- Oct 9, 2007
- 47,200 (7.56/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
GIGABYTE TECHNOLGY Co. Ltd., a leading manufacturer of motherboards and graphics cards, today announced their upcoming 7 series motherboards will boast GIGABYTE's industry leading Ultra Durable 4 technology, helping to safe-guard GIGABYTE motherboards from common everyday threats, including humidity and moisture, electro-static discharge, sudden power loss and high operating temperatures.
"With the launch of the first Ultra Durable motherboard in 2006, GIGABYTE revolutionized the motherboard industry by making quality the number one focus in our motherboard design," commented Henry Kao, Vice President of GIGABYTE Motherboard Business Unit. "Five and a half years later, GIGABYTE maintains our leadership in quality design by equipping our upcoming 7 series motherboards with even more lifespan enhancing technologies in the form of Ultra Durable 4."
GIGABYTE Ultra Durable 4
GIGABYTE Ultra Durable 4 motherboards embrace a range of exclusive technologies that guarantee DIY PC builders the absolute best protection for their PC, with built-in features that prevent common malfunction threats users encounter on a day-to-day basis.
2X Copper PCB
GIGABYTE Ultra Durable 4 design features 2X the amount of copper of a traditional motherboard for both the Power and Ground layers which dramatically lowers system temperature by delivering a more efficient spreading of heat from critical areas of the motherboard such as the CPU power zone throughout the entire PCB. GIGABYTE's Ultra Durable 4 also lowers the PCB impedance by 50%, which helps to reduce electrical waste and further lowers component temperatures. A 2X Copper layer design also provides improved signal quality and lower EMI (Electromagnetic Interference), providing better system stability and allowing for greater margins for overclocking.
Humidity Protection
There is nothing more harmful to the longevity of your PC than moisture, and most parts of the world experience moisture in the air as humidity at some point during the year. GIGABYTE Ultra Durable 4 motherboards have been designed to make sure that humidity is never an issue, incorporating a new Glass Fabric PCB technology that repels moisture caused by humid and damp conditions. Using a new kind of PCB material which reduces the amount of space between the fiber weave, Glass Fiber PCB technology makes it more difficult for moisture to penetrate compared to traditional motherboard PCBs. This offers much better protection from short circuit and system malfunction caused by humid and damp conditions.
Electrostatic Protection
All GIGABYTE Ultra Durable 4 motherboards use high quality IC microchips that are rated with higher electro-static discharge (ESD) resistance than traditional IC implementations. GIGABYTE Ultra Durable 4 motherboards use ICs with up to 3 times the ESD resistance levels compared to traditional ICs. This helps to better protect the motherboard, its components and the PC in general against potential damage caused by static electricity, a common threat to today's PCs.
Power Failure Protection
If your home experiences a sudden power outage for any reason, GIGABYTE Ultra Durable 4 Classic are equipped to ensure that you won't be dealing with a fatal malfunction. All GIGABYTE Ultra Durable 4 motherboards use patented DualBIOS technology to provide fail safe protection for the BIOS on your motherboard, automatically refreshing your BIOS from a back up version in the case of a critical power outage.
GIGABYTE Ultra Durable 4 motherboards also feature special anti-surge ICs that protect your motherboard, and your PC, from any surge in power delivery that may occur, helping to ensure that your PC is equipped to deal with any kind of irregular and inconsistent power delivery.
High Temperature Protection
GIGABYTE Ultra Durable 4 motherboards feature specially selected components that make your PC capable of higher temperatures in more extreme conditions, while at the same time preventing your PC from overheating. Using all solid capacitors for the GIGABYTE Ultra Durable 4 range both reduces overall board temperatures while, making the motherboard more robust at higher temperatures. The choice of Lower RDS(on) MOSFETs also helps to reduce operating temperatures significantly compared to traditional MOSFET solutions. These component technologies combine to guarantee enhanced longevity and stability for your PC.
2X Copper PCB
Humidity Protection
