GIGABYTE AORUS Delivers DDR5 6000 MHz 32 GB Memory Kit With RGB Lighting
AleksandarK
2,828 (1.03/day)
GIGABYTE TECHNOLOGY Co. Ltd, a leading manufacturer of motherboards, graphics cards, and hardware solutions today announced AORUS RGB DDR5 6000 MHz 32 GB Memory Kit, which uplift frequency to 6000 MHz with RGB lighting for performance boost and striking accents. Enhanced by DDR5 XMP Booster and XMP 3.0 User Profile of GIGABYTE Z690 motherboards, and copper-aluminium heat spreaders with nano-carbon coating thermal design, the new memory kit promises the next-level performance with stability while dissipating heat efficiently under high-speed operation.
AORUS RGB DDR5 6000 MHz 32 GB Memory Kit features high clock speed and low power consumption by two 16 GB DDR5 XMP 6000 MHz dual-channel designs with 40-40-40-76 timings, which fit the support of DDR5 memory on Intel Z690 platform. Along with GIGABYTE Z690 AORUS motherboards, AORUS RGB DDR5 6000 MHz 32 GB memory kit can enable "DDR5 XMP Booster" function which detect the brand of memory IC in the BIOS setting to allow users to choose promptly from multiple built-in memory overclocking profiles, boosting the native DDR5 or XMP DDR5 memory speed. Furthermore, "XMP 3.0 User Profile" enables users to create and store XMP profiles of their own to unleash the extreme performance of memories.
AORUS RGB DDR5 6000 MHz 32 GB Memory Kit equips robust thermal solutions of the copper-aluminium heat spreaders with nano-carbon coating and high conductivity-thermal pad, so that users can rest assure of their memory overclocking. The heat generated from the power control IC and memory chip can be quickly carried out by the thermal pad and the copper bottom, and exchanges through the air between nano-carbon coated copper-aluminium heat spreaders. The groove cut by CNC on the spreaders enlarge the heat dissipation area to fasten the heat blown away by the system fans and drop the temperature. Users have no more worry about overclocking failures caused by overheating from high-speed operation or overvoltage of memories.
AORUS RGB DDR5 6000 MHz 32 GB memory kit holds 8 digital LEDs to create a diversified and gentle lighting display. The exclusive lighting strips and effects illuminate the AORUS design patterns to give the memory sticks a more vivid but not too sharp lighting glow. By using the GIGABYTE exclusive RGB Fusion App, users can synchronize the RGB lighting effects of their PC components and peripherals, playing around with more diverse lighting patterns on their build. With the built-in RGB lighting, users can showcase their own RGB style with athletics which is highlighted by the RGB memory lighting.
In order to provide more superior stability, and ultimate performance of memory, AORUS RGB DDR5 6000 MHz 32 GB Memory Kit was implemented with GIGABYTE ultra durable elements and verified with all GIGABYTE motherboard lineup. AORUS RGB DDR5 6000 MHz 32 GB Memory Kit will soon hit the market with its phenomenal performance and stylish lighting effects.
For more details, please visit the official GIGABYTE website: https://global-test.gigabyte.com/Memory/AORUS-RGB-Memory-DDR5-32GB--2x16GB-6000MHz#kf
bug
14,141 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
No pricing announced. They probably haven't finished writing down the number yet.
6,459 (1.55/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
6,904 (1.40/day)
Case NZXT PHANTOM410-BK
Power Supply Corsair 850W
Mouse Logitech Hero G502 SE
Another super overpriced CL40 garbage most likely...
227 (0.14/day)
Stehekin, Washington
System Name (2008) Dell XPS 730x H2C
Processor Intel Extreme QX9770 @ 3.8GHz (No OC)
Motherboard Dell LGA 775 (Dell Propiatary)
Cooling Dell AIO Ceramic Water Cooling (Dell Propiatary)
Memory Corsair Dominator Platinum 16GB (4 x 4) DDR3
Video Card(s) EVGA GTX 980ti 6GB (2016 ebay-used)
Storage (2) WD 1TB Velociraptor & (1) WD 2TB Black
Display(s) Alienware 34" AW3420DW (Amazon Warehouse)
Case Stock Dell 730x with "X" Side Panel (65 pounds fully decked out)
Audio Device(s) Creative X-FI Titanium & Corsair SP2500 Speakers
Power Supply PSU: 1000 Watt (Dell Propiatary)
Mouse Alienware AW610M (Amazon Warehouse)
Keyboard Corsair K95 XT (Amazon Warehouse)
Software Windows 7 Ultimate & Alienware FX Lighting
Benchmark Scores No Benchmarking & Overclocking
Amazing….looks like most new kits today including this newly proffered "AORUS RGB DDR5 Memory Kit" being 32 GB. A basic system with 16 GB will simply not do it anymore! Wondering now when industry talk and marketing will want to convincing us that 64GB will be the new normal?
bug
14,141 (3.96/day)
I went 32GB about 3 years ago. For $200 and change, it was hard to pass up, even if I didn't need it.
That said, if you need memory this fast, you probably need the capacity, too. If you're buying it to play games and run a web browser... you're doing it wrong.
