points in 3DMark06
4,933 (0.74/day)
Hong Kong
Processor Core i7-12700k
Motherboard Z690 Aero G D4
Storage Plextor M10P 2TB
Display(s) InnoCN 27M2V
Case Thermaltake Level 20 XT
Source: TheINQ
It has "only" 10 memory chips:p
The benchmarks again proves that the 640MB and 768MB on the 8800 are simply useless and is a waste of cash.
jocksteeluk
1,455 (0.21/day)
The 13th room on the 13th floor of the 13th buildi
Processor custom dupont risk chip cpu prototype
Motherboard custom ibm x5 solid state carbon mainboard
Cooling industrial technologies prototype dupont custom heat transfer unit
Memory 6x 2gig prototype ecc hnc ddr4
Video Card(s) prototype low energy version nvidia 9 series unnumberd card
Storage 1tb solid state hdd
Display(s) 44 inch samsung plasma screen tv/monitor
Case custom ibm mobile home server case
Audio Device(s) custom Yamaha sound processing processor in spm format
Power Supply 1200watt deli cord custom made dupont type psu
Software sun unix/windows type v
is there any set release date for these cards yet?
Darksaber
3,090 (0.43/day)
NDA is lifted tomorrow afaik. and they are being sold already for 200 UKP in England.
2,648 (0.41/day)
UK
System Name Ma Biatch
Processor i7 860
Motherboard Gigabyte GA-P55-UD3A
Cooling Noctua
Memory 8gb (4x2gb) G-Skill
Video Card(s) GTX 470
Storage WD5000aaks raid0
Display(s) Sony Bravia 37" 1080p
Case CM 690
Power Supply Corsair HX520
Software Windows 7 Ultimate
£200 for an extra 3300 points in 3dmark, thats not bad, if anything i would consider getting one just for a top end dx9 card
Tatty_Two
Gone Fishing
25,944 (3.75/day)
Worcestershire, UK
Software Win 11 Home x64
Not really i would have to disagree a little, I know where you are coming from.....but, firstly in DX10 games (although I appreciate there are none at the moment!), on average, more memory is supposidly going to be used (more detail to be processed with SM4 and the like)as well as the fact that currently in High resolutions 256MB cards require a lot of system swapping which slows the game a little and can cause the "jutters".
To reinforce that, GRAW will not allow max settings and resolutions above 1280 x 1024 without 512MB of on board GDDR memory, also in FEAR for example, at just 1600 x 1200 resolutions a 256MB card at any given time is also having to swap and use up to 205MB of system memory on max quality, that means this 320MB card would still be swapping memory, the questions is, and may be more your point, "what effect does that have on gaming performance" well that varies, in some games very little, in some modern arithmatic or shader heavy games perhaps as much as 5-10FPS, more if you game at even higher resolutions.
2,555 (0.39/day)
Illinois
Processor i7 2600k@4.6ghz
Motherboard MSI z68ma-ed55
Cooling Silentx Extreem 120mm
Memory 2x4gb XMS 7-8-7-20 1600
Video Card(s) HD6870
Storage 2x128gb Kingston Hyper-X (Raid0), 2x750gb RE3 (RAID1), 2x750gb RE3 (RAID1)
Display(s) Soyo 24", Gateway 22"
Case Fractal Design Arc Mini 6x120mm fans.
Power Supply Zalman 750w
Software Windows 7
After all... That's what it is! :roll:
204 (0.03/day)
Columbia, Missouri
Processor Intel Core 2 Duo E6420 2.13Ghz 4MB @ 4.26Ghz
Motherboard Asus P5N32E 680i SLi LGA775
Cooling Scythe Infinity 120mm @ 1,200 RPM | Arctic Cooling 3x 120mm @ 1,000 RPM
Memory Corsair Dominator 2GB CL 4-3-4-12 DDR2-800 (PC2-6400) @ DDR2-1066 (PC2-8500)
Video Card(s) ATI Radeon X2800XTX @ 900/1350 w/HR-03 Plus
Storage Western Digital 150GB 16MB Raptor 10,000 RPM | Western Digital 2x 250GB (RAID0) 8MB Cavier SE
Display(s) Dell 2407WFP HD LCD Widescreen 1200p
Case Antec 900 w/modded top 200mm @ 800RPM
Audio Device(s) Creative X-Fi XtremeMusic
Power Supply Thermaltake ToughPower 750w 60A
Software Windows XP SP2 Gold Edition
So its a card for ppl who want even less futureproofing? Its only 10% less expensive than 640MB card, and if ur spending over 400$ for a card, whats the point of saving 50$?
2,648 (0.41/day)
UK
Processor i7 860
Cooling Noctua
Case CM 690
in the uk its actually about £60 cheaper than the 640mb which is £260 and £60=100$ so definately worth the saving, i reckon theres not going to be too much performance loss even at high res with 320mb over 620mb give it a month or 2 for prices to drop and thats probably going to be the first choice mid/high end budget card, when it drops to £150 i think ill consider getting one, just for DX9 as i said and maybe next year get a mid 2nd gen DX10 card
1Strive
682 (0.10/day)
Texas
System Name Back in Black
Processor AMD Opteron 180 @ 2.6GHz (Dual Core)
Motherboard Asus A8N-SLI Premium
Cooling All Antec Case Fans (3-speed and Quiet as they come.)
Memory 2GB DDR440MHz (Corsair XMS LED Series) 1GB x2 [Dual-Channel]
Video Card(s) 8800GTS G92 512mb (eVGA-745/1000) 9474 in 3Dmark06 at Defaults.
