Gigabyte gpu model differences?
158 (0.40/day)
Motherboard ASUS Prime X670E-Pro WIFI
Cooling Noctua NH-D15S
Memory Kingston FURY Beast 2x16GB 6000MHz CL36
Video Card(s) Gainward RTX 2070 Super
Storage Samsung 990 Pro 2TB, Samsung 990 Pro 4TB, Samsung 970 EVO Plus 2TB, Lexar NM790 4TB
Case Fractal Design Meshify 2
Power Supply Corsair HX1000i ATX 3.1
I'm looking at Gigabyte 4070/4080 series gpu's, but there are too many models. Windforce, Gaming, Aero, Eagle, Aorus Elite, Aorus Master.
Anyone know what's the difference? I dont care about rgb.
115 (0.63/day)
Processor AMD 7800X3D
Motherboard MSI B650 Tomahawk
Cooling Noctua NHU12S
Memory 2x16 GB GSKILL 6000MHZ CL28
Video Card(s) Powercolor 7900 GRE
Storage 1TB Samsung 980 PRO
Display(s) LG 32GP750 31.5" 2K QHD (2560 x 1440) 165Hz Gaming Monitor
Case Coolermater HAF 650
Audio Device(s) BeyerDynamic Amiron Home
Power Supply Seasonic 850W Gold
It is going to be cooling, cosmetic, and minor clock differences. Get whatever one is the cheapest that is aesthetically acceptable to you.
*edit* I would personally skip the Aero and Eagle line as they are usually inferior coolers but if its a tri fan design it will be fine.
18,585 (2.72/day)
System Name AlderLake
If you got the cash for it
Gaming, Aorus Elite, Aorus Master.
Just checked, couldn't find "Aorus Elite" GPU's..
I always look at what temps they run:
GB Windforce GPU's used to be always the bottem of the barrel tier...
Not sure what tier they are at GB these days..
148 (0.06/day)
The only real difference are the minor clock speeds, which don't really matter any more.
Sometimes the cooler might have a small difference.
I bought my 4090 Windforce because it doesn't have any LED's on it.
The gaming model was a bit cheaper at the time as well.
WIth OC'ing i get the same speed as the Gigabyte Master and Asus Strix, although I don't bother OC'ing.
4,399 (0.90/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
At some point in time Windforce had slightly smaller fans but not sure if that is still done. That said; I had a number of Gigabyte windforce cards over the years and never had an issue with them, always ran at good temps with little noticeable noise to me (and I'm more of a noise freak than temp freak).
The reality of it is, like the other board partners, Gigabyte sells and competes at different price points throughout their video card lineup. In order to justify the increased prices they make cosmetic changes like the other AIBs.
How do you live with yourself knowing you don't get that extra 1-2 FPS by not OC?
17,151 (2.36/day)
Eagle is their budget cards and anything Aorus are premium products.
Not true as the Eagle cards are Gigabyte's budget cards and thus have a weaker overall feature set and component choices and that's compared to the Windows and Gaming cards, we're not even talking about the Aorus range here.
1,045 (1.90/day)
Processor Ryzen 7800x3d
Motherboard Asus B650e-F Strix
Cooling Corsair H150i Pro
Memory Gskill 32gb 6000 mhz cl30
Video Card(s) RTX 4090 Gaming OC
Storage Samsung 980 pro 2tb, Samsung 860 evo 500gb, Samsung 850 evo 1tb, Samsung 860 evo 4tb
Display(s) Acer XB321HK
Case Coolermaster Cosmos 2
Audio Device(s) Creative SB X-Fi 5.1 Pro + Logitech Z560
Power Supply Corsair AX1200i
Mouse Logitech G700s
Keyboard Logitech G710+
Software Win10 pro
There is a vast difference between the 3 fan coolers aswell... the gaming cooler is ALOT better than the windforce cooler, and the aorus is a bit better than the gaming.
And there is a difference in the quality of the power delievery aswell.
Personally i wouldn't get anything other than the gaming card from Gigabyte.
1,045 (1.90/day)
Software Win10 pro
I tested both the 4090 gaming and windforce, and the windforce was objectively just a worse card. It's more noisy while being hotter.
Avoid gigabyte cards, bad build quality, high temperatures and noise
Often is the case, sadly.
18,585 (2.72/day)
1,045 (1.90/day)
Software Win10 pro
The windforce has alot smaller fans, and a much smaller and lighter heatsink.
158 (0.40/day)
I was looking at:
Palit Jetstream(people say paste pump out fast),
Gainward Panther(annoying fan noise even at lowest rpm),
Zotac Trinity(runs hot like MSI Ventus),
Asus TUF which costs a lot, like the 4070 Super TUF costs as much as the 4070Ti Super Panther or Palit GamingPro.
148 (0.06/day)
You are a great expert.
Based on the picture above my post, the GB 4080 was the coolest card with the stock bios,same for 4070.
