General Circuit Board Repair Question
djm5220
2 (0.00/day)
Specifically regarding an LG 60PV 450 plasma TV, but really just a general circuit board repair question: The solder connecting the 3 coils mounted on the Y-sustain and Z-sustain board have a known tendency to crack - see upper right of photo. But I have a far more drastic problem in the lower left of the photo, where the board has been burned, apparently by shorting. Is this even worth attempting to repair by resoldering, or is it beyond repair? Thx.
6,881 (1.46/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
yikes
13,275 (1.98/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Impossible to answer from here because we don't know if the board is burnt through all layers internally (if any) and on the other side, or if the component is damaged or not.
But IMO, sure it is worth trying to repair by resoldering. That costs nothing but a little bit of your time.
djm5220
2 (0.00/day)
Agreed!
True enough. And while I'm in there I might as well touch up the other 5 joints as well - they don't look particularly healthy. Thank you for the reply.
1,890 (0.79/day)
Cusp Of Mania, FL
Processor Ryzen 9 3900X
Case NZXT H710
Keyboard HyperX Alloy Pro
Whole thing looks cracked straight through. And its gone through a ground plane, looking at that peeled up copper. Other stuff on that plane may be affected if so. Hard to say at a glance. If youre lucky thats just a big trace. Really hard to know the real extent of the damage inside the pcb. On the bright side it looks like a simple pcb... might not be much under there.
Thats a big "i dunno, man..." Likely nothin but a big short straight through the board now. Sucker got HOT to crack like that. I definitely LOOKS bad. Still anything is possible.
Id still try. Get it cleaned up as much as you can and try it out. Plug it in and duck for cover lol.
Also solder cracking... not enough heat, not enough flux, or maybe bad lead-free... or some combo. Its not taking or setting like it should if its cracking like that.
14,146 (3.82/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
With all respect to Bill and his past experience, that appears to be a resistor that failed to do it's job, and now has to be replaced and still may not work.
The PCB is too severely burned IMO too.
28,121 (6.73/day)
Resolding would work to bridge the faulty circuit break, but it would not fix the potentially faulty components that may have caused it in the first place. It's worth a try, but be prepared to buy a new TV if you don't find and fix any other problems.
Frick
Fishfaced Nincompoop
19,643 (2.86/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
What does it look like on the other side?
12,325 (2.26/day)
Oregon
Keyboard EVGA / Logitech K400
This is a symptom of something else
42,464 (6.66/day)
Lots and lots of prepwork to clean it, something else failed, by the time you repair it you could get another board.
13,275 (1.98/day)
Nebraska, USA
Mouse Logitech M190
And with all due respect, do you have X-Ray eyes and can see the other side of the board? Typically resistors have small leads and if I had to guess, they would be where you can easily see the "bent" wires that are soldered.
Also, if you look at that picture, you can see printed on that circuit board, the image of a coil between that burnt lead and a similar lead to its right. So I don't believe it is a resistor but since we cannot see the component side of the board, I cannot be sure.
That said, if it is a resistor, and it is not badly discolored from heat (or burnt to a crisp), remember "Better be right or your great big venture goes west" (I was taught a different phrase way back in tech school that would be offensive today). A resistor is usually very inexpensive and easy to replace. But I suspect what ever created the excessive current would burn out the new resistor too.
3,629 (0.50/day)
System Name TheReactor / HTPC
Processor AMD 7800x3d 5050Mhz / Intel 10700kf (5.1ghz All Core)
Motherboard ASrock x670e Taichi / ROG Strix z490-e gaming
Cooling HeatKiller VI CPU/GPU Block -2xBlackIce GTX 360 Radiators - Swiftech MCP655 Pump
Memory 32GB G.Skill 6000Mhz DDR5 / 32GB G.Skill 3400Mhz DDR4
Video Card(s) Nvidia 3090ti / Nvidia 2080ti
Storage Crucial T700 2TB Gen 5 / Samsung Evo 2Tb
Display(s) Acer Predator xb271hu - 2560x1440 @144hz
Case Corsiar 550
Audio Device(s) on board
Power Supply Antec Quattro 1000W
Keyboard Corsair Gaming k70
Sure give it a try...but it is nearly pointless. There are complete traces that are burnt out that you will need to jump. Actually the resistor will be the easiest part. Plasma's have a ton of amps flowing in them so be careful. There are capacitors that store huge amounts on these boards so be very careful and if you know how to discharge caps I would do that first thing.
12,325 (2.26/day)
Oregon
inductor symbol
13,275 (1.98/day)
Nebraska, USA
Mouse Logitech M190
2,707 (0.75/day)
On The Highway To Hell \m/
Yup! A coil represents an inductor.
Or a simple electromagnet, if part of a relay. Or the primary/secondary winding of a transformer, if shown parallel to another coil(one of which being the primary winding, the other being the secondary).
13,275 (1.98/day)
Nebraska, USA
Mouse Logitech M190
Except the specific symbol printed on that specific PCP (the subject of this thread) is not the symbol typically used for a relay or transformer. It is a symbol commonly used for an inductor.
