- Jun 3, 2012
- 1,876 (0.43/day)
- Denmark
Processor | ryzen 7 5700x3d |
Motherboard | MSI B550 a-pro |
Cooling | Theremalright peerlees assassin 120 black |
Memory | 2x16gb 3600mhz cl 16 corsair vengeance lpx |
Video Card(s) | ASUS Dual GeForce RTX 4070 EVO |
Storage | 1x2tb KC3000 & 2tb samsung 970 evo plus, 2 x 2 tb external usb harddrives |
Display(s) | LG 32GP850, IIyama G2470HSU-B1 |
Case | Corsair 5000D airflow tg |
Audio Device(s) | Mission 778X Triangle Esprit Titus Ez |
Power Supply | Corsair RM850X White |
Mouse | Logitech G PRO Superlight |
Keyboard | Corsair K70 RGB TKL Champion |
Software | Windows 11 64 bit, Free bitdefender |
I have a Nzxt N7 Z590 mb and a i5 11600k
specs are 3.9ghz stock, max boost on all cores is 4.6ghz and peak i 4.9ghz
When trying 4.9ghz and using throttlestop + occt i get power limit to an extend where cores go to 100c
Stock with raised pl,current so it doesn't throttle, temps are under 80c, at 4.7ghz it could be avarage 80c
Can i adjust my cpu so it boost to 4.7 ghz on all cored,threads but don't go higher then 4.9ghz ?
Bonus question: If i go from a 240mm aio in the top of my case to the same aio in 360mm in the front, how much lower temps can i expect and will i be more likely to get pump noise mounted in the front ?