My 4090 in cyberpunk, during summer sitting between 50 and 60C while at 4k60, and I don't hear the fans. They are set to auto.
Which based on your expert advice, means all the temps are very hot.
Lei
1,143 (0.97/day)
usually in my shirt
Processor 3900x - Bykski waterblock
Motherboard MSI b450m mortar max BIOS Date 27 Apr 2023
Cooling αcool 560 rad - 2xPhanteks F140XP
Memory Micron 32gb 3200mhz ddr4
Video Card(s) Colorful 3090 ADOC active backplate cooling
Storage WD SN850 2tb ,HP EX950 1tb, WD UltraStar Helioseal 18tb+18tb
Display(s) 24“ HUION pro 4k 10bit
Case aluminium extrusions copper panels, 60 deliveries for every piece down to screws
Audio Device(s) sony stereo mic, logitech c930, Gulikit pro 2 + xbox Series S controller, moded bt headphone 1200mAh
Power Supply Corsair RM1000x
Mouse pen display, no mouse no click
Keyboard Microsoft aio media embedded touchpad (moded lithium battery 1000mAh)
Software Win 11 23h2 build 22631
Benchmark Scores cine23 20000
Better buy a bad 4080 than the best 4070.
There's also waterforce btw
1,045 (1.90/day)
Software Win10 pro
Based on what pic ? You bought the windforce, not the gaming... and the windforce cooler is alot worse than the gaming cooler...
As for those temps you mention, they say about nothing when you aren't pressuring the card... run unlimited fps, and show us the gpu stats in hwinfo.
Ps. I know cause i've used both gpus...
18,585 (2.72/day)
2,830 (2.13/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~1800 Video Games
I was looking at:
to be honest in the end it really does not matter.
they all perform the same and zotac has the longest warranty which is the only relevant thing if you're not super rich and can just dispose the GPU when it might break in a year and a half.
you can grab the zotac, enjoy a 5 year warranty and ignore that the GPU is 10° warmer than a strix. and if you are in europe everything from Palit/Gainward/KFA2 etc. is sold under XpertVision and has NO warranty outside of the enforced one by law if applicable.
1,045 (1.90/day)
Software Win10 pro
148 (0.06/day)
MSI afterburner at stock settings - Cyberpunk at 4k unlocked = peak at 66c 1.05v, 2775mhz auto fan
MSI set at 2,8ghz at 1.00v = 62c, auto fan.
Do you think Cyberpunk doesn't test a card even when locked to 4k60?
If I wanted to make my card seem like a ultra cool card I could of said Forbidden west maxes at about 52c because the fans start and then it drops to 46\47c, same with Horizon 5.
I could of said with GTA 5, my fans don't even start.
Ruru
S.T.A.R.S.
12,293 (2.86/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X
Cooling Arctic Freezer 50, GPU with custom loop
Memory 32GB Kingston HyperX Fury DDR4-3466
Storage 256+240+128+480+2x1TB SSDs + 3TB HDDs
Audio Device(s) Corsair HS35
VR HMD Oculus Rift CV1
Never had any problems myself (from both AMD and Ngreedia cards) but do they still have those cracking PCBs like reported some time ago?
148 (0.06/day)
He means my post https://www.techpowerup.com/forums/threads/gigabyte-gpu-model-differences.321642/post-5238094
But I agree about the WIndforce, those were always the bottom of the barrel like the MSI ventus GPU's.
The GB windforce GPU's used to come with a solid aluminium block for cooling, they changed it since then for cooling fins though.
When did the windforce cards just come with an aluminium block?
I've seen a 1070 that has fins and heat pipes, a GTX 770 with a 3fan cooler with heatpipes, a 960 with a similar cooler.
1,045 (1.90/day)
Software Win10 pro
Show me a screenshot of hwinfo64 while playing cyberpunk with unlocked fps, and not that BS.
912 (0.67/day)
System Name Yes
Processor E5-2690 v4
Motherboard VEINEDA X99
Video Card(s) 2080 Ti
Storage NE-512 KingSpec
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
There is even the windforce 4070 2X sweet little card but the noise of it might be unbearable without some power limit mitigation…,
Better than 4060 windforce single heat pipe that is the worst card ever i guess. ..
The new reinforced PCB is more of a straight line without a deep cutout, as shown by their renders.
148 (0.06/day)
There are two words I want to use but I will say the last one, you.
I sat there running a game benchmark 4x to appease you.
It is now 1am and I'm not running through hoops because you had an issue with your card.
I know what my card does because believe it or not I can see the figures.
The only time I have seen the temps in the low to mid 70's was when using 4k with raytracing in cyberpunk on a hot day.
That was only to see if it was worthwhile to use RT.
If you don't believe me, then fine, I will say I'm lying just to make you happy.
I'm done.
1,045 (1.90/day)
Software Win10 pro
I'm done.
It's simple math, dude. Smaller heatsink and smaller fans = more noise and / or more heat.
It's just a fact.
