- Mar 5, 2007
- 198 (0.03/day)
- Ålesund / Norway
System Name | Dark Matter / Mørk Materie (In Norwegian) |
Processor | AMD Ryzen 7 7700 (CPU Core Ratio: 'AI Enhanced' & OC: 'Curve Optimizer' @ -40 & 'PBO2' @ +200 MHz) |
Motherboard | ASUS ROG Strix B650E-I Gaming WiFi (AMD Socket AM5) (Mini-ITX) |
Cooling | CPU: EK Waterblocks EK-Nucleus AIO CR240 Lux (D-RGB) & Thermal Grizzly AM5 Contact & Sealing Frame |
Memory | Corsair Vengeance RGB Black DDR5 6000 MHz (PC5-48000) 2x16GB (AMD EXPO) (CL36 tuned to CL30 @ 1.4v) |
Video Card(s) | ASUS TUF Gaming GeForce RTX 3060 Ti 8GB V2 OC Edition (Overclocked +175 MHz Core @ +940 Mhz Memory) |
Storage | 1x Samsung 990 Pro 2TB & 1x Samsung 990 Pro 4TB (Both M.2 SSD) |
Display(s) | Dell S3220DGF (1800R Curved, VA Panel & 165 Hz Refresh Rate) |
Case | Phanteks Evolv Shift XT D-RGB (Black) (Modular) |
Audio Device(s) | ASUS ROG SupremeFX (Realtek ALC4080 Codec & Savitech SV3H712 Amplifier) (On Motherboard) |
Power Supply | Corsair SF600 Platinum (600w) (Modular) (SFX) |
Mouse | Logitech MX Anywhere 3S (Graphite) |
Keyboard | Logitech MX Keys Mini (Nordic) (Grey) |
Software | Microsoft Windows 11 Home (64-bit) (Norwegian) |
Benchmark Scores | Cinebench R23: 20.130 (Multi Core) (Single Cycle Run). |
Hello.
I do have an old 'Gigabyte GTX 1070 Mini ITX OC' GPU. You can see the info about the GPU here: https://www.techpowerup.com/vgabios/193322/gigabyte-gtx1070-8192-170309
The fan on my GPU is about to die very soon. It's acting up and are making some weird noises. So It's a clear sign that the fan is about to die and needs to be changed. So I have stopped using the GPU because of that and are running on my IGP from my 'Intel Core i5-4690k CPU from the stoneage now .
Is it possible to get hold of the same original fan that is on this GPU from somewhere?
I don't think 'Gigabyte' will be able to help me with that i'm pretty sure as this GPU is so old and such.
And I absolutely don't want to buy a new GPU (like the 3060 / 3060 Ti) now before the new 4000-series GPU's from NVIDIA is coming out later this year.
Hope someone can help with this as it's just a small problem with the fan.
EDIT: I found this on eBay that might be the fan I need: 4Pin Graphics Card Cooling Fan GTX1060/1080/1070 GPU Cooler for Gigabyte Mini | eBay
