- Nov 11, 2004
- 17,618 (2.41/day)
- Sweden
Keyboard | Corsair K70 Max |
Software | Windows 10 Pro |
Gigabyte Technology Co. Ltd, a leading manufacturer of premium gaming hardware, today announced a new AMD Radeon RX 6600 graphics card - the Gigabyte Radeon RX 6600 Eagle 8G. The Eagle graphics card is the best choice for those who desire a unique design optimized for power efficiency and durability, and the ability to experience incredible high-framerate 1080p gaming.
AMD Radeon RX 6600 graphics cards are based on the breakthrough AMD RDNA 2 gaming architecture, designed to deliver the optimal balance of performance and power efficiency. Offering 32 MB of high-performance AMD Infinity Cache, 8 GB of GDDR6 memory, AMD Smart Access Memory technology and other advanced features, the new graphics cards are designed to bring next-generation desktop gaming experiences to the midrange market. They also support AMD FidelityFX Super Resolution, an open-source spatial upscaling solution designed to increase framerates in select titles while delivering high-resolution gaming experiences.
The Gigabyte Windforce 3X cooling system features three unique blade fans, alternate spinning, composite copper heat pipes in direct contact with the GPU, 3D active fans, screen cooling and graphene nano lubricant that work together to provide efficient heat dissipation. These cooling technologies keep temperatures low at all times, resulting in higher and more stable performance. The middle fan spins in reverse to optimize airflow for heat dissipation, enabling more efficient performance at a lower temperature. Screen cooling extends the heatsink to allow air to pass through, providing better heat dissipation and preventing heat accumulation so to improve stability. In addition, graphene nano lubricant can extend the fan life by 2.1 times, delivering nearly the lifespan of the double ball bearing while providing quiet operation.
The design of Eagle graphics card is inspired by science-fiction with mechanical materials, providing a transparent cover and bright logo. In addition, the back plate not only strengthens the overall structure of the graphics card, but also prevents the PCB from bending or sustaining damage. GIGABYTE graphics cards use a multi-phase power supply, providing over-temperature protection and load balancing for each MOSFET and allowing the MOSFET to operate at a lower temperature. The Ultra Durable-certified chokes and capacitors provide excellent performance and longer system life.
