Gigabyte Outs First Dual-Thunderbolt Micro-ATX Motherboard
47,166 (7.56/day)
Gigabyte released the first motherboard in the micro-ATX form-factor to feature two Thunderbolt interfaces. The Z77MX-D3H-TH from Gigabyte is built in the standard 240 x 240 mm micro-ATX form-factor, and based on the Intel Z77 Express chipset, supporting socket LGA1155 Core "Sandy Bridge" and "Ivy Bridge" processors. The board uses an Intel DSL3510L dual channel Thunderbolt controller to drive its two ports.
The two ports, electrically-compatible with mini-DisplayPort, double up as display outputs that are routed to the Flexible Display Interface (FDI) taking display from the processor's integrated graphics core. With the included Lucid Virtu MVP software, graphics processed by discrete graphics cards can be output though the FDI, and hence these Thunderbolt ports.
The LGA1155 socket on the Gigabyte Z77MX-D3H-TH is powered by a 6-phase VRM. It is wired to four DDR3 DIMM slots, supporting up to 32 GB of dual-channel DDR3-2400 MHz memory; and two PCI-Express 3.0 x16 slots (electrical x8/x8 when both are populated). Other expansion slots include a couple of PCI-Express 2.0 x1, wired to the PCH. All six SATA ports from the Z77 PCH (two SATA 6 Gb/s and four SATA 3 Gb/s) are assigned as internal ports.
Display connectivity, apart from the two Thunderbolt ports, includes one each of DVI, D-Sub, and HDMI. Other connectivity includes four USB 3.0 ports (two on the rear panel, two by headers), 8+2 channel HD audio, gigabit Ethernet, a number of USB 2.0 ports, and PS/2 mouse/keyboard combo port. The board is driven by dual-UEFI BIOS. Expect the Gigabyte Z77MX-D3H-TH to cost around US $150-$170.
23 (0.00/day)
Gigabyte GA-Z77MX-D3H - 100 EUR (108.50 EUR at Mix-Computer)
Gigabyte GA-Z77MX-D3H TH - 150 EUR (at Mix-Computer)
Numbers from buy.fudzilla.com
Ridiculous :laugh:
17,493 (2.40/day)
Ridiculous :laugh:
Considering the TB chip alone is $15-20, not taking into account the connectors, extra power regulation components etc. it's not really ridiculous.
If you need it or not is an entirely different matter though.
28 (0.00/day)
Nobody in this world needs 2 Thunderbolt ports, one is more than enough (can already daisychain already up to 6 devices, incl montitors). Thunderbolt is still really expensive and this 2 port TB chip adds for sure 30 USD. Better save half that money and go for a solution with 1 TB port and more USB3 devices.
2,014 (0.33/day)
Processor RyZen R9 3950X
Video Card(s) RTX 3050
Storage Samsung 2TB SSD
Case Zulman MS800
Audio Device(s) On Board
Power Supply Seasonic 650W
Software Windows 11 64bit
I'm more interested in the Gigabyte GA-Z77X-UP5 TH or GA-Z77X-UP4 TH. Good to see though,...
iO
529 (0.12/day)
Germany
Processor R7 5700x
Motherboard MSI B450i Gaming
Cooling Accelero Mono CPU Edition
Memory 16 GB VLP
Video Card(s) AMD RX 6700 XT Accelero Mono
Storage P34A80 512GB
Display(s) LG 27UM67 UHD
Case none
Power Supply Fractal Ion 650 SFX
One connector for each of the two existent TB devices on the market...:laugh:
cadaveca
My name is Dave
17,232 (2.54/day)
Review will be live by next friday. ;)
There is actually about 35 devices available right now when I looked into getting one for reviews, not including Apple displays. However, each is quite expensive, for sure. Nearly $200 for an HDD dock is kinda unreal!
17,493 (2.40/day)
105 (0.02/day)
I can't stand Gigabyte's dysfunctional PCIe slot spacing. Building any decent Multi-GPU rig with their M-ATX boards blocks off your front panel headers... and it's not like there are many 5 slot cases on the market to begin with. What were they thinking? When will they get it right like ASUS, MSI, and ASRock?
17,493 (2.40/day)
Deleted member 24505
Whats the use of thunderbolt? surely the built in display connectors are enough, waste imo.