Storage 2 WD 74GB Raptors in RAID Zero for Vista. WD 250GB for XP and Storage
Display(s) Acer 22' widescreen. 1680x1050 res / 5ms
Case Antec Black Server Chassis / Logitec G7 Wireless-Laser Mouse
Audio Device(s) X-Fi Music w/ 5.1 Surround Sound Headphones
Power Supply Antec 500Watt ATX2.0 Modular
Software Vista Ultimate (64-bit) / Playing: Crysis in DX9 on XP @ 1680x1050 High with 30FPS
Benchmark Scores Over 9k in 3DMark06! That's better than 80% of all systems tested and logged according to 3Dmark's s
Okay. I would like to see that, considering that is what a normal GTS w/ 640mb of memory scores.
wazzledoozle
5,358 (0.72/day)
Seattle
Processor X2 3800+ @ 2.3 GHz
Motherboard DFI Lanparty SLI-DR
Cooling Zalman CNPS 9500 LED
Memory 2x1 Gb OCZ Plat. @ 3-3-2-8-1t 460 MHz
Video Card(s) HIS IceQ 4670 512Mb
Storage 640Gb & 160Gb western digital sata drives
Display(s) Hanns G 19" widescreen LCD w/ DVI 5ms
Case Thermaltake Soprano
Audio Device(s) Audigy 2 softmod@Audigy 4, Logitech X-530 5:1
Power Supply Coolermaster eXtreme Power Plus 500w
Software XP Pro
I thought it was supposed to be $300?
Wile E
Power User
24,318 (3.65/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
It's because 3dMark 06 doesn't need 640MB of ram at it's stock settings. It probably doesn't even need the 320MB, tbh.
Tatty_Two
Gone Fishing
25,944 (3.75/day)
Worcestershire, UK
Correct it is optimised for 256MB so there should be no difference in performance between a 256 and a 512MB card.....supposidly. Apart from that it runs the tests at a resolution of 1280 x 1024 and you dont really see any performance difference between 256 and 512 until you hit 16XX x 12XX resolutions.
1Strive
682 (0.10/day)
Texas
Now I see. Thanks for the clearing that up for me. No Problem. I bet that running CRYSIS at 1680x1050 and higher w/ all the options all the way up is going to be a problem w/ only 340mb. I am glad I got the GTS w/ 640mb and if that ain't enough for CRYSIS then I will just have to get anouther and run 'em in SLI.
1STRIVE Out:pimp:
Tatty_Two
Gone Fishing
25,944 (3.75/day)
Worcestershire, UK
1STRIVE Out:pimp:
I think your probably right, even FEAR for example on a 256MB card at 1680 x 1200 will use an additional 205MB of system memory to compensate with everything maxed, what that sysyem memory "swapping" actually means in performance terms varies I think but anyone would lose a few FPS, thereview below suggests up to 12FPS loss 256 > 512!! at a guess and the higher the res goes, the more swapping so the more lost FPS, take a look at the attached graph to get an idea, the graph is followed by the following comments:
"Now we are reaching the same levels of memory usage as HL2 in 2048x1536 with everything maxed out. Though the results show huge performance differences they simply cannot fully describe what I felt while playing the game. With 256Mb it was absolutely unplayable with stuttering at every turn, sometimes the screen would not refresh for half a second. This was blatant cache thrashing in action. In comparison the 512Mb card was behaving as it should, no stuttering at all. The average frame rate was low and it wasn’t very enjoyable, but it was a thousand times better than with the 256Mb card. The average frame rates for both cards are as follows:
256MB: 12.9 fps
512MB: 24.6 fps
That’s a 90.7% increase! F.E.A.R has shown itself to be the most demanding game for memory requirements out of all the games here. Add to this the intense use of pixel shader operations and you can easily see why it brings even the most high end machines to their knees.
Overall these results give us indications that we are no more than at the beginning of the transition from relying heavily on texture operations to arithmetic operations. We can’t all breathe a sigh of relief that ALU operations will mean we never need see a 1GB GPU, we will. But it does show that memory requirements might slow down and only increase when they are really needed thanks to pixel shaders. The future for video memory seems to be one of efficiency, but for the next few years I think we’ll see memory requirements continue as they always have done".
Mussels
Freshwater Moderator
58,413 (7.91/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
They might be too expensive now, but give it 2-3 months and this 340MB card will be a kickass upgrade for people on 256MB X1K or 7x00 cards.
6,959 (1.04/day)
Australia, Sydney
Finally nvidia does something I like T_T.
Well, what can I say? This is a wise desicion compared to the fact that they are going to release the 8900 probably needing a 1kilo TEC Unit, thinking about it, they might even have to supply support struts!!!
Is it just me or is it that the 8800 series when shipped, after removing the cooler looks second hand already.
desertjedi
42 (0.01/day)
If you look at this review, not only is the 8800GTS(320) NOT a kickass upgrade from X1K, an X1900XT(256) actually beats the 8800GTS in a significant number of the games tested.
WarEagleAU
Bird of Prey
10,812 (1.60/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
Spiffy, now, lets see the price and some benches on it.
Tatty_Two
Gone Fishing
25,944 (3.75/day)
Worcestershire, UK
Yes....good point but the 8800 series cards are designed for DX10 so when a DX10 game finally appears the 1900 wont get close which to be fair just reinforces my beleive that it's best IMO to wait for DX10 games to get here b4 upgrading.
