- Oct 9, 2007
- 47,067 (7.59/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
GIGABYTE introduced the GeForce RTX 4070 Ti SUPER WindForce MAX graphics card. It is characterized by an oversized air cooling solution that gives it some large dimensions of 33.1 cm length, 5.55 cm thickness (3 slots), but more importantly, a height of 13.6 cm, which could pose a challenge for those with mid-tower cases, given the tight cable bending restrictions of the 12VHPWR connector. GIGABYTE found a novel solution to this problem. The power connector is located pointing toward the tail end of the card, where the PCB terminates. The PCB is only two-thirds the length of the card, and so the power cable can be routed in without any bends.
The WindForce cooling solution features a trio of 100 mm fans that ventilate a large aluminium fin-stack heatsink with nine copper heatpipes, and a direct-touch base. GIGABYTE has given the card a factory overclock of 2655 MHz GPU clocks, compared to 2610 MHz reference, while leaving the memory untouched at 21 Gbps. The card offers dual-BIOS, with the default BIOS enabling these clock speeds, and the Silent BIOS lowering them to reference speeds, while quietening the cooler. Based on the 5 nm AD103 silicon, the RTX 4070 Ti SUPER is endowed with 8,448 CUDA cores, 66 RT cores, 264 Tensor cores, 96 ROPs, and 264 TMUs. The GPU gets 16 GB of 21 Gbps GDDR6X memory across a 256-bit wide memory interface. The company didn't reveal pricing.
