GeForce GTX 685 (GK110) Features 4GB 512-bit Memory, 25% Faster than GTX 680
2,668 (0.42/day)
Switzerland
Processor i9 9900KS ( 5 Ghz all the time )
Motherboard Asus Maximus XI Hero Z390
Cooling EK Velocity + EK D5 pump + Alphacool full copper silver 360mm radiator
Memory 16GB Corsair Dominator GT ROG Edition 3333 Mhz
Video Card(s) ASUS TUF RTX 3080 Ti 12GB OC
Storage M.2 Samsung NVMe 970 Evo Plus 250 GB + 1TB 970 Evo Plus
Display(s) Asus PG279 IPS 1440p 165Hz G-sync
Case Cooler Master H500
Power Supply Asus ROG Thor 850W
Mouse Razer Deathadder Chroma
Keyboard Rapoo
Software Win 10 64 Bit
awesome :D
if this does indeed come out... does that finally prove the 680 was/is a mid range card with a high price tag?
only time will tell if this is in fact true.... and not something made up.
It 'a very successful GPU and NVIDIA want to invest good money.
I am sure that they are already preparing, as there was the GTX 280 - 285.
Sources seem quite reliable.
expected price point?
$700???
$599 and a price drop would be a game changer!
how does it have 33% more shaders, double the ram and the bus, and is only 25% faster?
Stock clocks might be lower then GK104.
or its a bunch of bullshit ?
Maybe in economics... in this case its either not true or they have massive bottleneck somewhere.
No. It's always this way with pcs. Especially cards. You can add 15% more shaders but you're only going to get a 5% boost out of that. Just look at the 7950/7970 clock for clock.
That's better than the difference between Pitcairn and Tahiti.
7850: 32 ROP, 1024 Shader, 2GB VRAM, 256-bit bus
7870: 32 ROP, 1280 Shader, 2GB VRAM, 256-bit bus
7950: 32 ROP, 1792 Shader, 3GB VRAM, 384-bit bus
7970: 32 ROP, 2048 Shader, 3GB VRAM, 384-bit bus
The 7970 has 60% more shaders, a 50% higher memory bus, and 50% more VRAM, and is ~20% faster. Nvidia getting a 25% improvement over 33% more shaders and a wider memory bus is pretty impressive. If they priced this at $599, or $550 ad knocked everything down $50, they would crush AMD if they still refused to lower their prices at that point.
It's not much of a crush, because most of the revenue comes from under 300$, heck, under 250$ cards. And AMD has that covered since a loong time really. So it's more like the fastest card tag being a matter of prestige in us geek's eyes
Also, according to me, the HD7800 series DIE is the actual winner in this entire series. It's amazing, perfect, I believe if AMD had worked a month or two more on fine tuning it further, heck if they released the HD7870 as this:
- 1200MHz Core
- 1700MHz Memory (use 7GT/s chips already!)
The card would actually have left HD7970 in the dust, while being a HELL lot cheaper, to consumers and AMD as well.
25% improvement at stock clocks seems very possible and is what I would expect for a flagship card.
512bits seems such a waste of die for me 384bits and 6gbs gdd5 could provide already enough bandwidth for such beast.
I was just about to say that. At this rate with nvidia pricing I think it is extremely plausible to see the GTX"685" to be priced at about 550 to 600
awwww this looks bad for my 680. maybe I should sell mine off and just borrow a 6850 or something from my friend who doesn't use it anymore. and just buy this.
We'll see what will going to do after the GTX690. In theory they should present this alleged GTX 685 and then the GTX690.
It shouldn't be labeled GTX 685 as with the GF11x started the 5xx series, I don't see why the GK11x would not start the 7xx series.
Can't wait to see a 4GB card. should be a beast.
That's more likely, but we won't see these cards until at earliest the holiday season this year. I wouldn't be surprised if Nvidia released GK110 as the 7xx series, then just rebadged GK104 as the lower end 7xx series cards at lower price points.
