GELID Launches WING 12 PL PWM LED Case Fan
47,235 (7.55/day)
Thermal Solutions specialist GELID Solutions launches their first 120mm LED fan in green or blue light with unique magnet bearing and PWM.
The WING 12 PL features a unique Nanoflux bearing which ensures a friction-free and silent operation. Thanks to the clever design and magnetic bearing the impeller can be detached for easy cleaning. Additionally fan blade winglets were designed to achieve larger airflow and greater static pressure. In comparison to the multi-award winning Wing series the Wing 12 PL contains a premium PWM control so the temperature can be controlled precisely by the BIOS. LED lights in green or blue color were added to the WING 12 PL to give the fan a specific color.
The patented Nanoflux bearing (NFB) incorporates a clever magnetic design, very high precision manufacturing and runs friction-free and operates noiseless. Electromagnetic fields are exploited to keep solid parts from touching. The load is carried by a magnetic field. The Nanotechnology composite ensures lowest abrasion and extreme durability (MTTF 100'000 hours). The nano composite material is self lubricating Compared to conventional sleeve and ball bearings the high precision self-lubricated material of GELID Solutions Nanoflux bearing eliminates oil leakage.
"We created the Wing 12 PL especially for gamers and modders who are looking for a silent but colourful fan with unique features," said VC Tran Marketing Director of GELID Solutions.
Wing 12 PL has a MSRP of USD 19 and EUR 13. These fans are RoHS, WEEE conform and carry a 3 year warranty.
4,931 (0.74/day)
Hong Kong
Processor Core i7-12700k
Motherboard Z690 Aero G D4
Storage Plextor M10P 2TB
Display(s) InnoCN 27M2V
Case Thermaltake Level 20 XT
Any info on the actually specs?
Like Air Flow, pressure and noise?
371 (0.06/day)
These fans are excellent. I have the previous series (a bunch of them) in my current build.... the UV series. The specs of those are the same as these. They push a moderate amount of air, but are very quiet, and of course the blades can easily (almost easily) be removed for cleanin'. I highly recommend them.
znd002
10 (0.00/day)
The fan speed range is 600-1800RPM,controlled by PWM:D
WarEagleAU
Bird of Prey
10,812 (1.61/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
good amount of airflow pushed and the price is pretty good as well, though Id love to see it around 12 bucks USD. I like the colors too, think I would go for blue. Now need to see some more variants in the 140mm segement and 250mm segment for my CM HAF 932 case.
42,194 (6.64/day)
how about an Imperial (USA) conversion please (CFM)
