- Jan 19, 2017
- 341 (0.12/day)
System Name | Core p90 |
Processor | I7 9700k |
Motherboard | ASRock Z390 Phantom Gaming 4 |
Cooling | Ek supremacy evo cpu block/nexxxos ut60 rad 480mm/D5 vario pump 310mm reservoir combo. |
Memory | Trident gskill 16gb 3000mhz |
Video Card(s) | Nvidia Founders edition rtx 3080 10gb |
Storage | M.2 Intel 660p 1024gb, 4tb 7200 rpm black Western Digital hdd |
Display(s) | Acer x34 predator 3440x1440p 120hz g-sync ultrawide 21:9 monitor |
Case | Thermaltake Core P90 tempered glass edition |
Audio Device(s) | On board |
Power Supply | Thermaltake smart m1200w |
Mouse | Logitech G600 |
Keyboard | Logitech G910 |
Software | Windows 10 64bit |
I have a 1gbps internet connection from my provider. I have an ethernet cable (cat 6a) going from my providers router/modem to my gigabit switch downstairs...
The cat 6 cable that feeds the switch with internet should be constantly showing two led lights... Which means 1gbps signal...
Instead, it STARTS with 2 lights, and after a few minutes to a few hours the inevitable always happens... I lose on of the 2 lights and my speeds drop to 100 Mbps or less...
II don't understand why this happens... I tried rebooting every device including the switch and the modem, I tried new cat 6 cables and the problem persists...
Whenever the problem appears, I'm forced to unplug the ethernet cable that feeds the switch to provoke the 1gbps signal into coming back... It sometimes requires many tries.... When I do get the 2 lights back I always end up losing one to the lights and the speed drops.
PLease help me fix this problem!
P. S. II'm thinking maybe the switch or the modem is defective. I'll have the hub/modem replaced tomorrow to see if it fixes the issue
